any benefits from an upper charge pipe???
Old 06-24-2012, 10:06 PM
TurboTechRacing's Avatar
Top is the one that NEEDS to be upgraded. #1 they blow apart, and #2 the flow is horrable on the top one. The lower one not so much needed as flow is pretty good.
Old 06-25-2012, 01:03 AM
roadrunner132's Avatar
Pretty much 1. Much faster spool. 2. Louder spooling. 3. The ability to add a bov. If you dont want a bov then i dont think it would be worth it. I wanted a bov...so i got one lol
Old 06-25-2012, 01:05 AM
I really dont think the stock pipes usually break. Im pretty sure all the ones that break are in severe cold
Old 06-25-2012, 04:51 AM
redman2357's Avatar
Yea think I'll do do the duck tape mod for now, and keep an eye out for one in the classifieds
Old 06-25-2012, 06:40 AM
SSlobalt's Avatar
Originally Posted by m33pm33p
grab your charge pipe after a few "hot laps" at full throttle on the highway and tell me it ain't hot.
if you look at a cross section of the plastic piece you can see it restricts flow as well compared to a tube one.
This isn't necessarily true. It's flatter in one spot, but also wider. I would be the volume is the same.
Old 06-25-2012, 10:00 AM
ei3dag3's Avatar
i agree with this.
not to mention my car pulled just as hard with charge piping or not.
Old 06-25-2012, 12:13 PM
09BlueBaltSS's Avatar
It was about 80* when mine decided to peace out so Idk if that's accurate
Old 06-25-2012, 12:47 PM
Wangspeed's Avatar
All those pictures are old. Show me one where the stock upper pipe was properly secured, but still blew.
Old 06-25-2012, 12:52 PM
xChase's Avatar
So much conflicting information my head is going to explode.
I guess I'll just wait until mine explodes.
Old 06-25-2012, 01:07 PM
nobody2u's Avatar
If you are on the stock turbo it doesn't really help you. You'll be fine on the stock charge pipes. Like it was said above if you don't have the clamp attaching the pipe to the block then you need to look into it, but if it was changed under the recall you'll be fine. I havent heard of anybody recently blowing one.
Old 06-25-2012, 01:11 PM
  #36
It looks like your tuned what pressure are you pushing?
Old 06-25-2012, 02:45 PM
  #37
emiller's Avatar
Stock is plastic because its better for heat. Metal transfers heat really well.
Old 06-25-2012, 09:14 PM
  #38
SSlobalt's Avatar
yeah, it doesn't dissapate heat for ****. Anyone got any carbon fiber charge pipes?
Old 06-25-2012, 10:29 PM
  #39
06 GM CobaltSS's Avatar
My stock plastic charge pipe was broken where the screw holds it to the engine when I bought it new, stock tune, stock boost, off the lot!!! I didn't even bother with warranty and bought an upper charge pipe, my first mod. To each his own, but when I bought the Injen upper charge pipe I definitely noticed the quicker spool. Advantages; as said. Disadvantages; higher engine compartment temps, but you can wrap it with header wrap. I.M.O. it was well worth it.......
05-28-2022 03:47 AM
01-12-2016 12:01 AM
717ssbalt
10-02-2015 04:01 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: any benefits from an upper charge pipe???
