Bnr k04-gt28
Old Apr 18, 2011 | 03:41 PM
  #1376
cubaniche's Avatar
Yeah, Im sorry. I just thought that Id at least hit 330 and hold it there throught the powerband. Im on E. Running 93 would mean Id have to lower timing to avoid KR which in turn woul dmean a loss in HP. So if I dynod the 2860 on my car with 93 Id probably only dyno like 285 or some crap like that. Anyways......just not what I was expecting is all.
Old Apr 18, 2011 | 04:08 PM
  #1377
drewbroo's Avatar
Originally Posted by BYT*SS*TURBO
That's because they look like the graph's from a Excel Spreadsheet..
http://www.solstice forum.com/forum/f101/2871-turbo-upgrade-2-0l-now-available-67524/
Hey now! It was dyno'd on one of microsofts new dynos! (Yeah in no way does that look like anything that winpep or mustang dyno software.)
Old Apr 18, 2011 | 05:15 PM
  #1378
iboost's Avatar
Originally Posted by Supercharged Guy
That's what I wanna know....I think iboost will have #'s fairly soon
Hopefully soon. Im having some issues with my car that I can't figure out. So I'm taking it to GM to fix. Then I have to retune for the humidity here and I'll throw it on a dyno. Turbo swap, retune and dyno again. I want my car at 100% before and after before I post numbers
Old Apr 18, 2011 | 05:23 PM
  #1379
elecblue06's Avatar
they have posted other dynos that look normal i think that was just graphed out for comparisons sake
Old Apr 18, 2011 | 05:33 PM
  #1380
vahdyx's Avatar
Originally Posted by Sweetsandman
Where's that part from?
I just spoke with him, he said the Dynocom read right so this negates everything I said about 50whp added.
Well guys. This upgrade seems to not be worth it
I just dynod on a DYNOCOM. Running the E blend and about 19* of WOT timing at 22psi I only made 305whp LOL
Im given to understand that the DYNOCOM is sorta like the mustang dyno and reads low. Even if that was true and you add the 15% or so its still only about 345whp which is not worth the $1000 pricetag of the 2860. Ive heard of similar experiences with this turbo and even the 2871 not making what it should. The TQ and power is held throughout the powerband unlike the k04 wich seems to peak and fall off. Still, dont know if that is worth the price. Needless to say, I am very dissapointed and bummed out. The car feels great on the street. It def doesnt feel like a 300whp car but thats what the dyno is saying. Oh well.
Comments, flames and suggestions welcomed LOL
Then someone asked... do you have the numbers before the BNR
I dont. (which I assumed he meant he doesn't have the dyno numbers) The only other time I dynod there I wasnt able to get the chart. THey were supposed to e-mail it to me. Anyways, I put down 290whp on 93, 22psi, and only 13* of WOT timing.
So I assumed before he put on the BNR he was 290 and ended up 305 which is 15% lower which ended up being a 345whp. Taking these statements I assumed it was about a 50whp gain.
But I was wrong so my comments aren't valid.
I have spent 300.00 in mods for a 90-100WHP increase. Thats 3.00 a hp on a stock K04....
Also E85 BYT tune and AB mod dropped my ET from a 14.2@103MPH to a 12.94@112. sooooo thats 33.00 a MPH in the 1/4 and 230.00 per second dropped in the 1/4. Also another sedan here has the 2871 upgrade and ran the EXACT et as me with a 117 MPH trap. (He was also at 1K ft, and I race at 3200 ft at SIR.)
its just not worth it to me.
How did you spend $300.00 in mods for 90-100whp gains. I did something wrong then. My downpipe with spun cat was $280 alone. Trifecta was $350 so I'm already way above you and that's only supposed to get me what around 50whp . I dyno'd stock at 232whp and from what I understand is a catless downpipe adds 15whp and trifecta is around 40whp
Old Apr 18, 2011 | 06:41 PM
  #1381
cubaniche's Avatar
LOL
Look if you guys consider the increase in HP your getting worth the 1300 the 2871 costs and the 1000 the 2860 costs then by all means DO IT. I dont care one way or another. Its your money. I was just posting my numbers. Something only one other person has done. The 2871 was originally thought to put down at least 370. I mean, if a RWD solstice put down 320whp with their drivetrain losses on a 2860 then I though FOR SURE the cobalt would put down more. Not the case. Since I havent seen a 2871 dyno yet then I assume that the numbers werent really all that great. Even if it put down 350 I wouldnt consider the 2871 worth it because you can get damn close to that with the stock turbo.
