Gravana INGALLS Torque Damper PROTHANE Trans Bushing Promo - OVER 50% OFF!!!
Old Apr 2, 2007 | 04:31 PM
Gravana1's Avatar
FOR A LIMITED TIME ONLY, YOU CAN BUY THE INGALLS STIFFY TORQUE DAMPER AND THE PROTHANE URETHANE FRONT & REAR TRANSMISSION BUSHINGS FOR ONLY $175!!! THIS PACKAGE IS OVER 50% OFF NORMAL MSRP!!!
Once again, Gravana brings you a killer package promotion at a great low price! This package combines the Ingalls Stiffy Torque Damper with Prothane's Front & Rear Urethane Transmission Bushing Kits for the Cobalt SS 2.0 and Saturn Ion Redline 2.0 applications.
INGALLS STIFFY
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod applications if it is applied correctly.
Benefits:
  • Greatly improved off-the-line acceleration
  • Reduced wheel hop
  • Improved vehicle stability
  • Reduced shock loads on driveline components
  • Smoother shifting
  • Reduced wear on exhaust system joints
  • Less vibration transmission to the driver compared to polyurethane motor mounts
  • Less shock load, compared to torque straps and chains
  • Drifting – helps reduce shock loads when wheels gain traction
  • Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame
  • 1 year warranty!
PROTHANE TRANS MOUNT BUSHINGS
Much of the sloppiness in your driveline can be attributed to the factory transmission mounts. The OEM rubber mounts were never intended to take much abuse. Prothane transmission mounts are engineered to control torque and eliminate breakage. Prothane Transmission Mounts help transfer engine power more efficiently to the ground. Especially when the front & rear are used together.
Offer good only while supplies last. Not valid with any other promotions.
Old Apr 2, 2007 | 04:40 PM
Cobalt_SSTuner's Avatar
so you get both, the engine dampner and trans bushings for $175???
and with the coilovers, is that front and rear?
Last edited by Cobalt_SSTuner; Apr 2, 2007 at 04:40 PM. Reason: Automerged Doublepost
Old Apr 2, 2007 | 04:48 PM
srt-killer's Avatar
how much for just PROTHANE TRANS MOUNT BUSHINGS
Old Apr 2, 2007 | 04:50 PM
answered my own first question
Old Apr 2, 2007 | 05:16 PM
Stouffer's Avatar
x2^^^
Old Apr 2, 2007 | 05:18 PM
Gravana1's Avatar
Only $28.95 Each - Click Here!
Thx!
Jim
Old Apr 2, 2007 | 05:31 PM
FastPace Motorsports's Avatar
Are you sure you cant use the brushings on a LT.
Old Apr 2, 2007 | 05:38 PM
halfj99's Avatar
arnt the tranny mounts plastic? my concern is with stiffer inserts..it may put more pressure into the mounts causing it to break
Gravana1's Avatar
CLICK HERE FOR N/A APPLICATIONS!
Jim
Old Apr 2, 2007 | 05:40 PM
So, why isn't there a option for either application brushing?
Old Apr 2, 2007 | 05:44 PM
Gravana1's Avatar
Just go to our home page and select your Year, Make and Model. Then find the Transmisison-Clutch category on the left. The correct SKU will be tehre, mapped to the vehicle you selected.
Jim
Old Apr 2, 2007 | 05:54 PM
I want this package price though.
Old Apr 2, 2007 | 06:09 PM
Gravana1's Avatar
No problem. However, there is no guarantee that the Stiffy will work on all N/A applications. It has been hit and miss as to which years and engines. We just had two customers, both with 2006 2.2 Coupes, and one fit, yet the other did not. Chad has been working on a template to post online so you can check your car to see if it will work. Stay tuned!
Old Apr 2, 2007 | 06:12 PM
good question!
Old Apr 2, 2007 | 06:19 PM
Cool
Old Apr 2, 2007 | 06:30 PM
pimpnwink's Avatar
How do u install the Prothane Transmission bushings. Is there a how to for this yet?
Old Apr 2, 2007 | 07:52 PM
uwishuhdmyecotec's Avatar
thats a good deal, how long do you think it will last?
Old Apr 6, 2007 | 04:08 PM
spaz's Avatar
Hi, Do you ship to Canada usps, T3k 4z5? Price please.
And do you sell Control arm bushings(CAB's)?
Thanks,Chris
Old Apr 6, 2007 | 04:44 PM
UmeNNis's Avatar
damn - just bought my stiffy. aw well. keep up the good prices gravana!
Old Apr 8, 2007 | 04:34 PM
camarokiller's Avatar
Purchased! Thanks Gravana
Old Apr 8, 2007 | 04:56 PM
I'll be purchasing it on tuesday!!
Old Apr 9, 2007 | 01:53 AM
Pooch's Avatar
i would also like to know how if you shipp to Canada. and the price. and also can i just buy the Ingalls ETD? i have no need for the bushings
thanks
Old Apr 9, 2007 | 10:33 AM
another good question^
Old Apr 10, 2007 | 07:01 PM
spaz's Avatar
I guess no one is home?? Just would like to know how much shipping is to Canada?
Old Apr 10, 2007 | 10:22 PM
Rodimus_Prime's Avatar
Yea im interested in the torque thing but i have no need for the bushings
