another newbie question..difficult to get shifter into R
I'm wondering if the car we just bought has short throw shifter...throws are very short and its hard to get in reverse...need to push it over to the the right hard and then something clicks and then you can pull down into reverse...is this normal for stock shifter? Is it more difficult to get after market shifters into reverse?
I can do it but the wife cant get the car into reverse....
thanks
thanks
On the shifter itself there is a little button/ lever underneath the shift knob that you needs to pull up on with your 2 fingers in order to be able to shift into reverse. Hopefully this is the problem you are having.
so the stock shifter requires to pull the thing up underneath the shift knob? It works much easier now...we looked and manual and it said nothing about pulling up the shifter to get into reverse
thanks
thanks
ok..thanks all...problem solved and so we do have the stock shifter...now onto the tune mystery I posted earlier today....I think I will bring to local chevy dealer who has dyno and go from there
Yes its called a reverse lockout. It is to prevent you from accidentally slamming it into reverse. Glad to help
the first time i test drove a SS Supercharged i pulled back in and went to back the car in the spot and i sat there for about 5 minutes trying to figure it out and the salesman came over and told me about the lever.
had to get used to it, 98 passat i had to push the whole shifter down to get into reverse, this car i have to pull up on the ring. old 99 silverado had no lockout, you'd think a 4wd v8 would have a lockout
Yeah thats messed, and first gear in a jetta i remember was far left away from the rest, it was so confusing lol, looked like i had no idea how to drive.
thanks
thanks
