Glimmer Glass Detailing Glimmer Glass Detailing is a Supporting Vendor of CobaltSS.net
Newest Products arriving at GlimmerGlassDetailing >>>
Old Feb 28, 2008 | 09:36 PM
Chris(NJ)'s Avatar
3 Brand New products join the already stout Optimum Polymer Tech Lineup for 2008! A reformulated Spray Wax, The Instant Detailer & Gloss Enhancer and their Opti-Bond Tire Gel!
For the upcoming week, order a new Optimum Car Wax bottle and receive 1 free microfiber Towel! Order a new Optimum Instant Detailer & Gloss Enhancer and receive 1 free microfiber towel. Order a new Opti-Bond Tire Gel and receive 1 free applicator pad!!!
http://www.glimmerglassdetailing.com/optimumcarwax.html
NEW FORMULA OUT NOW!!
PRODUCT DESCRIPTION: Optimum Car Wax is the only spray car wax that provides the durability of a paste wax and long-lasting UV protection. A combination of high-grade Carnauba wax, sealant polymers and UV inhibitors forms a protective layer on the painted surface to protect the paint from sun damage and environmental elements for up to 5 months.
KEY BENEFITS
* Easy to Use
Takes less than 15 minutes to wax the whole car. No buffing required. No residues to remove.
* Durable
1 application lasts up to 5 months
* UV Protection
Helps reduce fading
* Non-abrasive
Will not create swirl marks like traditional car wax/polishes
* Environmentally Friendly
Contains no harsh chemicals or VOC's
* Performance Guaranteed
If not completely satisfied with performance, purchase price will be refunded
TECHNICAL BACKGROUND
Optimum Car Wax (patents 6669763 & 6685765) was developed after years of research in manufacturing automotive paint. Although automotive paint technology has experienced revolutionary changes in the past decade, the major wax/polish manufacturers have continued to offer the same old technologies. Almost all Original Equipment Manufacturers' (OEM's) automotive paint systems used today have a pigmented base coat protected by a thin layer of clear coat. The base coat is comprised primarily of pigments or colorants held in place by a polymeric resin film (binder). The clear coat contains polymeric resin or binder, UV inhibitors, and generally one or more additives. The additives can help protect the surface from scratches and marring, and generally last several months. Optimum Car Wax will add Carnauba wax to the surface and replenish sealant polymers to protect the finish from the environmental elements.
The UV inhibitors help keep the paint free of "free radical" degradation, and protect the pigments and colorants from oxidation. Over time the UV inhibitors become deactivated or consumed. Optimum Car Wax with UV is the only car wax that contains UV inhibitors and helps protect the paint from degradation and oxidation.
Top of page
ENVIRONMENTAL STATEMENT
Optimum Car Wax contains no chemical solvents or other environmentally hazardous compounds. Optimum Car Wax contains no VOCs and only the finest waxes, methicones, and emollients that are also used in many hand lotions. It is, therefore, very safe for the consumers as well as for the environment.
Top of page
TECHNICAL DATA
EXTERNAL UV TESTING
Panels that were painted with automotive base coat and clear coat systems were divided into two sections, the top half was left untreated while the lower half was treated with Optimum Car Wax. These panels were subjected to UV light in a QUV instrument which mimics direct sunlight. After only 6 weeks in the QUV instrument (which is roughly equivalent to two years of normal weathering), the untreated panels showed loss of gloss and clarity while the sections treated with Optimum Car Wax retained their high gloss and clarity.*
* Study conducted by Buckman Laboratories, Memphis, TN 9/10/02.
INTERNAL UV TESTING
Optimum Car Wax with UV was applied to clear coated glass panels and the UV levels were measured through the film. The UV inhibitors in Optimum car Wax reduced the UV levels by 43%. This level of UV protection can help increase the life of paint and the colorants in the paint by up to two fold.* * Study conducted by Optimum Polymer Technologies, Memphis, TN 10/15/01.
DURABILITY TESTING
Optimum Car Wax was applied to automotive coated panels along with two major leading spray car wax brands. These panels were left on an exterior surface at a 45 degree angle toward south along with an untreated control panel for five months. During this period of time, the panels were washed with car wash soaps on a weekly basis. While the panels treated with the competitive products showed no water beading after just one wash, the panels with Optimum Car Wax with UV showed visible water beading after 22 washes.* * Study conducted by Optimum Polymer Technologies, Memphis, TN 7/14/02.
http://www.glimmerglassdetailing.com/indeglen.html
Straight from the lab of Dr. Ghodoussi comes Optimum's newest creation, Instant Detailer & Gloss Enhancer.
Optimum Instant Detailer & Gloss Enhancer provides unsurpassed slickness and gloss in one simple application. Simply spray and wipe all automotive surfaces as the final step in your detailing process. The fluoropolymers in the Optimum Instant Detailer & Gloss Enhancer provide the maximum slickness, gloss and protection for all automotive surfaces as well as dust and dirt repellancy.
Available in 17oz ready to use (RTU) size and 32oz concentrate (which will make 1 gallon of RTU, Optimums Quick Detailer and Gloss Enhancer will be the last quick detailer you EVER have to purchase.
-Anti-Static properties help prevent dust, oil and debris from accumulating on the surface.
-Can be used as a waterless wash on surfaces with light dust
-Protects paint between routine waxing.
During controlled independent testing, Opt Instant quick detailer and gloss enhancer beat the ultimate, FK425 in gloss, and in slickness when compared side by side!
http://www.glimmerglassdetailing.com/optigel.html
Opti-Bond Tire Gel is a water based, VOC free tire dressing with high gloss and excellent durability. It can be used to protect and dress all tires, wheel wells, interior and exterior trim, vinyl, and dash whenever a high gloss finish is desired! Opti-Bond Tire Gel also protects these surfaces from ozone, UV and oxidation!!
-Protects & Shines Tires and Vinyl Surfaces.
-Contains Ozone & UV protectants.
-Contains no petroleum distillates.
-Environmentally Friendly!
-Performance Guaranteed!!
-Can be diluted 1:1 with water.
Directions:
Apply to clean and dry tires and trims with a sponge applicator. Allow to penetrate, then wipe away any excess.
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
