amount of Moble1 grease on Forge bpv
Old Nov 8, 2014 | 11:22 PM
Devin86's Avatar
I cant get the amount right every time i go drag racing i get a bpv code stuck open/closed. I pulled it out and it was dry looking with a light coat of grease on befor the races. But ive over greased it befor too. So how much should i put on???
Old Nov 8, 2014 | 11:28 PM
nathan112i's Avatar
use high temp grease and remember a little bit goes a long way, quick skiff coat around the inside and making sure the o rings get lubed then wipe off any extra
Old Nov 9, 2014 | 12:01 AM
Devin86's Avatar
So i should put a light amount on the inside then just the orings?? Ive put a VERY light coat on the plunger and o-rings but it still failed every time i go to the strip-.-
Mabe i just need a red coat inside and a light coat on the orings. I think im Putting to little and its getting to hot fading it away
Old Nov 9, 2014 | 08:56 AM
blueLNFftw's Avatar
Get a high temp grease.
Old Nov 9, 2014 | 11:58 AM
Devin86's Avatar
Im using the moble 1 red grease if says its good up to like 350F unless that's not high enough. Keep ir mind this is only at the drag strip i drove the car hard the last few days trying to see if it would happen and nothing. 2nd pass at the drags and the CEL popped.
Old Nov 9, 2014 | 05:00 PM
nathan112i's Avatar
in all honesty i have the forge bpv and it sounds cool and all, but stock bpv is probably better for what your doing
Old Nov 9, 2014 | 06:43 PM
Devin86's Avatar
The stocker wasnt holding the psi anymore so i went with the forge. When i got it there was a big glob of grease on the end of the pluger i figued that wasnt right. So i cleaned it and re-greased it. I just cant seem to get the right amount back on and it only acts up at the drags im guessing cuz all the back to back runs
Old Nov 9, 2014 | 08:45 PM
nathan112i's Avatar
yeah you basically had it right, get the orings lubed up enough so they are not dry and put a TINY bit inside the 2 orings so it self lubricates on each stroke and service every oil change.
Old Nov 9, 2014 | 09:41 PM
tomj77's Avatar
Mobile one grease sucks. It gets sticky after awhile. Use something else, full synthetic high temp.
Old Nov 9, 2014 | 11:48 PM
Devin86's Avatar
I think i got it the cel went away this time with out me taking it off do it must be good for now. Ill just make sure to service it befor the drags start back up in February
Old Nov 10, 2014 | 08:24 AM
blueLNFftw's Avatar
I would suggest Mystik Hi-Temp #1 or Mystik Hi-Temp w/ Moly for this application.
I did used to work for a distributor though which is why I would suggest those based on your needs and what the BPV actually does...
Old Nov 10, 2014 | 11:53 AM
09CobaltSS1's Avatar
I've found it's actually better to use something less viscous like synthetic motor oil more so than grease tbh. The grease tends to get more and more viscous over time and leads to sticking issues. This really goes for any plunger style bov for that matter.
As far as the stock bpv not holding boost, I'm curious as to how you came to that conclusion. By design, it's just not possible. If your stock bpv can't hold boost pressure then either the diaphragm is torn or something else is going on.
Old Nov 10, 2014 | 12:04 PM
Shanedude's Avatar
I'm wondering how the forge BPV's will fair in the winter. Especially the VTA one since it needs lubing more frequently than a BPV does.
Old Nov 10, 2014 | 12:10 PM
blueLNFftw's Avatar
Doesn't forge only make the VTA one for the Cobalts?
Old Nov 10, 2014 | 12:26 PM
Shanedude's Avatar
They've got two types. A re-circ like stock and a VTA which dump's air. Pretty sure the VTA will need re-lubing more, put 25k on it I should lube it up for the first time soon.
Old Nov 10, 2014 | 12:39 PM
blueLNFftw's Avatar
Hmmm.
I need to see what my car has.
I want VTA. If it isnt one, will I need to tune for it swapping it in?
Old Nov 10, 2014 | 01:04 PM
Shanedude's Avatar
Re-circ no tune, VTA yes tune.
VTA more of a ricer mod. I'm pretty sure the VTA decreases performance a tiny amount since the engine would rather have that readily available air. But the sound is amazing and a head turner. And I'm sure it's harder to dial in when tuning so if you're tune is way off might decrease overall engine life by tiny amount?
It might be to annoying in the winter aswell when feathering the throttle for traction. The VTA gets pretty "talkative" not sure how to say but it can be made to pssssssh very easily with only a few pounds of boost. For this reason I like it, I can show off without having to break the speed limit or tire traction.
Old Nov 10, 2014 | 01:40 PM
blueLNFftw's Avatar
I like the noises honestly. I think mine is only the regular Forge unit. I will be swapping that out or going to a BOV. Cheaper to do the Forge VTA tho I bet.
Old Nov 10, 2014 | 02:34 PM
Where you guys get the grease from or can someone post of pic of how it looks? Im not sure what to get i found a mobil1 grease but i dont think its high temp. I got a p2261 so im guessing i need to clean and re-lube it
Old Nov 10, 2014 | 08:07 PM
Is that the grease you use?
Old Nov 10, 2014 | 08:35 PM
nathan112i's Avatar
no! go get high temperature grease you car doesn't care what brand but the higher the temp the better.
Old Nov 10, 2014 | 08:40 PM
Lol thats why im asking. I saw high temp grease but its for wheel bearings and stuff like that, so im not sure what to use.
Old Nov 10, 2014 | 08:46 PM
nathan112i's Avatar
your bpv won't really care what kind of "specialty" grease is going in it. all it has to do is not break down from the heat produced from the turbo.
1)go to auto parts store
2)ask for highest temperature grease
3)????
4)profit
Old Nov 10, 2014 | 08:55 PM
Alright. What kind do you use?
Old Nov 10, 2014 | 08:58 PM
nathan112i's Avatar
a canadian brand one you probably don't get in the states, Hightemp 500F red lithium grease, use very small amounts /thread
