Aeroforce Interceptor gauges
Old Jul 15, 2008 | 02:32 PM
IsItFast?'s Avatar
I can now verify these WORK with the 2008 SS/TC. I'm going to make a list of the sensors that work and the ones that don't in the next couple of days.
WB02, oil temperature, IAT and IAT2 work off the top of my head.
Old Jul 16, 2008 | 12:29 PM
IsItFast?'s Avatar
Sensors that work:
IAT1
IAT2
Ambient
Coolant
Catalytic Converter Temp
RPM
Boost
MAP KPA
MAF lb/m
MPH
Throttle Percent
Ignition Advance
Short Trm B1
Long Trm B1
Engine Load
Rail Pressure (BTW its around 550psi at idle FYI)
HP
Run Time
Barometric Pressure
Battery Voltage
Lambda
A/F ratio (YES it is a wideband)
MAF Frequency 1
Fuel
O2 B1S2
Oil Temp
instant MPG\MPG average
Misfires
Resetting the long term fuel works from the menu.
Resetting and reading CEL works
Fan controls (high and low) works
performance gauge works (measures 0-60, 1/8th mile, 1/4 mile times and MPHs)
Probably work but don't know how to test:
o2 current
ABS Throttle Pos
Knock 1
Does not work:
Fuel trim cell
A/F cmd
OIL PRESSURE (Damnit GM (and others), why cant you spend the extra few dollars on a simple sensor?)
Trans temp and basically all the sensors related to an automatic transmission (obviously). Maybe this works when the cobalt comes out with the auto.
Old Jul 16, 2008 | 12:30 PM
Projekt's Avatar
i beleive its the PT series that works (same as the 2.4L series)
Old Jul 16, 2008 | 03:38 PM
Z_Ghost's Avatar
Originally Posted by IsItFast?
Sensors that work:
That's what I want to know!
Why build a sports car and not put a oil pressure gauge in it, even my TrailBlazer had a oil pressure gauge in it
Old Jul 16, 2008 | 03:40 PM
MapOfTaziFoSho's Avatar
Excellent news!
Maybe I should search for an 08 on the lot...
Old Jul 16, 2008 | 07:12 PM
boostking's Avatar
where did you buy your gauge from because I will be installing this in place of my boost gauge
Old Aug 4, 2008 | 07:28 PM
IsItFast?'s Avatar
CN series (CAN) for General Motors.. There is a post I started on the Aeroforce Forum about this. This is just for the 2008 though, the 07 I think uses a different gauge.
Purchased it direct from Aeroforce www.aeroforcetech.com - They are actually an official sponsor of my car now. I am the very first person to install these gauges in a 2008 Cobalt SS!
Old Aug 4, 2008 | 07:34 PM
ecotecon18s's Avatar
DAMNIT!!! why can the ss/sc version have a a/f ratio that works!!!?!?!?!?
Old Aug 4, 2008 | 07:39 PM
Dead Zen's Avatar
ss/sc doesnt. unlss you hook up an anlog wire on the aeroforce to a wideband controller like the lc1
Old Aug 4, 2008 | 07:44 PM
yeah i know...
Old Aug 4, 2008 | 07:50 PM
marcusicp's Avatar
So to get the functions listed all you had to do was plug the gauge into the OBD port? Dose the gauge need external power or anything?
Old Aug 4, 2008 | 08:31 PM
IsItFast?'s Avatar
All you have to do is connect them to the OBD2 port.. No need for any external power!
Unless you are also connecting an analogue input, it is as easy as it could possilby be to connect these gages.
Since each gage can support up to 2 analog inputs, you could connect 4 more sensors to the 2 gage set.
Old Aug 4, 2008 | 08:45 PM
boostking's Avatar
this is the same gauge/unit for the ss/sc. I can buy the one for the ss/sc from cobalt addictions and it will work?
Old Aug 4, 2008 | 08:50 PM
marcusicp's Avatar
I really just wanted an A/F gauge but if I can get all of that off the OBD2 port I will use this instead. Can you run three of the off of the OBD2 port? Thanks for the info!
EDIT: I just re-read the website and I see that a triple set can be special ordered. I will contact them and get some info about it.
EDIT 2: I found something on the forum about the triple gauges here, http://aeroforcetech.com/forum/viewtopic.php?t=5
Old Aug 4, 2008 | 09:36 PM
hiltu's Avatar
super noob question. From everything i've gathered there is no reason that these gauges should void your warranty, but i just gotta ask: will this void my factory warranty? thanks
Old Aug 5, 2008 | 02:45 AM
d2k_01's Avatar
I have a question related to mounting rather than the gauges themselves. Your a-pillar with the tri-mount is in black. Does it come in a color and texture that matches the cream or beige color the stock pillar has?
Old Aug 5, 2008 | 05:25 AM
IsItFast?'s Avatar
I dont know - there are different types, this one is the one compatible with the CAN bus - which earlier Cobalts did not use - it may still be the same gauge though.
No. These gauges do the same function as hooking up a scan tool to your OBD port.
Its hard to tell from the picture, but the texture almost matches perfectly. I got a great deal on the black pillar, so I didn't bother looking for a cream colored one I supposed you could always paint it to match, but no one that has ridden in my car has notied its black instead of another color.
Old Aug 5, 2008 | 07:16 AM
boostking's Avatar
thanks for the info. I will contact them.
Old May 19, 2009 | 10:41 PM
DoMiStIc_RuSh_06's Avatar
so the pt gauge wont work on the 09 turbo, it has to be the cn gauge, is this correct??
Old May 20, 2009 | 12:26 AM
hallss's Avatar
does anyone have one of these lists for the dash daq?
Old May 20, 2009 | 12:42 AM
Gestapo007's Avatar
did you order the SS one or the regular model. I was all set to order one but heard on the TC you cant order the cobalt SS one.
Old May 20, 2009 | 01:04 AM
Boosted_Cobalt09's Avatar
i currently am the first cobalt with the triple setup lol. ordered it months ago but no one was intrested in pics or anything when i tried to make a thread on it. anyways yes they are the cn gauge. also not that with the triple they react a little slower since now you have 3 gauges fighting for bus time instead of 2. its not horribly slow or anything just a tad bit slower most wouldnt even notice. i ran the single on the bottom and the dual in the upper 2.
Old May 20, 2009 | 01:09 AM
stacy_dammit's Avatar
OK!....I'll be brave, what exactly is the interceptor for???
Old May 20, 2009 | 01:16 AM
marcusicp's Avatar
It is a mutigauge that lets you see most of the parameters of the engine with out the need for lots of gauges. It plugs into the OBDII port under your dash and gets all the info from the ECM just like a dealer scan tool would.
Old May 20, 2009 | 01:21 AM
oh ok thnk u...i kinda had an idea but i thought it was only for air fuelreadings..i didnt think all that....so it helps if there is sumthng off somewhr in the engine?
