Safe to?
Old Mar 6, 2007 | 02:39 PM
3ds138's Avatar
Safe to?
Is it Safe t run a 2.9 pulley on Gm Stage 2 Tune???
Old Mar 6, 2007 | 02:45 PM
Doc's Avatar
Doc
anything smaller and I'd go with 60's.
Old Mar 6, 2007 | 02:47 PM
3ds138's Avatar
waht about a 2.8?? i heard they are good with the Gm Tune or is it?
Old Mar 6, 2007 | 02:49 PM
Doc's Avatar
Doc
its pushing the limits of the injectors...personally, no, I wouldn't do it. Its been done though.
srt-killer's Avatar
You will be fine. Just don't go any lower than 2.8 with 42's.
Old Mar 6, 2007 | 02:54 PM
3ds138's Avatar
alright.. well i guess I will go with a 2.9.. or is it even worth it?
Old Mar 6, 2007 | 02:56 PM
Doc's Avatar
Doc
its worth it...there are quite a few people that run a 2.8 and stage 2 tunes. Just remember that the duty cycle increases when your in the higher rpm range. If you don't race or take the car deep into the rev's it might be worth it to go to the 2.8. Does pulley boys sell a 2.8 or 2.9..??
Old Mar 6, 2007 | 02:59 PM
3ds138's Avatar
think they got a 2.8, not to sure about a 2.9. I don;t ever go to the track.. try not to beat on the car as much.. but I like giving it a little bit of throttle on the highways and such.. I sometimes go in to redline. but not to often..
Old Mar 6, 2007 | 03:08 PM
Stouffer's Avatar
I have been looking into this as well. The 2.9 would be the safest bet from I have been reading and this is where I have found one that you can get to match the gm hub. Just got off the phone with them would take upto 2 weeks max to get the pulley. http://www.cobaltperformanceparts.co...roducts_id=336
Old Mar 6, 2007 | 03:17 PM
3ds138's Avatar
you sure that matches the GM HUB? does not look like it
Old Mar 6, 2007 | 03:20 PM
Doc's Avatar
Doc
I believe pulleyboys sells the right pulley
here... direct link
3ds138's Avatar
thats a 2.8
Old Mar 6, 2007 | 03:26 PM
Stouffer's Avatar
The one in the pic is not the one you get. I just talked them. They make any size you want to fit the gm hub. Takes them about 3 days to get it machined for gm hub. And you use the existing bolts as well.
Hey Doc, thnx for gettin back to me. I would go with the pulley boys but dont want to worry about the injectors with the 2.8. That's why I have been searching for 2.9 to fit the gm hub
Old Mar 6, 2007 | 03:36 PM
06blackSC's Avatar
here ya go! I just bought a polished 2.9" just a couple hours ago. A few members here already have his pulleys and the quality i hear is excellent! The seller is also a member here.
http://cgi.ebay.com/ebaymotors/ws/eB...0340&rd=1&rd=1
Doc's Avatar
Doc
awesome....glad to know they will make what you want. to Pulley Boys
Old Mar 6, 2007 | 03:38 PM
3ds138's Avatar
the gm stage 3 pulley is a 2.9? I could go with that to match the gm hub
Old Mar 6, 2007 | 03:40 PM
Doc's Avatar
Doc
I have one of those I have the pcm too
Old Mar 6, 2007 | 03:48 PM
barryBlueSS's Avatar
Greg Gm stage 3 is 76.0 mm which is a 2.99"(3.0)if I'm not mistaken. Your stage 2 is 77.9mm which is 3.07". If you want a 2.9, some guy on ebay name Nate will make any size you want to match your GM hub. And they say he does a good job too. I'll pm you his email address. ttyl
Old Mar 6, 2007 | 03:49 PM
BUCK's Avatar
I have a 2.85 on my GM 2 kit. I had Nate make this for me. He is on this site and does this for the public. He will be cheaper than other vendors on this site and he does top notch work. Mine works fine with the 42lb injecters. This is as low as I would go, and Nate backed this up. Just put a good set of colder plugs and it will work fine.
Old Mar 6, 2007 | 03:50 PM
Stouffer's Avatar
That was CobaltPerformanceParts that makes them. I was considering the gm stage 3 pulley, but there are others the same size for almost half the price.
3ds138's Avatar
thanks barry that would be awesoem
Old Mar 6, 2007 | 07:35 PM
Doc's Avatar
Doc
ooppss..
Old Mar 6, 2007 | 07:46 PM
bigrroberto's Avatar
so we should have no problem with 2.9 on stage 2 going to redline ?
Rduncanss06
Sep 27, 2015 11:17 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Macgyver2484
Sep 2, 2015 05:44 PM
