Bonestock Dyno vs Stage 1 Dyno with pics and vids
Old Mar 10, 2010 | 09:24 PM
lifeguard15's Avatar
The bone stock dyno apparently didn't have torque sensors hooked up right so I didn't get a reading on stock torque. Crappy, I know. Should I use 237 as my stock torque, or +/- some ft-lbs for a more accurate baseline?
Bone stock (same run, different graphs. 3rd gear):
mph graph
rpm graph
Video - http://www.youtube.com/watch?v=_Vs_0Pu3ZwU
Stage 1:
4th gear
3rd gear
Video - http://www.youtube.com/watch?v=hZomwHs5rjw
So... From 237whp to 255/257whp. And ??ft-lbs to 289ft-lbs. That is with NO hardware modifications beyond the sensors that came with the GM Stage 1 Tune.
I know the pics came out kinda big. Let me know if I should post anything else up. Sorry about not having a stock torque reading, first time to dyno and I didn't realize they had messed up until after the car was unstrapped and I getting my print off. I also don't know why the RPMs are so off on that second graph.
Old Mar 11, 2010 | 12:12 AM
tom.g's Avatar
Good stuff man.
Seems like a stingy dyno, you only gained 18WHP that doesn't seem quite right.
Old Mar 11, 2010 | 12:16 AM
SSlobalt's Avatar
I'm putting less and less stock in dynos. There are just so many different factors and variables.
Old Mar 11, 2010 | 01:58 AM
Originally Posted by tom.g
Good stuff man.
Same dyno for all runs. Very close on humidity (9-12%) excluding the one run in 71% humidity, but probably around 20 degrees cooler during the Stage 1 runs.
The quoted additional power for Stage 1 was 20hp and 60ft-lbs at the crank, so for me to gain 18hp and 40-50lb-ft at the wheels seems believable. Better than I could've hoped for. Plus the cars that I've raced locally have allowed me to see what a difference Stage 1 makes.
Old Mar 11, 2010 | 02:06 AM
pookie025's Avatar
wow absolutely terrible infiniboost ftw!!!
Old Mar 11, 2010 | 02:22 AM
I purchased Stage 1 for the sensors and peace of mind if I need to go into the dealer for work, not to compete with Trifecta numbers (not that anybody with a Trifecta tune has had problems yet with having work done). Trifecta is on my future mod list, and then I'll compare those numbers to Stage 1 and Stock numbers, all on the same dyno.
Oh and if anybody knows Vince, ask him to check his PMs please. I sent him a message over a week ago.
Old Mar 11, 2010 | 02:25 AM
09BlueBaltSS's Avatar
Those curves suggest that its getting choked out up top. Next mod=catless down pipe. Redyno and see how those change. Hot side charge pipe will help a little as well
Old Mar 11, 2010 | 02:32 AM
sundevil07's Avatar
Very organized post, thanks. Just what the forum needs more of
Old Mar 11, 2010 | 02:46 AM
Your taunting the haters
Old Mar 11, 2010 | 07:09 AM
boosted4dr's Avatar
That doesnt make sense in all honesty...being HP is caluated by knowing the torque of the engine. Are you sure thats your not torque line instead of the HP line? All a dyno measures is torque and rpm, then it figures out the HP using the formula below
HP=torque*rpm/5252
Knowing this I do not understand how a dyno could pick up HP but NOT pick up torque.
Other then that looks like a completely stock setup.
Old Mar 11, 2010 | 11:14 AM
tom.g's Avatar
It's obviously not going to put down anywhere near trifecta levels but it should of put down 265-280WHP IMO
Old Mar 11, 2010 | 11:19 PM
HP=torque*rpm/5252
I do understand that HP is calculated from torque, but I know when they went to apply ft-lbs to the graph, it had readings of 190, 9, and 140 (3 separate runs). We just assumed that was some kind of mistake. It looks more like a HP line in my stock graph to me. I could be wrong.
That would be 28-43whp increase over my stock whp figure, and I don't think the Stage 1 is THAT underrated. For a claimed 280hp and 320ft-lbs at the crank, I should be putting down 238-240whp and 272-275ft-lbs at the wheels. I'm putting down 15-17whp and 14-17lb-ft more than those calculated numbers (using a 15% drivetrain loss and GM's claim for Stage 1's power).
I was hoping for 250whp and 270ft-lbs and I beat that!
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
