Gravana INGALLS Torque Damper PROTHANE Trans Bushing Promo - OVER 50% OFF!!!
[QUOTE=Gravana1;950686]
Once again, Gravana brings you a killer package promotion at a great low price! This package combines the Ingalls Stiffy Torque Damper with Prothane's Front & Rear Urethane Transmission Bushing Kits for the Cobalt SS 2.0 and Saturn Ion Redline 2.0 applications.
INGALLS STIFFY
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The Stiffy was originally intended for the sport compact market, but can be used for some Hot Rod applications if it is applied correctly.
Benefits:
PROTHANE TRANS MOUNT BUSHINGS
Much of the sloppiness in your driveline can be attributed to the factory transmission mounts. The OEM rubber mounts were never intended to take much abuse. Prothane transmission mounts are engineered to control torque and eliminate breakage. Prothane Transmission Mounts help transfer engine power more efficiently to the ground. Especially when the front & rear are used together.
[QUOTE]
Just bought me this set of bushing and dampener cost me 190 shipped standard to MI....
FOR A LIMITED TIME ONLY, YOU CAN BUY THE INGALLS STIFFY TORQUE DAMPER AND THE PROTHANE URETHANE FRONT & REAR TRANSMISSION BUSHINGS FOR ONLY $175!!! THIS PACKAGE IS OVER 50% OFF NORMAL MSRP!!!
INGALLS STIFFY
Benefits:
- Greatly improved off-the-line acceleration
- Reduced wheel hop
- Improved vehicle stability
- Reduced shock loads on driveline components
- Smoother shifting
- Reduced wear on exhaust system joints
- Less vibration transmission to the driver compared to polyurethane motor mounts
- Less shock load, compared to torque straps and chains
- Drifting helps reduce shock loads when wheels gain traction
- Reduces motor movement decreases the chance of motor parts rubbing against the hood and frame
- 1 year warranty!
[QUOTE]
Select Shipping Service
UPS - Standard - $22.55
* Required
Ups fu#*ing rapes us on fees though.I want to know if they could send the stuff out USpost like some of our other vendors do.
Yeah ups cost me someting like 15.00something for standard shipping to MI
That is fucked up man now i know why stuff in Canada is so expensive but i feel for you guys in canada. You should have freind in MI and go to there house and pick it up lol save you a few extra bucks lol
DANRICKARD
Oct 1, 2015 12:08 AM
