Modern Performance Modern Performance is a Supporting Vendor
contacts: Modernceo
New Projector headlights w Halos for 05-08 Cobalts ! (Pics!)
Old Sep 17, 2007 | 02:55 PM
Modernceo's Avatar
(Pics down below!)
Mp has these lights IN stock, and with free shipping at $239.99
Available in black, and in chrome.
Quick facts on these headlights
-No cutting, or welding needed
-Comes with bulbs, no need to purchase any bulbs.
-You can install new headlight bulbs if you wish.
-We have not tested these headlights with HID lighting kits
-These come complete, nothing else other than tools needed to install.
-Installation should take 1-1.5 hours.
Modern Performance is proud to introduce to you the new projector headlights with halo rings and led turn signals.
They are also available in black, or chrome style as pictured below.
Although these lights come with halo rings as well as led turn signals, because they connect to your factory headlight harness for power for the headlights, and they have a spot for the turn signal, wiring up the led and halos are optional.
If you were to install them as the they were designed, you'd wire the halos to come on with your parking lamps, the led turn signals to flash with your factory turn signal. Both the Led turn signals, as well as the Halo lights have their own seperate power sources, so, you can wire them indepently for power.
The factory headlight plug (that normally plugs into headlight plugs into the wiring of these perfectly, and there's two wires for the led turn signals, and two wires to connect for the halo rings.
Installation is fairly easy, we recommend you have a socket and driver, wire strippers, electrical tape and a soldering gun.
Get a set of these today! Give Mp a call !
TedSS
101
Apr 25, 2016 10:46 PM
Pasierbek
Dec 10, 2015 07:22 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
jonnycat
Sep 19, 2015 12:58 PM
