amount of Moble1 grease on Forge bpv
Old Nov 10, 2014 | 09:01 PM
Alright ill check to see whats higher. Also whats the best place to add the grease other than the oring
Old Nov 10, 2014 | 09:33 PM
Devin86's Avatar
Im using the moble 1 grease u posted a pic of. its works for awhile its good to like 350F it says on the side. If there somthing better let me know so i dont have to re-grease as often.
Old Nov 10, 2014 | 09:39 PM
Yeah ill let you know if i find something better. Although dony really want to get the whole tub for the amount of grease i will use. Well would a code p2261 because by the bpv needing to be relubed?
Old Nov 10, 2014 | 09:45 PM
Devin86's Avatar
Originally Posted by 09CobaltSS1
I've found it's actually better to use something less viscous like synthetic motor oil more so than grease tbh. The grease tends to get more and more viscous over time and leads to sticking issues. This really goes for any plunger style bov for that matter.
As far as the stock bpv not holding boost, I'm curious as to how you came to that conclusion. By design, it's just not possible. If your stock bpv can't hold boost pressure then either the diaphragm is torn or something else is going on.
I was getting a p0101 boost leak. Was like wtf looked nothing no cracks or loose piping. my rpd wasnt agreeing with the code and it would go limp mode like every few days till i shut the car off about 3 times. Then it made sense i got a bpv code with in 2 weeks. Im thinking the spring was just weak so it was "rolling to the side" under boost causing a p0101 at first. Then the car figured out it was the bpv. Changed it to the forge no issue since. Just a the drag strip for lack/overload of grease lol
Old Nov 10, 2014 | 09:52 PM
Devin86's Avatar
Yeah ive had it for like 4 months now used about 2 table spoons worth using it for other stuff as well lol i just picked it up reading thats what Forge says to use. I just dont get how ppl run it for 10k+ miles befor re-greasing it and i get a code 3 times in 4 months for it they must not run there car much/ hard lol But again only the drag strip where im sure its getting hot as fk.
Old Nov 10, 2014 | 10:04 PM
Well i dont have that long with it maybe 1 month and half maybe lol and i got that code so idk what to think
Old Nov 10, 2014 | 10:09 PM
Devin86's Avatar
When u take it out clean it really well dont take it off the turbo just unscrew it where the hose connects. Make sure there isnt to much grease under the orings or on the end of it. I threw a little inside it and on the plunger/orings this time and code went away by itself so it must be cycling right
Old Nov 10, 2014 | 10:16 PM
Alright nice so then all the the grease goes on the inside where the spring is pretty much huh? And how often you have grease it with the mobile1 grease
Old Nov 10, 2014 | 10:39 PM
Devin86's Avatar
No not where the spring is but the inside of the housing that stays in the turbo when u unscrew it thats what holds the spring so be carefull after that take ur finger slide the plunger out put some on the plunger/orings and some on the inside where it goes back in you will see when u take if off then slide it in a out a few times by hand then check it to see if its gunked up to much . i pretty much only re-grease it after the drags lol cuz of the codes driving around 2 months no issue till last Saturday at the strip. Being to light handed made it where off very fast o didnt put any on the inside befor this ether just the plunger so im thinking there wasnt enough to keep the heat incheck and it faded away
Old Nov 12, 2014 | 09:12 PM
Ok so i finally relubed my forged bpv on tuesday and i ended up using valvoline multipurpose grease it has a rating of 400°F. I still have to buy it tho used tge one from school
Old Nov 15, 2014 | 04:12 PM
  #36
Shanedude's Avatar
Make sure the grease is good for low temperatures too. Wouldn't want it getting stuck and the next weakest link in the system going pop.
Luckily I haven't had to re-lube my forge VTA yet. Around 15,000km on it and I'm pretty sure the VTA would go through grease faster than the BPV will.
Old Nov 15, 2014 | 05:05 PM
  #37
Yeah i gotta check what the lowest it protects.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
