blew map sensor ??'s
Old Nov 24, 2009 | 11:40 AM
08turbaltscott's Avatar
Originally Posted by drewbroo
I just blew another within 2 weeks of getting one installed. It happens at cold start. THe engine idles funny for a second, then bam, blown map sensor. It has nothing to do with boost levels. It has happend this way both times. I hope they get a goodone in there next friday.
I've blown three MAP sensors and the dealership tried to blame me for all three of them. at the time i had no aftermarket performance parts. They said that me driving the car 4500 rpms, at 47 mph, and 100% throttle is what caused it. The code always came up when i started my car, this is because the car can take up to three times starting before the computer reads that the sensor is actually out. They ended up warranting my car after i theathened to take them to court beacause other than knowing how fast i was going they couldn't prove that it actually caused the sensor to blow.. I now have the stage kit (which is very worth it) and have had no other problems.
Old Nov 24, 2009 | 02:17 PM
RBC's Avatar
RBC
The dealer just got back to me and guess what? The map sensors is BAD! Now they are saying the map went, and when it went it took out the sensor signal from the computer
Old Dec 1, 2009 | 11:20 AM
Jaxon's Avatar
I have a hhr with a blown map sensor also. The dealer told me they needed to order a new ecm, guess this is what happened to mine also. I've even used write entire with the stock tune, with a new map in the manifold. Guess I just have to wait on the dealer to let me know when whatever gets in, then they'll have to get a new map too I'm sure.
Old Dec 1, 2009 | 04:37 PM
oopsitouchedmyself's Avatar
Originally Posted by RBC
I took mine in to the dealer this morning and just heard back from them. They said my map was fine and the problem lies in the computer, so they are replacing that. I wonder if that will be the fix.
the dealers service manual thing has something in that that says not matter what the MAP testing reads, replace ECM. it's a GM typo. the tech who replaced mine showed me the troubleshooting printout from GM, and we both agreed on the typo. he then called GM and they acknowledged it was a typo. so when they say it's the ECM tell them to call GM and get it straight, cause it's the MAP sensor.
Old May 30, 2012 | 01:58 PM
j_potter13's Avatar
I have 09 cobalt ss and it threw U0073, p0010,p0101, p0300 and p0304. Im not getting any boost at all and car is running like ****. Smells like its dumping to much fuel. I replace MAF sensor. Any other idea's? could this be a MAP? Im running 23 lbs boost
Old May 30, 2012 | 07:34 PM
SSlobalt's Avatar
You're not running 23 lbs anymore. Now you're running five and you have a giant boost leak. See my sig for details on how to run a boost leak test. If you're on the stock IC, you likely cracked it after letting off WOT at 23psi. Did you hear a "pssshhhh!?"
Old May 30, 2012 | 10:15 PM
j_potter13's Avatar
Yeah u r right. My boost gauge shows no boost at all. And yes it was right after letting off and heard a big psssshhhh..... thanks for the help
Old May 30, 2012 | 11:32 PM
SSlobalt's Avatar
ZZP IC's are the shiznit.
Old May 31, 2012 | 12:05 AM
j_potter13's Avatar
Mine is under warranty and at dealership right now. They were thinking maf or map sensor. I'm going to call in the morning and suggest ic. Wish they would put aftermarket one in but don't see that happening.
Old May 31, 2012 | 12:11 AM
Stamina's Avatar
My dealer was cool with me going aftermarket when my stock one blew.
They basically informed me that an aftermarket IC wouldn't be covered under a warranty, since it isn't their IC. I was like "That's fine. That makes sense.", and they installed the IC I supplied without any issues with it. I'm summarizing a lot, but those are the main points. It basically boils down to the dealer. Some are okay with things like that, and some aren't.
Old May 31, 2012 | 11:23 AM
  #36
Chevrolet Cust Svc's Avatar
How's everything going with the dealership, j_potter13?
Looking forward to an update!
Sarah
GM Customer Service
Old Jun 5, 2012 | 09:51 PM
  #37
j_potter13's Avatar
Well my car has been at the dealership for a week and a half. I suggested that they test the intercooler and see if it is messed up. They said it was just fine. Today they told me they think that it is the internal fuel pump that is draining fuel into my crank case. I will know in the morning if it fixed the problem or not. I dont know that this will fix the issue I was having of no boost and the codes I threw. We will see. I will update
Old Jun 7, 2012 | 02:39 PM
  #38
SSlobalt's Avatar
buncha morons.
Old Jun 12, 2012 | 11:31 AM
  #39
j_potter13's Avatar
UPDATE- My car is still at the dealership. They have tested the intercooler, replaced map, maf, internal fuel pump, PCM, and still do no have it fixed. Yesterday they said they were on the phone with GM tech support but last time I had talked to them they still havent figured anything out. This is getting rediculous. I had the car 2 weeks exactly before this happened. They have had my car for 2 and a half weeks now.
Old Jun 12, 2012 | 03:59 PM
  #40
j_potter13,
If you would like for me to set up a case in my department and contact the dealership to follow up on the progress of the vehicle, please send me the following information in a private message here on the forum:
Your name, phone, and address
The last 8 of your VIN and current mileage
the name of your dealership
All the best,
Sarah
GM Customer Service
Old Jun 17, 2012 | 07:54 PM
  #41
j_potter13's Avatar
haha. Well after 3 weeks of me telling the dealership that it was the intercooler.... I get my car back yesterday and it was the intercooler.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
