2.4 blower?
Old Oct 3, 2005 | 01:47 PM
cobaltss87's Avatar
2.4 blower?
gm performance parts offers a blower for the 2.4 cavys i was curious if anyone knows if that same setup can be tossed into the newer 2.4s with equal results....now that the solstice and sky are out
http://www.gmgoodwrench.com/perfpart...253&section=ep
its at the bottom of this page
Old Oct 3, 2005 | 01:57 PM
97cavie24ls's Avatar
nope the 2.4 twin cam is alot different than the 2.4 eco vvt
you can use the 2.0 s/c parts , as it is a eco also
Old Oct 3, 2005 | 02:51 PM
2006ArrivalBlueSS's Avatar
Man, those 2.4L were 150 hp stock. You're telling me the blower only adds 40 more hp. I dunno if I'd spend that kinda cash for 40 ponies.
Old Oct 3, 2005 | 03:49 PM
well my last dyno was 140 to the wheels , before the header and high flow cat , and the best of 16.0 @ 84 in the 1/4
i havent dyno'd with the s/c and head and high flow , but so far my best is a 14.88 @ 92 mph
so that is more than a 40 hp gain , and i have had good cool weather for the s/c yet
and i know someone that has the 2.0 s/c's supercharger on his 2.2 eco cav and has put down 220 with the stock 1 7/8" exhaust , and ran mid to low 14's
Old Oct 3, 2005 | 04:13 PM
Very impressive numbers!!!
Old Oct 3, 2005 | 04:46 PM
thank you
im hoping to get it on the dyno this weekend , if the deal goes through , if not itll be in a couple weeks , gotta let it cool a little more around here , LOL
Old Oct 3, 2005 | 05:41 PM
xonic's Avatar
Do u have an intercooler? ....Are u running with the stock pully?
Old Oct 3, 2005 | 05:45 PM
no intercooler , ive got 1 of the few proto type 2.4 twin cam s/c's , so im not sure of the pulley size during the heat i see up to 7psi , and when i get the right amount of cold air ive seen up to 9
Old Oct 3, 2005 | 07:17 PM
phxSS's Avatar
97 cavie24ls's ride is pretty quick. i raced him on the freeway starting at 75mph, and barely pulled on him.
Old Oct 3, 2005 | 07:23 PM
3fo893013L's Avatar
What size throttle body you sporting? The injectors bigger?
Old Oct 3, 2005 | 09:01 PM
59mm tb , cai filter in the bumper , pacesetter header , 2 1/4"pipe into a 2 1/4" magnaflow high flow cat , magnaflow 2 1/4" cat back
motor has 102,000 , as does the trans and its not in the best shape
ive got 225/45/17 azenis sports , wilwood front 12.2 brakes , and a copy of the baer 12" rears
Old Oct 18, 2005 | 04:02 PM
cobaltss87's Avatar
wow way to stay on topic
Old Oct 18, 2005 | 07:23 PM
way to stay up to date , lol
yeah it went off
alot of people ive talked with have heard of problems when trying to boost a car with variable cam timing like the 2.4 has , cause it changes to often
but i will be trying it when/if i get a 2.4 cobalt
Old Oct 19, 2005 | 08:44 AM
brentil's Avatar
What a lot of vendors who don't take the time to correctly deal with VVT on a *charged system do is they just disable it via the ECU. It's a very dirty work around but it works. If they took the time and had the resources to correctly learn and tune the VVT it could be done correctly.
If the information is correct and the Solstice GXP is based off a Turbocharged VVT ECOTEC then there's proof right there it can be done correctly.
Old Oct 19, 2005 | 12:42 PM
actually im under the impression that GM is having problems with the solstice and boost with the vvt , which is why the 2.0 keeps being rumored to be the motor they will have for boost
honestly GM would be better off using the 2.0 head on the 2.4 , then boost it
Old Oct 19, 2005 | 04:36 PM
SCdyne's Avatar
VVT with variable boost like a turbo is VERY hard to deal with. VVT with boost based on rpm is easy to deal with.
Old Oct 19, 2005 | 06:09 PM
brentil's Avatar
Meaning using a Supercharger would permit much easier adaptation of VVT to the new system in other words?
Old Oct 19, 2005 | 07:06 PM
MikeSS's Avatar
The new pics of the Solstice with boost does not have a S/C, so I assume it is turbo
Old Oct 19, 2005 | 08:14 PM
s/c boost is variable also
it all depends where your foot happens to be on the go pedal
Old Oct 20, 2005 | 11:41 AM
SCdyne's Avatar
No matter what you do with an S/C the maximum pressure for a given engine rpm is always the same. Anything less is related to throttle position.
With a Turbo you can have maximum boost pressure at any rpm because of exhaust pressure.
Old Oct 20, 2005 | 04:34 PM
max boost per rpm , with your foot on the floor would be constant
but ive been able to hold my s/c to 2-3 psi while under accel , and have been able to regulate it with out being at max boost
but the s/c is alot more predictable on boost per rpm then a turbo would be , but that also depends on the size of the turbo , because you can size them on the small side and keep it closer to max boost alot sooner
Old Oct 26, 2005 | 12:18 PM
sunburst 2.4L's Avatar
Both are pumps
One is direct S/C
One is variable Turbo
4 stroke engine intake compression power exhaust
2.4L VVT is higher than normal static compression
used for S/C engines
Can you guess in what stroke one can "bleed off"
compression using the VVT technology to be able
to run a super?
Old Nov 10, 2005 | 01:24 PM
Turbo9nut's Avatar
So back to the topic. If I already have the 2.4L engine, can I just swap the 2.0L head and the supercharger on and make it work? If so, is it a bolt on deal or I have to do some fab work? Thanks
Old Nov 11, 2005 | 08:57 AM
This swap will entail some advanced research into the correlation between the higher 2.4L compression, amount of usable boost and the ecm reprogramming among other variables.
This would be better left to a "packaged product/system" instead of donor approach.
That is what I was leaning to in my 26-10-2005 post.
Oct 15, 2015 05:11 PM
Silverbullet333
Oct 4, 2015 02:27 PM
jimbofug007
Oct 2, 2015 12:06 PM
goaliemo
Sep 28, 2015 01:37 PM
