blew map sensor ??'s
I blew my MAP sensor, but have a tune/intake/exhaust.. is it worth it to try to get it replaced under warranty or do you think i'll just be better off eating the cost of a new one? I'm not really interested in the stage kit right now btw.
i'll flash it to stock, i'm trying to make an appt with the dealership. in the DTC thing on hptuners it's throwing the map sensor low voltage code, and it's not logging boost or map pressure anymore. i logged a run with it not working, and my VE airflow shot up to 67lbs/min when i punched it lol. is it ok to drive with this sensor blown? the sensor is about $90 or so from the dealership, i can get it cheaper online, but i don't feel like waiting that long when they can have it by tomorrow.
i don't wanna spend the $$ on the stage kit yet, i want to wait till spring if i can.
Last edited by oopsitouchedmyself; Nov 16, 2009 at 04:03 PM. Reason: Automerged Doublepost
that's what i said. lol idk if the MAP sensor not working is making that read incorrectly or what, the MAF was reading 23-24 at that point, i just floored it for a second then let off.
is it ok to drive the car with this sensor blown? it's my only vehicle right now.
Last edited by oopsitouchedmyself; Nov 16, 2009 at 04:14 PM. Reason: Automerged Doublepost
The MAP must be used for helping the ECU calculate VE, and if I remember right I read a while back that this might actually be the case.
Not true. Im running 30psi and have been for almost 10K miles now. Same original map sensor still. So thats not true..
i don't have an rpd. i do have a CEL though, can't remember the code(it said something about low or no voltage from map sensor), no limp mode, but it was misfiring at first when i started it up, coulda been the tune i just adjusted/loaded though. idk. it doesn't log any reading from teh map since that CEL came on either. i have an apt. today with the dealership, we'll see.
Fail. Unless your swappin turbos the stock maps fine. the reason for the 3 bar is basically for diagnostic compliancy..
that's the reason i went for warranty, the fact that ppl are blowing these sensors on bone stock cars didn't make me feel bad about going in for warranty with a car that had been tuned. it only took the 4 1/2 hours to figure it out though.. they tried telling me the sensor was bad cause of my intake, and the fact that the hahn intake stretched the wires to the sensor. i told them they were looking at the wrong sensor....lol trained professionals here.
i think that may have been my problem. everytime i adjust my tune and load it the idle is funny for a few seconds, it was real funny this time, though, started misfiring and stuff then the code for the map came on. idk if it was something i did or what..
I just blew my second one. I actually have the replacement in my lap right now. Im boosting about 24-25lbs (vacuum tank delete) and it only pops when im hard on it. Other than that it was good before i took out the vacuum tank which is going back in this weekend.
I took mine in to the dealer this morning and just heard back from them. They said my map was fine and the problem lies in the computer, so they are replacing that. I wonder if that will be the fix.
