09 bluetooth radio, compatible with 08??
I have been reading a couple of threads with people that have the 09 SS and they have the bluetooth and usb port. I was wondering if they were compatible as in plug and play with the 08 SS?? If so if anyone is upgrading their radio to an indash unit would you be willing to trade radios?
theres no button on our wheel for bluetooth, so that would kinda suck...Usb should plug& play its within the brain of the h/u itself...id have 2 look at it but i believe splicing the volume down button (wich is where it is on the 09's) to the bluetooth wire for end call from an 09 model would allow you the same thing, obviously without the little decal of the phone. Im going in dash but i have an 08 model...sorry
YEA, i thought of that as well but if i just remember what buttons are what i think that the wiring harness is the same. i doubt GM would change a whole body harness and wiring harness for a diff radio. atleast i hope they didnt so i can have a stock bluetooth unit
i really dont care about usb but i want the bluetooth. aftermarkets suck and i like the stock look
Last edited by Black08SSTC; Sep 15, 2008 at 10:39 AM. Reason: Automerged Doublepost
https://www.cobaltss.net/forums/electronics-audio-video-49/bluetooth-retrofit-128576/
You won't be able to retrofit an 08 with the 09 bluetooth setup...
https://www.cobaltss.net/forums/showthread.php?t=128576
There were software upgrades , module change and wire harness changes to the 2009's to support the Bluetooth feature . Youd have to retrofit the 2009 version of Onstar . Im pretty optimistic about getting wrong things to work
No one said I could get a 07 6 disc radio to work in a 05 but I did .....saying that , I can tell you 100% , you wont be able to adapt the bluetooth functions because there would be no way to retro in the 09 version of onstar . If you could find a GM tech that was smart enuff to unlock a incorrect model year headunit ( its not the standard vin relearn process in Tech2 ) and if GM didnt change the postions of the rest of the wires in the radio harness ( the connector is the same between 08 and 09 ) , you possibly could get the radio to function just without bluetooth( which is tied in with onstar , it uses the headunit for sound thru the oem speakers just like onstar ) . The USB port functions are internal to the radio and should function correctly as far as displaying ipod info on the screen . Im pretty versed in the OEM electronics and trying to get the OEM bluetooth to work would be a failing project .
agentirons
Oct 16, 2015 02:11 AM
