All lights on with brights
Old May 15, 2009 | 08:32 PM
sponge14's Avatar
I was wondering if anyone could tell me, from experience, how to make my driving and fog lights stay on with my brights? I want to be able to push the stalk forward and have it look like it is when you hold the stalk back.
Old May 15, 2009 | 09:16 PM
BartSS's Avatar
You can't bro
Old May 16, 2009 | 12:17 AM
kylewalton2007's Avatar
fog lights shouldn't be used with high beams, and in pa and probably other states for inspection, the fog lights have to cancel out when the high beams are on.
Old May 16, 2009 | 05:26 AM
Nighthawk243's Avatar
Originally Posted by BartSS
You can't bro
It actually is possible.
You will need to use a setup of relays to accomplish the task.
That being said, having your fog lights remain on with the high beams is illegal per the vehicle codes of most states. In addition, the OEM wiring doesn't like the additional heat from running all the lamps at once. This setup is better suited for those of us who use HID in projector housings.
Old May 16, 2009 | 09:53 AM
BartSS's Avatar
Yeah I was just thinking about relays. But is it worth it to you to mess with all that?
Old May 16, 2009 | 10:00 AM
Gestapo007's Avatar
do u drive with your brights on in fog alot?
Old May 16, 2009 | 01:57 PM
sponge14's Avatar
The fog lights being on is not a necessity, I mostly just want the driving and brights on at the same time.
Old May 16, 2009 | 02:53 PM
Hamrhead's Avatar
X2.
High and Low beams BOTH on at the same time (when using the High beams) would be nice.
Old May 16, 2009 | 07:26 PM
rat's Avatar
rat
I feel that it gives you a false sense of security. It puts too much light too close to the vehicle.
Old May 16, 2009 | 07:53 PM
In PA, it helps immensely. You have high beams to see further down the road, but you also have low beams to watch the sides better for any closer animals that want to use your car to commit suicide.
Anyways, to the OP. You can easily do it with relays, but if you're on the OEM bulbs (Halogen), I don't reccommend doing it since it generates a large amount of heat. The Projector housing with low beam HID suits this setup perfectly and safely (And throws an insane amount of light down the road to boot).
Old May 16, 2009 | 08:10 PM
metroplex's Avatar
I'm afraid of upgrading to the aftermarket projector lights because I heard they're leaky and tend to crack easily.
Old May 17, 2009 | 01:28 AM
Got Boost SC-Ya's Avatar
Originally Posted by Hamrhead
X2.
In most states that is illegal as well.
Old May 17, 2009 | 02:47 PM
Maven's Avatar
As stated its illegal to run high beams and fog lights at the same time. It can be done with a relay kit though. Buy a 4 lamp headlight kit designed for Chevy trucks, you can make it work.
Old May 18, 2009 | 10:08 AM
wantedSS/TC's Avatar
not worth it. WHy would you want to anyways?
Old May 18, 2009 | 10:18 AM
originaladrian's Avatar
just buy a relay kit. its very easy.
To those who say you cant.
Are you just talking to get posts up or something or actually think you know what your talking about?
whatttttttt????
if done proporly theres no risk.
some people do it to save there HIDs from damage.
Mine happen to stay on when I flash my brights.
Last edited by originaladrian; May 18, 2009 at 10:18 AM. Reason: Automerged Doublepost
Old May 18, 2009 | 10:32 AM
MapOfTaziFoSho's Avatar
Most cars are set up, from the factory, with the low beams programmed to stay on with the high beams.
Old May 18, 2009 | 10:33 AM
metroplex's Avatar
Only temporarily using the flash to pass feature. If the high beams remain on, the low beams and fog lights are normally shut off.
Old May 18, 2009 | 10:34 AM
On the Cobalt, yes, but most other cars...not the case.
Old May 18, 2009 | 11:06 AM
koch1ar's Avatar
um none from gm, a lot of fords! what cars do you speak of?? lol
Old May 18, 2009 | 12:22 PM
dunit121's Avatar
you only need to run 1 relay but 2 would probly work better ... but honestly a relay is one of the easist things to wire up once you know how and would take all of 15 minutes to do because i did this on the old car and i never had a problem with the cops and i drove by a few with my brights and fogs on in the hamptons
Old May 18, 2009 | 07:31 PM
Hamrhead's Avatar
My '04 SVT Focus (w/ HID's) worked this way from the factory.
I see many cars/trucks that keep the low beams on with the high beams.
Old May 18, 2009 | 09:19 PM
sponge14's Avatar
Almost nothing is illegal in Oklahoma. We don't even have safety inspections on cars anymore.... To those that ask why: Have you ever driven on a rural Oklahoma road at night?
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
