any benefits from an upper charge pipe???
Old 06-24-2012, 12:45 PM
redman2357's Avatar
Was wondering if there was any benefits of an upper charge pipe besides looks?
Old 06-24-2012, 12:53 PM
K-Train04RL's Avatar
charge pipes help spool times and air flow, but how much is not really worth it, more for looks. although im a hypocrite as i have both upper and lowerr
Old 06-24-2012, 12:54 PM
padlock's Avatar
well seeing as your tuned at 23 psi, do you like how this looks?
simple fact of the matter is plastic sucks for boost (especially for higher levels). Metal charge pipes are not only able to handle anything you throw at them, but they look awesome as well
Old 06-24-2012, 01:04 PM
redman2357's Avatar
lol damn I just actually raised boost to 24psi. Is that why your stock one blew a hole?
Old 06-24-2012, 01:06 PM
BlackARCA06's Avatar
Stock upper likes to go kaboom, my buddies did it on GMS1.
Old 06-24-2012, 01:09 PM
padlock's Avatar
thats not my personal car... but if you search "ss/tc blown/cracked charge pipe" you get images such as that one..
GM cheaply made the charge pipes (hence the plastic), which I suppose we cant blame them to keep costs low... but the downfall is bring the balt up higher than the stock 15psi makes for the charge pipes becoming a weakness in the system....
granted I did see quicker boost response when I switched my hotside out so there are other advantages more than just looks and reliability.
Old 06-24-2012, 01:15 PM
redman2357's Avatar
Makes sense, my stock one has been rattling around for quite some time now, it broke off from screw that mounts it in place at top.
Old 06-24-2012, 01:18 PM
SSlobalt's Avatar
I don't think aftermarket CP's are worth it. If my stocker ever cracks, I'll just replace it with another stocker. I've been tuned for years and had no issues.
Old 06-24-2012, 01:36 PM
redman2357's Avatar
Bump 4 more opinions
Old 06-24-2012, 01:50 PM
09BlueBaltSS's Avatar
Its mainly for reliability, the performance gains are minor. This is my car
Duck tape mod FTW
Old 06-24-2012, 03:17 PM
ei3dag3's Avatar
was expecting you to post in here. ya beat me to it. :p
i still have my stock hot side, but honestly I just prefer the look of my engine bay without the plastic. i didn't really notice any performance increase or anything. i also never had an issue with running the stock hotside for 1.5 years. it still hasn't cracked.
Old 06-24-2012, 04:04 PM
redman2357's Avatar
Ok, sounds like there won't be much benefit for the charge pipe I've been running the stock one for 2 yrs. Have not had a problem with it other than the bracket that holds it in place. If there is no performance gain than I don't think it will be worth buying.
Old 06-24-2012, 04:23 PM
Got Brakes?
Sox-Fan's Avatar
It likely doesn't get cold enough in Dallas to make the plastic really brittle, but heat cycling and age will still take a toll. You might not pop that thing today @25psi. Might not tomorrow. But it'll eventually happen to you. You should keep your eye on the used parts forum and pick one up for cheap when you can.
Old 06-24-2012, 04:26 PM
padlock's Avatar
^this
I was also going to say that about the temp swings... when it gets as cold as -20 up here in the winter, the plastic isnt exactly as strong at that temp as it normally is at say 50 degrees.. temp swings play a big part in it, so I guess if your in a consistently warm climate your charge pipes may not be effected as much
with that even said, just because your in a warm climate doesnt make you safe from this happening
Old 06-24-2012, 04:31 PM
Rick Bragstad's Avatar
Plastic charge pipe = FAIL
Old 06-24-2012, 04:45 PM
redman2357's Avatar
Yea the temp usually only gets to about 30 degrees at the lowest in winter time and that's only for about a week out of the year. But ill keep an eye out for a used one.
Old 06-24-2012, 06:38 PM
lilskarvcx's Avatar
Is it harmful to run the car with a cracked/broken charge pipe?
Old 06-24-2012, 06:59 PM
Throws the fuel trims all over the place
Old 06-24-2012, 07:58 PM
Got Brakes?
Sox-Fan's Avatar
all the boost goes out the hole?
Old 06-24-2012, 08:07 PM
m33pm33p's Avatar
grab your charge pipe after a few "hot laps" at full throttle on the highway and tell me it ain't hot.
if you look at a cross section of the plastic piece you can see it restricts flow as well compared to a tube one.
Old 06-24-2012, 08:15 PM
SSSnoop's Avatar
Damn, man. I'm going outside right now to duct-tape my upper, just in case!!
Also, if I get that "flame" pattern duct tape, I'm thinking I can dress up my engine compartment a little....
Old 06-24-2012, 08:44 PM
Cobalt_Daddy's Avatar
meh isn't the charge pipe covered under warranty as it could be considered part of the engine or drivetrain?
Old 06-24-2012, 08:51 PM
Got Brakes?
Sox-Fan's Avatar
25 pounds of boost blows it out I bet it isn't going to be warrantied.
Old 06-24-2012, 08:55 PM
well obviously... i was moreso refering to the fella that blew his up on GMS1 only
but yes for the guys running custom tunes. charge pipes and new intercooler are almost a given. plastic sucks
that being said i think alot of people forget plastic gets brittle in cold and im sure some of those people have made full boost in cold weather conditions when they probably shouldn't have.
Old 06-24-2012, 09:43 PM
nobody2u's Avatar
No performance gains to be found with aftermarket charge pipes. But yeah, it is possible, but quite unlikely to blow it.
Quick Reply: any benefits from an upper charge pipe???
