Boooooost
Old Jun 9, 2009 | 12:06 AM
ssturbo305's Avatar
Boooooost
for you ss tc drivers
i got an 09 with less than 500 miles.. live in sunny florida.
noticed today i was boosting 15psi. Will this increase once car is broken in?
or do you guys normally have 15 psi? if so whats the range you guys got..
answer if your stock lol wouldn't help much if your tuned.
Old Jun 9, 2009 | 12:11 AM
swazzees's Avatar
bounce off 17psi\
hold steady 15-16 psi
Old Jun 9, 2009 | 12:15 AM
Stamina's Avatar
Post
I've been as low as 12 and change and as high as 18.
I've heard of a guy up north getting as little as 10.
It has to do with density altitude, which is how easily your engine "breathes":
Low altitude (high pressure), low temperature (denser air), and low humidity (less water in the air taking up space) all contribute to your engine "breathing" easier and therefore making more power on its own without the need for the turbo. The ECU will notice this and will lower the target boost pressure from the turbo.
Higher altitude, high temperature, and high humidity will all have the opposite effect and you'll notice more boost.
Here's a post I made a while back if you're interested in learning more.
Old Jun 9, 2009 | 02:35 AM
09BlueBaltSS's Avatar
Im in Broward and usually boost 15-16psi
Old Jun 9, 2009 | 03:11 AM
raynrishad's Avatar
I live at over 5k feet. I drive between that and over 7k feet. So, pretty high altitude. I've seen my boost gauge hit about 20psi. As they said, the higher the altitude the less air. I think you lose like 5% power for every 3k feet you go up, etc. Which is why the ECU will have the turbo push more or less air.
Old Jun 9, 2009 | 03:15 AM
Knightwolf's Avatar
My car now has 1k miles on it and boosts around 15 most of the time when I'm "going", however in 3rd and 4th gears it'll spike almost to 18.. mind you I haven't watched the boost gauge for the past 400-500 miles either lol but that's what it was doing. I'll check it out tomorrow when I'm out and about to be sure and update if there's any change. Elevation here is 2200 feet as well btw.
Old Jun 9, 2009 | 02:06 PM
TorqueSSter's Avatar
Talking I finally looked on my Wendy's run !
NLS for the MFW !
The gauge held steady at 15 psi - schweet !
I am in Houston - about 87 degrees w/ 57% humidity today. I turned 666 miles on the way back ...
Britt
Old Jun 9, 2009 | 02:36 PM
Permafried-'s Avatar
Your boost is limited by the ECU based on elevation, barometric pressure and the HP/TQ numbers it calculates you are putting down. The 15PSI you're reading indicates that's all that's required for the ECU to calculate maximum configured power at which point it begins relieving boost.
Around here I'm the same as swazzees (since we're literally 40 minutes from eachother) and I've never seen it higher than that regardless of the weather .
Old Jun 15, 2009 | 02:36 PM
swazzees's Avatar
dunno if its the warmer weather or not but i cant advance over 15 psi now
Old Jun 15, 2009 | 02:44 PM
Terminator2's Avatar
15.3 psi stock was what mine was making soon to be even higher than 22.5 psi.
Old Jun 15, 2009 | 06:41 PM
CudaJoe's Avatar
I make 7-13psi with my leaking boost modification. It rocks, I recommend it.