Me personally, as I have stated before, was hoping to put down at least at the very minimum 330whp. Its not a coinsidence that two 2860s have put down exactly the same amount of power down on a dyno. Something is definitely not right with the 2860.
HHRSSouth-You even said yourself in this thread and others that you believe the 2860 to be 'choking'. And the comment about the 2871 not making what it should was exactly that. Your happy with your gain, yes, but its obviously not what you had hoped for I assume. DDMworks advertises the 2871 on the solstice to make 360+whp. Thats on a RWD drive chassis with RWD losses. Surely the LNF cobalt can put down more, or at least thats what we all thought....???
To adress Vahdyx's comment. When I dynod I was told that it was sorta like a mustang and it read low. After I posted that comment Term2 and some others corrected that thought by informing me that the dynocoms generally read 6% higher than the dynojet. So, my original assumption of adding 15% to the 305 that I put down, WAS WRONG. This is why you have to READ through everything before posting so you are up to date on whats been said. Oh and, YES I put down 290 on a 22psi tune on 93 octane on a dynojet. So, to put down 305 on this slightly bigger turbo at 22psi, E and more timing advance, is VERY dissapointing to me.
So, AGAIN, I stick with what I originally said. Do I consider the 2860 worth the cost? NO. Thats MY opinion. Am I happy with what I dyno'd? No but, I like the fact that my powerband is held to 7k and that I picked up quite a bit of midrange and it holds. Maybe, once we see numbers, we will find out if the 2871 is actually worth it or not.
Old Apr 18, 2011 | 07:02 PM
  #1382
vahdyx's Avatar
cubaniche I understand this you pm'd me remember this is why i retracted my statement earlier.
Old Apr 18, 2011 | 07:18 PM
  #1383
cubaniche's Avatar
I know. Im just re-iterrating it for others so they dont think its something new that I posted or anything LOL
Old Apr 18, 2011 | 08:11 PM
  #1384
drewbroo's Avatar
E85 BYT Tune + ZZP AB Mod = less than 300.00
a 14.2@103MPH at 3200 feet vs. a 12.9@112 at 3200ft = AT LEAST a 90-100WHP gain.
It doesn't matter how many mods you have on me, it doesn't mean you are faster Its all in the tuning and the stability of the parts installed.
See video below. The evo racing me has MANY MORE mods and AWD, and I still take the win.
http://www.youtube.com/watch?v=73EVa...ature=youtu.be
Usually about 10WHP is gained per MPH you go up is proper ricer math
Old Apr 18, 2011 | 10:17 PM
  #1385
JBThrasher22's Avatar
YouTube - My 2009 Cobalt SS Sedan 12.9@112MPH vs EVO X
Didn't someone post up a 117 trap speed with a 2871? Can't remember I'm on my phone and maybe a little intoxicated lol but I thought so and if so then a 117 trap car should by ricer calculations be much faster then a 112 trap speed car.
Dunno if the BNR upgrades are worth it for the LNF platform to each his own for some people it might be, not me I will probably go a different route keeping my eye on the EFR turbo's ZZP are working on.
Old Apr 18, 2011 | 10:29 PM
  #1386
drewbroo's Avatar
He got a 117MPH trap with a 2.3 60ft. @ 1000 ft of elevation (BNR2871 fully bolted)
I got the exact same ET (2.2 60 ft.) with a STOCK TURBO and just E85 tune and airbox mod @ 3200 Ft with CALC DA of 5600+ft. (In my sedan, on crappy hankook ventus V4's)
Also in my coupe I Trapped 116.4 with the E85 50/50 mix and stock turbo. (Also done at 3200 Ft.)
I am not going to say this turbo is worth it till I see a 120+ Trap with an 11 sec pass.
I am also pretty sure in my sedan I can trap close to that up at phoenix where the BNR 2871 car ran.
Old Apr 18, 2011 | 10:57 PM
  #1387
drewbroo's Avatar
Originally Posted by HHRSSouth
So what happens if/when those 2871 guys can run E85 on there turbos?
