this throttlebody plug and play ??
Old Nov 13, 2006 | 10:52 PM
Serpico's Avatar
i know it wont mount up without an adapter but what im wondering if our tps/drive by wire connectors will plug into this
Old Nov 13, 2006 | 10:53 PM
Serpico's Avatar
its over 3.5 inches (90mm).....Thats A Huge Bitch !
Old Nov 13, 2006 | 10:55 PM
R&C_rallySS's Avatar
Interesting, any info about this thang? Is it for Cobalt SS/SC?
Old Nov 13, 2006 | 11:05 PM
Serpico's Avatar
hello no, its for a ls2- reason why i was thinking it might be plug and play was cause its made for a chevy (corvette) and i know that lots of manufacturers use the same sensors across model lines ... the amount of work it would take to make this work on a cobalt would be extensive and offer little gains with a m62
Old Nov 13, 2006 | 11:06 PM
Serpico's Avatar
i bet rob would know, hope i can get him to chime in..
Old Nov 15, 2006 | 12:18 AM
Serpico's Avatar
anyone?
Old Nov 15, 2006 | 12:23 AM
Cobalt_Supercharged's Avatar
I spoke with Rob (Fast06) about this months ago. He said tuning wise an LS2 TB would work, but it is way too large to do any good with the M62.
Old Nov 15, 2006 | 12:36 AM
cashstacker's Avatar
it looks like it uses a fly by wire, so how would we use it?
Old Nov 15, 2006 | 01:20 AM
That is probably a representative pic. The LS2 TB's are drive-by-wire
Old Nov 15, 2006 | 01:49 AM
Serpico's Avatar
what makes you think ill be using a m62 ?
Old Nov 15, 2006 | 01:20 PM
soccer1061287's Avatar
If the picture is representative, then that throttle body is mechanical. The electrical hook up on the side is for the idle air bypass solonoid. Even if you did adapt it to fit, a 90mm throttle body would really slow down the air flow. Its like putting too big of a carburetor on an engine. It reduces performance, not improve it.
Old Nov 15, 2006 | 10:31 PM
Serpico's Avatar
true most folks wont get any use out of a throttle body this large...
Old Nov 20, 2006 | 12:35 AM
NJHK's Avatar
Basically.
Also, with a larger throttle body, you still have to think about intake velocity cause it is still seeing "natural airflow", not highly pressurized airflow (above atmospheric pressure).
Old Nov 20, 2006 | 12:50 AM
Originally Posted by NJHK
Basically.
Exactly. Not to mention that it will be more difficult to find a low RPM TB position since the slightest movement will allow significantly more airflow. It will make the lower RPMs very jumpy and difficult to smoothly control.
Old Nov 20, 2006 | 12:51 AM
NJHK's Avatar
Bingo.
(I like the way you think )
Old Nov 20, 2006 | 12:58 AM
Bingo.
I've read a few books that have enlightened me of the importance of proper TB, intake, and exhaust sizing since I talked to Rob about it.
Old Nov 20, 2006 | 01:04 AM
NJHK's Avatar
Could you send me the names of those books via PM? I'd really like to look into them, I've been in a reading mood. I've just finished reading this book about Turbochargers in every aspect...finished it in 2 days
Old Nov 20, 2006 | 02:08 AM
Yeah, I'll send them to you Tuesday, I should have been in bed a couple hours ago. If you don't have them by midnight (your time) Tuesday send me a reminder. Things have been slipping my mind lately.
Old Nov 20, 2006 | 03:44 AM
NJHK's Avatar
okie dokie
Old Nov 20, 2006 | 10:25 PM
Rodimus_Prime's Avatar
way overkill even the GM drag cars only use a 75mm LS1 Tb
Old Jan 4, 2007 | 07:37 PM
grandma's Avatar
75mm LS1 t/b is more than you'll ever need on a GM 4cyl. However, as a side note, the 75mm LS1 t/b is not THAT jumpy at part throttle/lower rpms, you get used to it, and can drive it like any other car. It's just a lil bit of a learning curve.
I'm using it on a turbo Quad 4 though, so results may vary on jumpiness of the throttle.
Old Jan 4, 2007 | 07:42 PM
intense_SS's Avatar
that thing looks sick dude...it is huge!!!! is that for the ss/sc or no???
Old Jan 4, 2007 | 07:48 PM
grandma's Avatar
read the post and you shall receive.
Old Feb 26, 2008 | 10:40 PM
Serpico's Avatar
bringing back an old post ...i guess the ls2 doesnt fit but the ls4 does, anyone confirm ??
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
