Bnr k04-gt28
Old Apr 19, 2011 | 12:37 AM
  #1401
BlackBeast!'s Avatar
Originally Posted by T-Man
Hah, thanks man. Appreciate it.
Absolutely... No dreaded OMGWTFBBQAPPLESAUCE instant torque hit like the KO4.
Ask Vince to smooth out power delivery. I'll PM you on some other easy fixes so that we aren't mucking up the thread any further.
Lol ok cool
Old Apr 19, 2011 | 09:47 AM
  #1402
turbo_chevy_cobalt's Avatar
Some one buy me some good tires then maybe i can run my bnr2871 at the track. Soon to have a new dd so i can push the cobalt.
Old Apr 19, 2011 | 09:50 AM
  #1403
cubaniche's Avatar
Originally Posted by HHRSSouth
I know its not possible now (already asked Vince about E85 + 2871) but it might be some day.
Hey, have you asked him if an E blend on the 2871 is possible or was that out of the question too?
Old Apr 19, 2011 | 10:02 AM
  #1404
BYT*SS*TURBO's Avatar
We are running it on TGlems car with 2871, 1:1 E and bolted.
Old Apr 19, 2011 | 10:08 AM
  #1405
cubaniche's Avatar
Nice. I thought you could run the blend and get away with it with some creative tuning
Old Apr 19, 2011 | 10:29 AM
  #1406
Terminator2's Avatar
I have had cars run into the fueling limit on the stock turbo and E-47 at 24 psi and my own car on 93 octane gas at 0.80 lambda (still leaner A/F than 0.88 lambda and E-47) and 26psi ( 16* of timing 320-330* injection angle) rail pressure at 5K dropped from a commanded 2200psi to 1500psi.
Old Apr 19, 2011 | 10:34 AM
  #1407
Injector Constant is a WIN. I have my car running 26psi with FULL E85 right now and have no more pressure drop issues. Drew is also running a full E85 tune now without issue.
Old Apr 19, 2011 | 11:57 AM
  #1408
Wont work on gasoline though.
Old Apr 19, 2011 | 12:03 PM
  #1409
You just said 1:1 blend lol. I haven't had any issue on regular gas no matter the setup. In fact, the only real problems were when going to full E. Haven't had an issue on a Blend car.
Old Apr 19, 2011 | 12:10 PM
  #1410
Last week I did it to my car on gas 26 psi holding, 35 lbs/min VE, 0.80 PE lambda to keep knock away (too rich I know LOL but still leaner than e-47 and 0.88 lambda actually) and 16* max timing I maxed the pump out at about 4K-4500 IDC went to 34% IPW was over 9ms pressure dropped from 2200 psi commanded to 1500 psi at the rail. Car bogged and popped once when it happened.
Old Apr 19, 2011 | 12:14 PM
  #1411
That shouldn't happen!
Old Apr 19, 2011 | 12:30 PM
  #1412
It did though LOL. I turned the boost back to 24 flat (235-240 DAL) 14* timing and 0.88 PE lambda. I have a hybrid 09 regular OS with the 3 bar map settings so I can actually see 90-100% WG dc unlike the stage 1 09 file I had in the car before. Airload curve which normally mimics the torque curve looks so much flatter seeing 225 airload at 6400 vs 190-195 before and I have the WG rod back to stock now on the car as well.
Old Apr 19, 2011 | 01:01 PM
  #1413
I would ramp up the fuel pressure slower. It doesn't need to hold 2200 or greater flat to have enough fuel in there
Old Apr 19, 2011 | 02:45 PM
  #1414
Meh stock is 2176 psi. 2200 flat is not much higher.
Old Apr 19, 2011 | 02:47 PM
  #1415
Im not saying that's too high, Im saying it doesn't need 2200 lower in the RPM range
Old Apr 19, 2011 | 02:49 PM
  #1416
Yeah the HPFP is not very efficient in the lower revs it cannot pump fast enough. We need a different lobe spec for the HPFP that would help with fuel delivery if we could have it pump faster than stock. Maybe ZZP will build cams with a revised lobe for the HPFP.
Old Apr 19, 2011 | 03:50 PM
  #1417
cubaniche's Avatar
This is a little off topic but have you or Nick tuned a TC with the new ZZP cams yet?
Old Apr 19, 2011 | 03:54 PM
  #1418
Nope.
Old Apr 19, 2011 | 05:59 PM
  #1419
Matt M's Avatar
lol, who's your spy?
Old Apr 19, 2011 | 06:52 PM
  #1420
Iam Broke's Avatar
Great minds think alike is all.
Old Apr 19, 2011 | 06:57 PM
  #1421
cubaniche's Avatar
LOL Oh boy. Fingers crossed!
Old Apr 19, 2011 | 07:30 PM
  #1422
drewbroo's Avatar
I have 2 90% hankook V4's and 1 90% Conti if you want them 150.00 for all 3
will include new valve stems
Old Apr 19, 2011 | 08:18 PM
  #1423
HHRSSouth's Avatar
I will definetly buy this, can't wait to see the results.
Old Apr 19, 2011 | 10:53 PM
  #1424
I needs slicks lol
Old Apr 19, 2011 | 10:56 PM
  #1425
What psi is he running?
