best 0-60 tire for TC's
Old Dec 15, 2014 | 07:29 PM
63 Nova SS's Avatar
Originally Posted by mikeluis92
I'm on my stock sensors bt my tuner says he's reading all my sensors fine that isn't the problem... I'm on full e85 .. I'm going to have to check ic piping and ic co re ..
I thought stock sensors would only go to 22-23 psi? What kind of dyno did you run on?
Old Dec 15, 2014 | 08:59 PM
Terminator2's Avatar
He should know from the logs if you have a boost leak or not. Any good tuner can spot a boost leak from a mile away.
Old Dec 15, 2014 | 11:27 PM
KMO43's Avatar
If your fueling is fine, and you are dyno'ing on a dynojet you should be around 370-385 I would guess on e85. I am going to try and do e47 in the spring if traction is better. Sure you have 3 bar map sensors?
I'm either doing nitto nt05's, 01's, or direzza star spec 2's.
I had nt05s really liked them, this spring I'm getting NT01s cause I'm getting a smoking deal on them
Old Dec 16, 2014 | 01:10 AM
mikeluis92's Avatar
nah on dyno wouldnt go higher than 22 and yeh he told me its a leak somewhere im guessing a coupling in ic or the intercooler itself may be cracked. im on stock sensors and in the street off the dyno it spikes 24 psi, i asked about the sensors told me he is reading them fine so that isnt my problem and they arent blown, we unpluged electronic boost controller and had open wastegate for it to spike boost floored the car and it didn;t go past 22 - 23 psi, should be way up there, and should i go up in tire size? im still on stock tire size got some bf good rich sport comp2
Old Dec 16, 2014 | 01:15 AM
mikeluis92's Avatar
dyno was a dynojet
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
