All with Sleeve work done...chime in
The stockers used in the GM build didn't fail till over 700hp. So I don't think your going to have a problem with them. Now if you want to go with more then .5mm of overbore, I know Darton makes a +1 (87mm) for the 2.2. Should fit fine in an LSJ. Bigger then that and you might need to get custom sleeves made.
That's what I'm trying to get at. Darton ones ire suppose to be much stronger. I e-mailed Darton and that is the quote that they gave me. Thay also said that they would also have to do some R&D before thety can install them. They make the kits for the 2.2. I know, I know I tried to tell them but, they want to make sure the casting is the same.
thats why i did it myself, take my time and follow directions from the book very very carefully, i even found a couple goofy things that gm does, that well is weird, like who the **** wants to use angle sockets. its easier just to go with torque specs, that way u can re torque the studs half hour later