Then I hope they can break a 120 trap.... The synapse stage 3 ran 422WHP down here on 91 Oct.... And hardly any timing. You will only be able to run E85 on that though with either a mix or a dual feed rail.
Old Apr 18, 2011 | 11:06 PM
  #1388
drewbroo's Avatar
Dude is trapping 117mph in AZ with a 2871 and you don't think E85 will push the 2871 past that, come on man.
Its at firebird raceway.... its actually one of the best places to run on the west side of the US. Also quite a few trap records have been set there. I am 1.5 hours away from there, and run 2-3 MPH faster just by going to that track. (Just have not have had time to go there recently)
I am running out of fuel on a stock turbo on E85, what do you think the 2871 will do?
Old Apr 18, 2011 | 11:32 PM
  #1389
drewbroo's Avatar
You missed the if/when in my post about E85 and the 2871.
I know its not possible now (already asked Vince about E85 + 2871) but it might be some day.
get a dual feed rail and more fuel pressure and 120+ traps and 450+WHP will be possible with the turbo on E85.
ZZP has already done 400WHP and 500Ftlbs on the stock turbo.
Old Apr 18, 2011 | 11:39 PM
  #1390
BlackBeast!'s Avatar
Tyler the guy here with the 2871 is also on a conservative tune remember that drew he can trap over 120 easy without e85 hes only running like 23 or 24psi
Old Apr 18, 2011 | 11:46 PM
  #1391
vahdyx's Avatar
Drewbroo, you got 100whp from a tune, E85 and airbox mod? That's nuts. I think I'd be closer to 100whp if I lived 2500 ft lower. Also with E85 I can add a few more whp correct, but unfortunately I would have too many starting issues because it's always below 40*F at night here and winter is worse.
But you're a smart one, I wouldn't have ever thought of doing so much for so little. I figured bolt ons and tune were the only way to increase large amounts of whp.
Kudos to you man.
So what are the benefits of the BNR2860? Is there any?
Old Apr 18, 2011 | 11:55 PM
  #1392
drewbroo's Avatar
I wasn't gonna throw his name out there till he ran a better time mister!
Can trap and trapping are 2 different things. I CAN trap 118-119 in my coupe, but I CANT get enough traction to get there
Old Apr 18, 2011 | 11:56 PM
  #1393
drewbroo's Avatar
Kudos to you man.
I didn't do it all myself, I was just a guinea pig for a BYT E85 tune, all credit goes to him for getting ***** deep into the HPT Tables. All I did was play with the tq management and redline settings, and drove.
Old Apr 19, 2011 | 12:08 AM
  #1394
T-Man's Avatar
Shhh Drew; Sedans are slow, E blending isn't worth it, modded airbox is garbage!!!11 YOU NEED HAHN!!!!111 and you just don't know what you're talking about.....
/sarcasm off
Highly disappointed with the performance being shown here... Hopefully the 2871 steps up to the plate.
Old Apr 19, 2011 | 12:12 AM
  #1395
Of course but the argument is, is it worth buying and im just saying dont go off of his runs because its not where it could be. I agree 100% with you but thats his dd still on stock clutch and motor he's doesnt want to push it hard as he can it still has some left in the tank
Old Apr 19, 2011 | 12:15 AM
  #1396
/sarcasm off
You drew and tyler hold it down for sedans haha on the dyno day your numbers were beautiful for a stock car i wonder what drews will put down
Old Apr 19, 2011 | 12:20 AM
  #1397
drewbroo's Avatar
im still amazed that his clutch hasn't blown into 1000 peices, but this just means he has tq where he needs it.
Old Apr 19, 2011 | 12:23 AM
  #1398
Yeah me too we gotta get him to the dyno but i think i finally experienced clutch slippage for the first time last night and i still have to get you and vince a log
Old Apr 19, 2011 | 12:26 AM
  #1399
drewbroo's Avatar
I take it its slippage going into 3rd at about 3.5-4.5K rpms? I can ask vince to bring the boost on later in 3rd for you and it will save your clutch.
Old Apr 19, 2011 | 12:27 AM
  #1400
T-Man's Avatar
Hah, thanks man. Appreciate it.
Absolutely... No dreaded OMGWTFBBQAPPLESAUCE instant torque hit like the KO4.
Ask Vince to smooth out power delivery. I'll PM you on some other easy fixes so that we aren't mucking up the thread any further.
