2008 SS/TC Loud Clicking?
#77
Mine is still stock.
The SS/TC is one loud car while stock. It buzzes, ticks, and clicks at low speed. I noticed that when the trunk kicking sound occurs, the AFR gets bumped up to 14.7:1 like it is being purged or something.
#78
Just gonna bump this and say thank GOD! haha I just bought this Victory Red SS/TC 08 used 19000 miles and heard that sound and was like OMFG its broken already! Haha thanks a lot fellas
#79
What about this one? When I park the car and shut off the engine about 30-40 seconds later I hear a loud click coming from the front of the car near the intercooler. It is maybe a little deeper of a sound than a click. I'll have to record it.
I have never heard the kicking in the trunk sound though.
#80
If you look at the Ecotec w/ DI used in the Equinox, it has a metric buttload of insulation on the engine. Imagine an average soccer mom driving a SS/TC - 100% of them will take the car in for weird noises coming from the engine.
#82
Very normal and necessary.
#83
Oh yeah, this is a one time thing when you shut off the ignition. I hear it too. Just flick the key to the RUN position and flick it off, you should hear the sound.
#84
I believe there is a way to eliminate the clicking noise if it bugs you that much, I don't mind it on my 09 SS. I just say to my friends "Cobalts make all sorts of funky noises, they scream, click and woosh depending on the model". Good times
#85
You for got to mention the squeal, screech and grind as well. (From the rear disc brakes!)
#86
Oh... to add one.. That kicking noise you guys are talking about coming from the rear?
I think its the heat shield above the muffler expanding while its getting hot. It'll sound like someone is tapping on the back glass 3 times.
The first time I heard that noise was a WTF moment. I turned around quickly expecting to see someone behind me.
#87
This noise can be reduced by 50%, GM actually makes a part that will quiet this noise.
Injector Pump Noise Reduction Cover GM Part # 12628069
The stock cover is a thin piece of black cardboard, while the new mod piece is much thicker; it looks like it is made of rubber or foam. This part costs less than $10.
Thanks to Crate Engine Depot for this information.
#88
I have an important update for everyone regarding the ticking noise coming from the fuel injector pump.
#89
#90
#91
QUEEF-NUGGETS
#93
My buddy makes the "man you have a bad valve knock going on!" and every time i have to remind him "dude its the direct injection" hahahaha
TELL ME ABOUT IT, my rears are loud as hell. as well as GOUGED.
#95
I'm having some rear grinding now with 18K mi..rears rotors don't look too bad...grooves, but not gouged. I'm gonna replace the pads and rotors in a week or so, as well as lube the pins. I found Thermoquiet Pads (you can get either ceramic or OEM organic..I got OEM) and Centric Premium Rotors....PLAIN. They're the same one's C1 Concepts use to drill and or slot. I really think it's the PADS and unlubed pins that are the root of the problem, but I would't rule out the rotors either. I got the pads for $38 shipped and the rotors for $111 Shipped. Cheap fix I would say. I wouldn't even bother to go to the dealer under warranty. Just DIY and be done with it.
