Break-in for 2.4
Old Oct 15, 2005 | 12:44 AM
gmowner7's Avatar
Break-in for 2.4
I recently took delivery of a new 2006 G6 with the LE5 engine. So far, I have been driving a mix of city the highway driving. Is a careful break-in period for modern engines a necessity? I happened upon this internet link to a guy who puts forward a case for running the engine in a methodical and more aggressive manner to break-in an engine. Any thoughts?
http://www.mototuneusa.com/break_in_secrets.html
Old Oct 15, 2005 | 09:23 AM
avro206's Avatar
well your are varying the speeds at which the engine is operating--thats good. The owners
manual for the Coblat says do that for 500 miles (800kms).
I limited the rpms to 4500 and did not give it more then half throttle for that period. After that I gradually drove it harder. Redlined about 2000kms. It was hard to do and took some discipline! I almost always give the car 30sec to a minute to warm up if its been sitting over night too.
Old Oct 15, 2005 | 10:41 AM
RaineMan's Avatar
I've got about 1200 miles on mine and am just now starting to drive her in what I would call my "normal" style... I took it easy for the first 1000... kept it below 5000 RPM, only went on the interstate once....
Old Oct 15, 2005 | 06:35 PM
brentil's Avatar
If you read your manual it'll be in there.
Do the following for the first 500 miles.
Alter the speed/RPM and keep it at 65mph or lower.
Don't use the clutch to slow down, use only the brakes.
NO wide open throttle starts.
Old Oct 16, 2005 | 09:49 PM
gmowner7's Avatar
Thank you to all for the responses. Will keep up the go-it easy approach for another few hundred miles.
Old Oct 17, 2005 | 11:47 AM
97cavie24ls's Avatar
the first few hundred miles you gotta kinda go easy for the bearings
but you gotta drive hard to break in the rings
alot depends on who you talk to , me i go with the drive it like you stole it theroy
Old Oct 19, 2005 | 11:35 PM
sunburst 2.4L's Avatar
This seems to be the more generally accepted procedure these days
Old Oct 19, 2005 | 11:48 PM
with regards to avro206 "30 second warmup"
what we are after on "warmup" is to get oil circulating to elimate dry running
and to bring the engine up to operating temp. to stabalize dimensions
that said,
when the engine indicates normal oil pressure start moderate driving
this will help circulate oil to the top end and throughout the engine
continue moderate driving until normal operating temp. is reached
drive as usual - find someone to pick on
Old Oct 20, 2005 | 07:42 AM
avro206's Avatar
that said,
I didn't say that very well. I didn't really mean "warm up"---I know then engine is not going to reach operating temp in 30 sec. I sort of meant what you said.
Old Oct 20, 2005 | 09:14 AM
warm up
I'm not very clear either - I'm referring to the "sit and wait" philosphy NOT GOOD
What have you got done to the 400 in the 'bird?
My collection has been reduced to a ; '68 HO 350 , '65 389 , '69 428 , mid '70s 455
428 going in '31 Ford Model A P/U Gasser , 670 heads mild port unshroud intakes, RA IV cam , RPM intake , Q-Jet , 400 THM , 9" 35 spline 3:70 PROJECT IN PROCESS
I know this isn't a Pontiac site so if you like respond private as to not "pollute" this thread
Old Oct 20, 2005 | 04:36 PM
pretty much you want the motor to start to build up some heat before your playing with it
it doesnt take long for heat transfer from the combustion to warm things up
also sitting with the motor at low rpm , while its cold isnt good either because the extra fuel causes the oil to get washed off the cylinders , so you dont wanna sit for 5-10 minutes either
usually a minute or 2 is good
Old Nov 30, 2005 | 09:18 AM
VortecWes's Avatar
Break in is very important on the Evo. Break it in correctly and you'll have no oil usage...neglect the break in period and put a quart in every couple of weeks. I would imagine that most motors are that way. I'll be erring on the side of caution...
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
Oct 15, 2015 05:11 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
