Air Conditioner
Air Conditioner
Hey guys well i bought my tc right before winter when it was starting to get cold and never really used the AC and now that its getting warm im starting and im noticing that it sucks.. Takes forever to get cold.. and It barely gets cold at all.. Just wondering if it sucks in everyones car or i need to take mine in.. Any help would be nice.
Mine gets cold almost immediately and can freeze me to death. Perhaps give it a couple days of running it full-on with the windows down and see if it just needs to get some use out of it. If it still isn't cold, take it into the dealer and have them look at it.
Yeah ive had it on full blast for the past 3 or 4 days.. And leave it on full blast all day during my 30 mile drive to work.. Still no cold air.. I guess ill take it to the dealership.. Have them charge it..
I bet they say the bov is blowing off the cold AC air :P
I bought my 08 SS brand new and the AC needed to be charged up right away. It was about 15% low on refrigerant which can make a big difference. I would take it to the dealer, they shouldn't give you any guff.
yeah both buttons are on haha.. but i just got back from the service shop and they said my aftermarket cai rubbed a hole in my somethin line.. i havent got in there to look yet but if thats the case im gonna be pissed at dejon.. they also said they called the dealer and they dont make that line.. wtf.. i can tell ths is gonna be a pain in the ass..
Just because the A/C isn't cold doesn't necessarily mean you are low on refrigerant. There are several causes, and to properly diagnose it you need (at the very minimum) a vent thermometer, and a set of A/C manifold gages that measure the high and low side pressures. Those chill-in-a-can's from the autostore that have the attached gage are inaccurate at best, and if you have a blockage in the system the low side pressures could be high or low and wont let you know if the compressor is working correctly.
After replacing the line, the system must be properly evacuated and a vacuum pulled on the system down to very low micron vacuum levels several times to remove any moisture in the lines. Then the proper amount of oil and refrigerant re-added using the above gages.
z28addiction
Sep 28, 2015 12:03 AM
OrangeCoba
Sep 25, 2015 06:06 PM
