2010 mazdaspeed3 to compete with cobalt ss/tc????
Old Dec 18, 2008 | 03:50 PM
cereal83's Avatar
Those are coming to North America probably in Feb or sometime after the new year. It is a sexy car. 210 HP 4 banger turbo or 300 hp v6
Old Dec 18, 2008 | 03:53 PM
G85 SS's Avatar
Originally Posted by Perfect.disguise
From what I've heard it's just as fast stock for stock already (though the handling isn't on par) so I would think so.I've seen a vid on the current on running a 13.7 stock and I'm sure there are better times.
I'd like to see them both run a comparison lap(like what they did with the ZR1 and Skyline) out at the 'Ring. I'd be willing to put money that the SS will still be the fastest FWD out at that track.
Old Dec 18, 2008 | 04:40 PM
reddeerspeed3's Avatar
i think you guys are on crack. my stock 08 ms3 was definately equal to a ss/tc. however the no-lift shift thing definatly gives ss/tc drivers an advantage over inexperienced ms3 drivers on the track.
the 2010's will have a 2.5L 4 cyl, no HP/TQ numbers have been released by mazda yet. probably fwd though. as for aftermarket, the ss/tc will probably hit the same wall the ms3's have, at a certain HP range you guys will start blowing motors due to exessive cylinder heat issues. ms3's are limited to around 350WHP reliably on the stock 'forged' internals.
Old Dec 18, 2008 | 04:50 PM
ISuckBad45's Avatar
mazda3 sucks. looks like a shoe on wheels. it would be embarrassing to drive one... plus they cant handle at all! and the power numbers are not that impressive since its a BIG 4 cylinder. what is it a 2.3? and the numbers really are not that impressive. damn they are just soooo ugly. wow i really feel better now
Old Dec 18, 2008 | 05:04 PM
Nismothecat's Avatar
looks are subjective. some people dont mind looking like they are driving an Enterprise rental. some people dont mind driving around in a shoe on wheels. id love to see teh MS3 and SS/TC race at the ring to see which car really is better. the only time the MS3 was driven on the Ring the driver had never driven the track before so he was at a disadvantage from the beginning.
Old Dec 18, 2008 | 05:10 PM
09silverSSS's Avatar
and are RWD
GENESIS COUPE SPECIFICATIONS
• Configuration: Front engine, rear-wheel drive
• Wheelbase: 2820 mm / 111.0 inches
• Overall length: 4630 mm / 182.3 inches
• Overall width: 1865 mm / 73.4 inches
• Overall height: 1380 mm / 54.3 inches
• Wheels: 18-inch or 19-inch five-spoke
• Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo
• Est. horsepower V6: 306 @ 6,000 rpm (regular fuel)
• Est. horsepower V6: 310 @ 6,000 rpm (premium fuel)
• Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel)
• Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel)
• Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel)
• Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel)
• Block & head materials: aluminum for both engines
• Valvetrain: DOHC for both engines
• Valve timing: continuously variable valve timing for both engines (Dual for 2.0t)
• Estimated 0-60 mph V6: under 6 seconds
• Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or 6-speed manual, 6-speed automatic (V6)
• Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package)
• Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package)
• Front calipers: single piston floating (standard), monobloc four-piston (Brembo package)
• Rear calipers: single piston floating (standard) monobloc four-piston (Brembo package)
• Limited slip differential (Optional)
• Est. top speed: 149 mph (V6), 137 mph (2.0t)
• Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder)
Old Dec 18, 2008 | 05:51 PM
ISuckBad45's Avatar
the cobalt im pretty sure will out handle a mazda3... in a drag race you might have the upper hand b/c 2.3 adds up from factory. i cant wait to see which one does the best with just stock turbo
Old Dec 18, 2008 | 06:07 PM
i would be happy if GM put the SS/TC drivetrain and suspension in the Saturn Astra. i would love that car.
Old Dec 18, 2008 | 06:08 PM
Projekt's Avatar
the genesis is to heavy, wont compete in the same league as the cobalt.
Old Dec 18, 2008 | 06:22 PM
no but its RWD it has a big advantage right there. oh yeah and it looks ten times better than the MS3 and SS/TC
HKS Genesis. the 4cyl turbo was designed with mitsubishi so it should be pretty stout and mod friendly
Old Dec 18, 2008 | 06:33 PM
  #36
ISuckBad45's Avatar
dear lord..... that car might just be it... RWD turbos make me cry
Old Dec 18, 2008 | 06:34 PM
  #37
Projekt's Avatar
wasint designed with mitsubishi, the engine they use is the 2.0L world turbo, same engine in the csrt-4 (they have a stroker kit) and the evo.
