my car can't accelerate hard until its warmed up...wtf?
Why is it that even on a 60-70 degree day...I can't jump in my car and hurry somewhere? If I try and accelerate much at all, or get into boost, it falls on its face until I let out on the pedal. It kinda lurches, like it isn't getting fuel or something. But after a few minutes its just fine.
Anyone else have this problem? I'm just wondering if its something I need to take it to the dealership over...
Mine never did it til stage 2....and even if I drive the car, let it sit half an hour, and then drive it again it'll do it. Not always, but sometimes. And I'm not talking about jumping in, starting it, and hitting 100mph 10 seconds later...this is just regular city driving, not going faster than 40.
car is still in its warm-up loop mode. no car actually likes being womped on when its still in closed loop. (or is it open loop? i keep messing those two up). just drive normally for a few minutes and all will be fine after. you may notice an exceptional amount of black smoke from the exhaust too when its cold...the cat hasn't warmed up either and can't do its job properly. when the cat doesn't do its job right, the computer picks that up and kind of freaks out to try to correct it.
It's open loop. Think of it being open loop because the computer hasn't begun to use the 02 sensors at that point so there is no self checking going on. Then when the 02s and coolant temp is warmed up enough it will start to make adjustments to the AFR and then the it will check itself using the 02s as if it's performing a loop (output to input and back).
+1 rep for good info
Ok, its actually getting worse now and it does it even after its warmed up, in just about any gear, under any form of acceleration, hard acceleration or just easing into it. During the same drive I'll accelerate once and it won't do it, and then I'll accelerate again and it will.
W. T. F. This is getting to be really irritating.
Mine used to do that when I was in Texas and it got really cold during a start up...took it to the dealer and they raised the idle about 200 rpm during startup I think. After I let it warm up for a few min, it was fine.
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
