All with Sleeve work done...chime in
Old Jun 16, 2007 | 02:37 PM
M88ArRamadi's Avatar
Question All with Sleeve work done...chime in
Well I have to put new sleeves in and wondering what everyone's experience was. I just want to know:
Sleeve type (ie. Darton 100-500)
Sleeve cost
Installation cost
other work done (ie hottank, honing, boring, rebuilding)
Mine is going to be :
Darton 100-500
$675 Sleeve cost
$600 labor
HotTank & Honing
Old Jun 17, 2007 | 12:37 AM
spaz's Avatar
Dude Why do you need new sleaves? I have done a bunch at work, really easy there is a puller installer tool and then a cutter to machine down the top. You can easily do it in the car once the head is off it only takes about an hour. These were factory sleaves, I don't know about the darton ones.
Old Jun 17, 2007 | 12:38 AM
sick06cobalt's Avatar
dude you got ripped off.. My sleeves were free with the tee shirt i got lol
Old Jun 17, 2007 | 12:42 AM
I blew my rings out in #2 and it fuct up my sleeve
Old Jun 17, 2007 | 01:02 AM
spaz's Avatar
Are the Darton ones stronger and will they fit the block without machining? Is that the p#
Old Jun 17, 2007 | 01:10 AM
That's what I'm trying to get at. Darton ones ire suppose to be much stronger. I e-mailed Darton and that is the quote that they gave me. Thay also said that they would also have to do some R&D before thety can install them. They make the kits for the 2.2. I know, I know I tried to tell them but, they want to make sure the casting is the same.
Old Jun 17, 2007 | 01:26 AM
spaz's Avatar
Wicked ! any Idea how much power the stock ones are good for? I am doing a motor right now and maybe this is something I should look into.
Old Jun 17, 2007 | 01:27 AM
I have no Idea but I'd like to know too
I'm rebuilding my motor right now too
Old Jun 17, 2007 | 09:20 AM
The stock sleeves didn't fail did they? it was more like the piston failed and damaged the sleeves?
Old Jun 17, 2007 | 01:26 PM
^^^^^^^^^exactly...well the rings failed and damaged the piston and the sleeve
Old Jun 23, 2007 | 11:51 PM
can I get more input....please
BTW SPAZ do you want to sell the valve **** you just bought? I'm VERY interested
Old Jun 23, 2007 | 11:53 PM
Dustin's Avatar
Ah **** it, just run it with busted sleeves, lol.
Old Jun 24, 2007 | 12:14 AM
sunfirejoe's Avatar
the stockers are good for a while i think i think they shoudl be good for 600 hp, but dont quote me, when do they change in the ecotec building, i think they change blocks before they change sleeves,
so IMO, and what i did was, stick with a stocker, i got gipped on labour from the dealer, they charged me 400 to change a sleeve, took the ******* 3.5 hours
Old Jun 25, 2007 | 12:47 AM
spaz's Avatar
I told you to bring it to Calgary and I would have changed your sleave for you.O well.
And M88 I can't sell the stuff I need it so I can wrap the tach.
Old Jun 25, 2007 | 12:50 AM
I guess I'm going to have to buy them from a vendor
Old Jun 25, 2007 | 01:08 AM
sunfirejoe's Avatar
CED there on sale and got them to me quick
also spaz i totally forgot that u could do it, otherwise trust me i would have
Old Jul 19, 2007 | 03:44 PM
spike's Avatar
where is the best place 2 get a stock sleve my #1 is done 4
Old Jul 19, 2007 | 06:34 PM
sunfirejoe's Avatar
Crate engine depot
Old Jul 19, 2007 | 06:41 PM
06blackSC's Avatar
a friend of mine blew is number 4 and 1 ringlands and was thinking about getting sleeves done. The cost and labor ended up being so much he decided to go with a new GM race block instead with all the goodies....currently under construction.
Old Jul 22, 2007 | 11:17 AM
SuperEco06's Avatar
so does darton make sleeves for the 2.0? I was looking into upgrading pistons and rods, and while I had it apart was gonna put some new sleeves in as well,
Old Jul 22, 2007 | 11:26 AM
Jackalope's Avatar
I had a 1969 Pontiac 400 block bored 200 over and all 8 cylinders sleeved then the sleeves bored to except 455 pistons so when it was finished it displaced 427 cubic inches or 7.0 liters for those who don't know CI. The engine was bullet proof and dynoed to over 600 hp with almost 700 ft of torque. The redline was 10,000 rpm but it never saw much past 9000 cause of the cams power band ended at 9100.
Sleeves aren't bad at all from my experences with them. Hell all the top fuel dragsters run them so they can't be half bad.
Old Jul 22, 2007 | 11:38 AM
SuperEco06's Avatar
so jackalope do you know off hand how much the LSJ's sleeves could be bored out, I wanna do pistons and rods, and I want to pick up a little more displacement.
I havent heard of anything like a stroker kit for our cars, so I was assuming the good old fashioned bore it out method.
Old Jul 22, 2007 | 11:54 AM
Jackalope's Avatar
Sorry man I don't know the limits of the ECO engines but yeah the same way they bore out any engine is how ours is done.
Old Jul 22, 2007 | 12:17 PM
SuperEco06's Avatar
kk thanks man, just trying to figure out if i want overbore pistons or not
Old Jul 22, 2007 | 12:22 PM
WSFrazier's Avatar
If you want to stroke it, use a 2.2 rotating assembly. There are some things that will need to be worked out though. One is the reluctor ring on the crank, and another is the flywheel bolt pattern. Then you can also bore it out about .5mm over.
It can be done, just won't be a weekend job.
