3 Bar Map Sensor Idea
Old Aug 23, 2013 | 10:03 AM
QuickSilver_SS's Avatar
Red face 3 Bar Map Sensor Idea
So i was thinking about an idea I had the other day for a bracket that would go over the gms1 3 Bar sensors to hold it in place. Especially on the plastic factory lower charge pipe. I was thinking something out of hard plastic or light wieght metal that would go under the bolt that holds the sensor down. And then loop tightly over the sensor to hold it down in place and then have a screw whole to screw down into the second spot where the stock sensors screwed into. What do you guys think of the idea ? I don't have the know how to build them. Anyone have the knowledge to build them and sell them to members ?
Old Aug 23, 2013 | 10:05 AM
blueLNFftw's Avatar
Is this some sort of common problem?
Old Aug 23, 2013 | 10:10 AM
Not overly. The top sensors on the intake mani always seem to be just fine. They are into aluminum and can probably be tightened down more. I have read of a few lower tmap sensor's leaking for a few different reasons. Some are wrong seals. Some are sitting crooked because of install or for what ever reason. Mine seems to be fairly tight. But it wiggles abit if I try to move it. The bracket idea would just give them abit more strengh as well as peace of mind.
Old Aug 23, 2013 | 10:36 AM
Sox-Fan's Avatar
Got Brakes?
Did that on my lower to change the orientation 90 degrees and get the wires away from the AC or radiator fan.
Old Aug 23, 2013 | 11:17 AM
What did you use to act as a bracket to be able to seure them down better ?
Old Aug 23, 2013 | 11:45 AM
JapEatr's Avatar
South Central *********
take a look at the bracket for the baro sensor on LSJ. it would be perfect fit
Old Aug 23, 2013 | 12:16 PM
I owned an 06 lsj for 5 years before my lnf. But i'm not really to sure which sensor you are talkong about let alone the bracket. Any pics of siad sensor and bracket ?
Old Aug 23, 2013 | 01:41 PM
Sox-Fan's Avatar
Got Brakes?
Made one. Small square of metal, a whizzy wheel, a drill. Boom. Done.
Old Aug 23, 2013 | 07:03 PM
SSlobalt's Avatar
Was that you, Sox? I remember that someone had a really fancy mounting plate the turned it 90 degrees.
Old Aug 23, 2013 | 09:18 PM
Sox-Fan's Avatar
Got Brakes?
Turned it 90 degrees, yes. fancy? hell no.
Old Aug 23, 2013 | 11:17 PM
SSlobalt's Avatar
somebody had a milled piece. it looked fancy.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
