another newbie question..difficult to get shifter into R
Old 01-14-2012, 06:38 PM
kevnv's Avatar
I'm wondering if the car we just bought has short throw shifter...throws are very short and its hard to get in reverse...need to push it over to the the right hard and then something clicks and then you can pull down into reverse...is this normal for stock shifter? Is it more difficult to get after market shifters into reverse?
I can do it but the wife cant get the car into reverse....
thanks
Old 01-14-2012, 06:43 PM
USA Y U NO HAVE AUTOBAHN?
tylerjclance's Avatar
Reverse lockout?
Old 01-14-2012, 06:45 PM
kevnv's Avatar
we have a couple other manual cars and this one is much harder to get into reverse...
gears 1-5 are fine
Old 01-14-2012, 06:52 PM
silverSS08's Avatar
gears 1-5 are fine
You are pulling the lever on the shifter up and then moving it all the way to the right and back. Correct?
Old 01-14-2012, 06:58 PM
1995chevy's Avatar
stock
hurst
sounds like a hurst if your having problems with reverse and 5th
Old 01-14-2012, 06:59 PM
silverSS08's Avatar
On the shifter itself there is a little button/ lever underneath the shift knob that you needs to pull up on with your 2 fingers in order to be able to shift into reverse. Hopefully this is the problem you are having.
Old 01-14-2012, 07:05 PM
kevnv's Avatar
so the stock shifter requires to pull the thing up underneath the shift knob? It works much easier now...we looked and manual and it said nothing about pulling up the shifter to get into reverse
thanks
Old 01-14-2012, 07:14 PM
kevnv's Avatar
ok..thanks all...problem solved and so we do have the stock shifter...now onto the tune mystery I posted earlier today....I think I will bring to local chevy dealer who has dyno and go from there
Old 01-14-2012, 07:16 PM
silverSS08's Avatar
thanks
Yes its called a reverse lockout. It is to prevent you from accidentally slamming it into reverse. Glad to help
css win
Old 01-14-2012, 09:03 PM
SSRich's Avatar
the first time i test drove a SS Supercharged i pulled back in and went to back the car in the spot and i sat there for about 5 minutes trying to figure it out and the salesman came over and told me about the lever.
Old 01-14-2012, 09:05 PM
AWD > FWD
TommyP's Avatar
when I first got my ss I even knew about the reverse lockout, and I still forgot to pull up on it lol.
It's something that the majority of cars are implementing these days. I'm surprised you were able to get it into reverse at all without pulling up on it.
Old 01-14-2012, 09:25 PM
nRRe's Avatar
had to get used to it, 98 passat i had to push the whole shifter down to get into reverse, this car i have to pull up on the ring. old 99 silverado had no lockout, you'd think a 4wd v8 would have a lockout
Old 01-14-2012, 09:40 PM
guitarenvy's Avatar
Yeah thats messed, and first gear in a jetta i remember was far left away from the rest, it was so confusing lol, looked like i had no idea how to drive.
Old 01-14-2012, 11:11 PM
BooSSted's Avatar
thanks
Sounds like you broke it to me
007Buff
06-11-2017 03:04 PM
biniecki
10-25-2015 02:23 PM
brett.higgins3
09-24-2015 09:51 AM
Cptnslo
09-24-2015 09:32 AM
007Buff
09-22-2015 09:48 AM
Quick Reply: another newbie question..difficult to get shifter into R