Old Dec 18, 2008 | 07:44 PM
  #38
eman777's Avatar
the genesis looks really good and everything, but it is still a hyundai. but i defantly think that hyundai is moving more into a company to be taken more seriously while kia is left in the dust
Old Dec 18, 2008 | 07:47 PM
  #39
1BADSS/SC's Avatar
Originally Posted by bootymac
do you guys think that the new mazdaspeed3 is going to outdue the cobalt ss, im kinda wondering how it'll do, has anyone heard anything???
more than likely. Theyre incrasing the HP/TQ, and doing the suspension last I heard.
Its always a battle of better. MS3 will be better, then GM or Dodge will release something better than that, then ford, then mazda again, etc...
Old Dec 20, 2008 | 07:05 AM
  #40
IsItFast?'s Avatar
I dunno about that Hyundai... it looks like someone just didnt know when to stop designing it! And if it is anything like previous Hyundai's, replacement parts are going to cost an arm and a leg for it.
Old Dec 20, 2008 | 07:34 AM
  #41
blackbird's Avatar
Consider the Cobalt SS Turbo will more than likely be dead by the time the new MS3 hits the US market I don't think you'll be able to compare the two directly, new-for-new, and knowing Mazda and how good the current car is the new one should be even better. I'm pretty brand agnostic and try to remain unbiased and I bet it will do quite well. Faster? Handle and ride better? All quite possible or at least match the current Cobalt.
If you don't care if the Cobalt is still in production, then if any FWD to be released in the US can best the track numbers I'd say the Focus RS would have a good chance. There's a good chance we'll see it here on our shores in '10 as a MY'11 model. While the new 3 and Focus both share a similar modified Focus "C1" platform, the new RS has a trick "RevoKnuckle" front suspension that incorporates double-wishbone like movement into the Macpherson strut and is said to dramatically reduce torque steer and maintain precise steering over different pavement and road conditions.
Old Dec 24, 2008 | 10:32 PM
  #42
AtlM5's Avatar
Well the current one does already...and the next one is MORE THAN LIKELY gonna be lighter, have somewhare north of 300 hp/tq with an 2.3 or 2.5l turbo engine...so i'd say yes it will outdo the cobalt ss...besides the fact that the interior and overall build quality is insanely better...
the 2010 3 5 door is 25% lighter than the old one...
It will also MORE THAN LIKELY be FWD...
and the current one is quicker or as quick as the balt ss as is, not to mention as good if not better than the balt on the track...the balt is 10 seconds quicker around the Ring than the current ms3 and the balt had a professional driver who knew the track and the car very well while the ms3 had an ameture driver who had never driven the track or the car and was driving on and open track day so he was slowing down for other cars, etc...
Old Dec 24, 2008 | 10:38 PM
  #43
Mazdaboi318's Avatar
and lets think about money difference....they quoted me 25000 with a 2500 car trade in...fully loaded GT...
SS =20.9 fully loaded
SS FTW
Old Dec 24, 2008 | 11:06 PM
  #44
AtlM5's Avatar
o yeh I heard about that genesis but look how heavy it is...and fro the MS3...I don't want awd...I like having good low mid and high end power...not just low with some mid like the wrx's and evo's ...and it would add too much weight...look how the ms6 turned out with its awd system...an overwieght car with not enough power to overcome the weight issue.
Thats with navi...the balt doesn't even have that as an option...the build quality and interior is worth the extra money...NVM...THe Balt SS fully loaded is 26,105...vs ms3 loaded without navi is 25,948...
MS3 FTW!!!
SS FTW
Old Dec 24, 2008 | 11:08 PM
  #45
But mazda does not give you any incentives!!!
SS FTMFW
Old Dec 24, 2008 | 11:16 PM
  #46
AtlM5's Avatar
LOl... I thought you were gonna go there...w/e I'd still rather pay a couple g's extra for a much nicer car...and the balt ss is more comparable to the sport model which is less expensive...and learn to negotiate...I got my mazda dealer down to 21,500 for the GT...
SS FTMFW
And why is your name Mazdaboi if your supporthing the rental car...jk...if the balt had a decent interior i'd possibly be getting it instead of waiting for the 2010 MS3
  #47
welll.....the crazy dealerships dont budge here...cause people in louisiana are dumb...and will buy any and everything....
25k with TTL GT fully loaded....i got that quote...
20.9 Fully loaded....WIth TTL for the SS......i got that car
Old Dec 24, 2008 | 11:17 PM
  #48
AtlM5's Avatar
Thats cool...it's(the balt ss) still a very cool and fast car...
Old Dec 24, 2008 | 11:20 PM
  #49
oh yes...
i would have got it over the ss....
but that price is ridiculous
Old Dec 24, 2008 | 11:31 PM
  #50
xCobalt05x's Avatar
looks like an updated tiburon to me
