Chasing Knock WTF
Chasing Knock WTF
I am getting an HP Tune and between 5K to Redline I am getting crazy knock retard (5 -9.4) all the way through that range. I think it's false knock. I got under the car and the IC Pump mount was missing a bolt so replaced that, then I saw an blot for the Intake Manifold that had backed almost all the way out so i tightend it up and all the other Intake manifold bolts to make sure. Also changed the spark plugs to NGK BKR7EIX. WTF Could it be. I am stumped.
Engine sounds good. No sounds of knock at all. Check with a stetoscope.
Thinking about replaceing the knock sensor but I am not getting a code for it.
It's a 07 SS/SC 2.8, 60#, ZZP Stg 3 HE, Dual pass, opt b, ZZP Phenolic spacer, Bad Mab Header, ZZP 3"down pipe.
Any Thoughts.
Any Thoughts.
I was getting knock last week and was like wtf! First thing I did was look for metal on metal contact or anything loose in the engine bay. The hose clamp on my intake was rubbing against the option b post by the strut tower, adjusted everything and now its gone. I know I'm turbo now but throwing my situation out there might help.
Got Bewst?
Very. And WOT from 5500 to redline the car knocks non stop no matter how much timing you pull out of it. James went from 19* to 15* and he still had the same amount of knock. That's why I say it's the sensor. Or something is knocking internally. But you think you would hear that. The motor sounds fine.
twilson380
09-14-2015 10:52 AM
