Brakes slipping? Adivce anyone?
Stock rotors for me. I run them lap after lap in the dry, and the poor things glow from the abuse, but they are smooth with no cracks. Last event, I also ran them lap after lap going 110-120 mph in the pouring rain, and they were just fine. Yes, you'll have a split second where they don't work as well, but just step on the pedal harder.
YouTube - Trackdaze, VIR Full, Nov 16, wet, wet, wet!
lulz at this thread. Our cars have nice wide open wheels/no dust shield. It's pretty easy for water to accumulate on the rotors. Don't complain about something that works better than the braking systems of 90% of the other vehicles on the road. Leave a little more space between you and the car in front of you(which you should do anyways when it's wet...) and you won't have a problem.
I've never had brakes not do this, you feel it more on this cars because you're used to it breaking on a dime, it's actually worse on motorcycles, but nothing to be worried about, nature of the beast, if you guys are so worried about stopping distances then slow down you're going to fast for the conditions, it's just common sense
My first car vehicle was a '77 Chevy 1/2 ton. had manual steering, manual brakes, 3speed manul with column shift, bias ply tires. Guys complaining about "slippery brakes" on an SS/TC need to be smacked.
My '65 malibu SS had 4 wheel manual drum brakes.....
A stock Cobalt LS is better in virtually every aspect of handling and braking than most of the badass muscle/pony cars from back in the day, kids are spoiled
one of the first cars I ever drove actually had 4 wheel drum brakes. Now that was terrifying!! Then in high school I helped a buddy put together a 454 chevelle using a 78 chevy truck 454 between the heads cam and such the car was lopy as hell idle wise. Well long story short massive cam = not enough vacuum for strong brakes. Yeah that might of been worse than the 4 wheel drum brake car! That thing couldnt out brake a nuclear aircraft carrier! It did get a some help on that issue down the road.
, plus if you tried to get it going in first it wouldn't but it would try to do a wheelie
I'm having the same issue as reported. Only an issue when it is cold out and wet. I have bled the brakes quite a bit just to be sure, but you can tell its a simple lack of pad to rotor friction issue. The pedal is firm but you get no braking. I can tell you I have had other cars with high quality factory brakes like my S2000, STI, C5 Z06, Type R, and Evo. Non of them had this issue like this car does, NOT EVEN CLOSE. Non of them had slotted or drilled rotors. There is also a huge list of cars I have had that had less heavy duty stock braking systems that never did this either. I have to wonder if its an issue with the stock pads. I like how some of you say just be aware, hardly an acceptable answer. What if you actually need the brakes like NOW, due to an unforeseen hazard ???? Perhaps you have no deer or stupid drivers where you live
I'm surprised chevy hasn't been sued over this issue yet (based purely on how bad an issue this is).
Anyone try changing to a different pad and get an improvement or change?
I'm surprised chevy hasn't been sued over this issue yet (based purely on how bad an issue this is).Anyone try changing to a different pad and get an improvement or change?
brakes slipping PLUS
My brakes are slipping also but when mine do it the entire back end comes around and I do a 180 or sometimes even a 360.. anyone have any ideas as to why and if it means theres a big issue I need to fix
Thanks
and it's a 2008 Cobalt LS
Thanks
smathys460,
Welcome to the forum! While I cannot provide much in the way of troubleshooting as a customer service representative, if you should have questions about warranties or working with a dealership to get this checked into, please let me know.
Sarah, Chevrolet Customer Service
I've had the problem with bothe stock pads and rotors along with r1 concept rotors and hps pads. Its not a rotor and pad thing.
I've. Actually just gotten used to it. As many said above if its raining or cold, slow down. Tap the brake before you actually need to push on it in order to get some of the water off. And most importantly stop tailgating
While we can't do anything about the large-faced rotors, when they're wet, we have discovered that a lot of the brake pedal sponginess is caused by the rear rotors. Replace the rear calipers, or just try resetting them by turning the pistons all the way back in.........then bleed the brakes and the sponginess will disappear.
Iceberg
Sep 29, 2015 12:33 PM
