Lookie what goes on tomorrow
Old Nov 10, 2006 | 09:23 PM
bdwarr6's Avatar
findanza
spec 2+
60lb injectors
2.6 pulley + Hub
HP Tuners
Cometic Headgasket
Golden Eagle Headstuds
AEM wideband
Valentine 1
Diamond Pistons
muhahaha i cant wiat
Old Nov 10, 2006 | 09:27 PM
CobaltPerformanceParts's Avatar
You better give us some build pictures . Good thing you got a radar detecter with you goodies. Your going to need it.
Old Nov 10, 2006 | 09:29 PM
M-Dub's Avatar
Lookin' good man... keep us posted with the build...
Old Nov 10, 2006 | 09:33 PM
M88ArRamadi's Avatar
what is Valentine 1? Just curoious....why did you choose GE HS?
I'm getting:
SPEC Stage2+
Fidenza Flywheel
Cometic HG
ARP HS
INJEN CAI
Diamond Pistons (10:1)
3pillar pod
AEM wideband
Meth. Inj
CA Front heat exchanger
Old Nov 10, 2006 | 09:37 PM
bdwarr6's Avatar
yes its a v1 only the best
golden eagle have a glass bead finish torque better
Old Nov 10, 2006 | 09:41 PM
what Compression Ratio did you get?
Old Nov 10, 2006 | 09:44 PM
bdwarr6's Avatar
10:0:1
Old Nov 13, 2006 | 04:03 PM
phlash's Avatar
thats a pretty high compression for FI,snce you have a 8.1-1 or something stock
Old Nov 13, 2006 | 04:07 PM
Jackalope's Avatar
10.1! WOOF! You planing to run Cam 2 all the time?
Old Nov 13, 2006 | 04:09 PM
3fo893013L's Avatar
is your build almost done? is the car running? still scewing around with that timing chain?
Old Nov 13, 2006 | 04:24 PM
06blackg85ss's Avatar
Our comp ratio stock is 9.5:1 there guys.... 1/2 point ain't too bad for lower boost (@15 psi)
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 27, 2015 01:27 PM
n20saturn
Drag Racing
19
Oct 6, 2015 12:38 PM
dennis69
Sep 17, 2015 12:52 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
