any benefits from an upper charge pipe???
Pretty much 1. Much faster spool. 2. Louder spooling. 3. The ability to add a bov. If you dont want a bov then i dont think it would be worth it. I wanted a bov...so i got one lol
This isn't necessarily true. It's flatter in one spot, but also wider. I would be the volume is the same.
If you are on the stock turbo it doesn't really help you. You'll be fine on the stock charge pipes. Like it was said above if you don't have the clamp attaching the pipe to the block then you need to look into it, but if it was changed under the recall you'll be fine. I havent heard of anybody recently blowing one.
#36
#38
My stock plastic charge pipe was broken where the screw holds it to the engine when I bought it new, stock tune, stock boost, off the lot!!! I didn't even bother with warranty and bought an upper charge pipe, my first mod. To each his own, but when I bought the Injen upper charge pipe I definitely noticed the quicker spool. Advantages; as said. Disadvantages; higher engine compartment temps, but you can wrap it with header wrap. I.M.O. it was well worth it.......
