Question about Canuck Motorsports Lowering Springs?
yea hes got a 2.2, thats been lowered by like 2 inches. i dont think they will settle any lower tho bbrewbaker, mine didnt. prob thowing on my buddies old sportlines sometime this spring for a bit less wheelgap
It doesn't matter if the rear springs are "binding" as some of you call it.
They have what is called "dead" or "inactive" coils. They are the coils that look normal off of the car, but when installed, they are sitting on-top of each-other, (As seen in a picture on the 1st page). You actually need the "dead" or "inactive" coils in some cars, because when you increase the spring rate in a lowering spring it's obviously going to be shorter than stock spring rate. If you had a low spring rate but not enough coils to fill up space, you'd have a loose spring sitting there, which would be dangerous as all hell.
In short: The "binding" coils as you guys call it, (incorrect name), are not doing any harm what so ever, they are essentially filling space, that is all. Notice the active coils below them.
Thanks.
Thanks.
Front is about a 2 finger gap..rear is about 3 fingeres or so.
Here's mine on Pedders:
Yours (Again):
#36
i put my springs in today and i noticed that i put the springs upside down in the rear i have the touching coils at the bottom and the top i have the gap i wonder if this is safe to drive? or do i gotta change em right away?
#40
#42
It was a question and i knew it was old i was just hoping someone like you would see it and be able to answer that
#43
This took 10 seconds to Google. https://www.cobaltss.net/forums/susp...-coils-272919/
Consensus is the dead coils go to the top.
How hard was that?
#44
Again, Punctuation would help. We can't read your mind.
How hard was that?
How hard was that?
Btw it wasnt that hard to google i was just looking for someone cool enough to share their experience with cm and "knowledge" that you seem to have, thanks anyways.
