LNF Powertrains
Old Oct 26, 2007 | 06:08 PM
CSM Huber's Avatar
Cool LNF Powertrains
http://media.gm.com/us/powertrain/en...2008/08car.htm for the 2008 GM Powertrains including LNF engines. No Cobalt listed but LNF engines AND ECOTEC compatible FWD transmissions are listed. Also links to pictures, specs, and dyno charts.
Old Oct 26, 2007 | 06:11 PM
Spectral's Avatar
i could be mistaken but that does nothing for the cobalt...the 2.0T in the saab is not the same as the LNF and is completely different.
Old Oct 27, 2007 | 10:18 AM
CSM Huber's Avatar
Question LNF is LNF engine across all GM companies
The LNF ECOTEC engine is an LNF engine regardless.... the issue for some will be the transmission its mated to. Obviously if it is originally factory mated to a RWD, the intake and exhaust tracts will not work without modification for a FWD swap. On the other hand if the LNF is found in a HHR SS, it should swap into a Cobalt fairly easily.
GM is manufacturing ECOTEC engines and their components so they "plug and play" for the most part.... but you do need to do some research and understand the capabilities and limitations of the components before you start making a hybrid swap.
Old Nov 3, 2007 | 02:26 PM
FastPace Motorsports's Avatar
Will a LNF with its tranny be a doable swap?
Old Nov 4, 2007 | 09:44 PM
CSM Huber's Avatar
Cool
I'm assuming you have not been reading about the 2008 Cobalt SS Turbo using the LNF?
https://www.cobaltss.net/forums/forumdisplay.php?f=152 for all the info....
Old Nov 5, 2007 | 07:21 PM
What? I'm saying for a current cobalt owner to install a LNF with its tranny.
Old Nov 5, 2007 | 08:18 PM
CSM Huber's Avatar
Cool
The LNF is the same basic ECOTEC block as your current engine. It will bolt up to the same FWD transmission. But you need the whole LNF (FWD) engine package (wiring harness, ECU, air induction,fuel lines, turbo, exhaust, etc. ) Until the 2008 Cobalt SS is generally available the HHR LNF is going to be the best source.... You could use a current Soltice, Redline, or Opal LNF engine but they are of course set up for RWD.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
