HVAC problem... heat is on all the time
Old Oct 22, 2005 | 02:17 PM
Mercury's Avatar
Well I notice that when my fan is set to OFF heat is still coming out of my vents. If I turn the vent control to the floor, heat comes from the floor. Also If I switch the temperature control to cold, cold air comes out. Anybody else have this problem?
Old Oct 22, 2005 | 02:42 PM
Permafried-'s Avatar
Is it a hard stream of air or just a very slight flow? I notice when everything is turned off a very small amout of air still flows through but I also had this on my Cavalier so I assume it's normal. If you've got a substantial flow almost like the fan is on low then that would maybe be something you should get looked at .
Permafried-
Old Oct 22, 2005 | 02:46 PM
Asstyme's Avatar
"I notice when everything is turned off a very small amout of air still flows through but I also had this on my Cavalier so I assume it's normal"
Same thing here, my 2001 F-150 also did this. So in the summer just make sure the dial is on blue/red in the winter and all will be good.
Peace
Old Oct 22, 2005 | 03:12 PM
ExHondaMan's Avatar
Domestics Pwn
I think 99% of cars do this... nothing to worry about...
*EDIT* .. went and ahead and moved it over to general discussion
Old Oct 22, 2005 | 03:18 PM
Xenozx's Avatar
My understanding is the heat and cool take power from your Car when they are running? It would only make sense for it to be completely off when you choose off. I had a SE-R it still came out slightly, and it slightly comes out in my balt too.
Old Oct 22, 2005 | 03:28 PM
ExHondaMan's Avatar
Domestics Pwn
Try pressing your recirculate air button while your driving without the blower fan on....
Does air come out then ? or is it reduced from before ? It should be.... You will probably also notice that as you are driving (without the recirc button pushed) the faster you go the harder (harder being relative) the air starts coming out of the vents... The car is drawing the air from the outisde... which means the blower box has an opening to the open air... even if the fan is turned off... Air can still push its way through the tubes in the box.. especially at higher speeds..
Old Oct 23, 2005 | 02:50 AM
tiny's Avatar
its normal
i usually put it on cool air if its hot
or on defrost when its foggggggged
DarrenGC
Dec 24, 2021 01:55 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
jmelton327
Sep 26, 2015 10:04 PM
