Burning Clutch using "Launch Control"
Old Jun 1, 2010 | 01:46 AM
LiveT's Avatar
Anybody else Smell a Burning clutch while using the Launch Conrol Feature. I know It really doesnt work that well but I see the videos on Youtube where they ping it off the 4800 rpm then let the clutch go. I try the same thing and All I get is Wheelspin and Burning clutch Smell.
Old Jun 1, 2010 | 03:00 AM
SSlobalt's Avatar
Put your flamesuit on, newb.
Old Jun 1, 2010 | 03:07 AM
tREBs's Avatar
Why??
its a known fact the RPM limiter is set far too high on the T/c, its great if you are on slicks at a track, but thats about it.
OP, you probably have worn out your clutch pre-maturely due to driving habits/ skill. Do you ride the clutch when releasing it? Is the T/C your first standard car?
Old Jun 1, 2010 | 07:38 AM
jpower102's Avatar
OOO look the short bus is coming to pick you up ...
But then again why did GM put that feature if it wasn't going to be used .. cept to make more money replacing clutches lol
Old Jun 1, 2010 | 07:41 AM
BLAZIN07SS's Avatar
I'm too JDM for you
if its wheelspin is more than likely not a burning clutch smell
Old Jun 1, 2010 | 08:02 AM
ei3dag3's Avatar
don't use launch control. it will burn your clutch.
gms attempt at it was a waste, and if you're going to launch, launch around 2-3k depending on track.
Old Jun 1, 2010 | 08:17 AM
CudaJoe's Avatar
I used launch control once. Yes it will burn your clutch and roast your tires.
Old Jun 1, 2010 | 08:28 AM
LiveT's Avatar
Wow It was a Simple Question about a factory option. Looks like I need to Find a new Cobalt Forum where not everybodys perfect.
Old Jun 1, 2010 | 09:14 AM
jpower102's Avatar
All I know is if I would try it once and see the results being:
1) tires burn uselessly
2) premature clutch wear
I wouldn't do it again after the 1st try ..
Old Jun 1, 2010 | 09:20 AM
tmharsh's Avatar
Any time I've played with launch control I haven't burned the clutch or seen excessive wheel spin. You shouldn't get a lot of wheel spin since it's designed to limit it. You don't side step the clutch, but you do want to release it quickly. If you think you're burning it, then you're likely letting it out too slow. Keep in mind that the clutch engages close to the top of pedal travel, so you may also be used to cars where the clutch engages earlier. Try focusing on releasing the clutch and placing your foot on the dead pedal in one motion.
Old Jun 1, 2010 | 09:21 AM
LiveT's Avatar
Smile
Originally Posted by tREBs
Why??
I don't believe I ride it. I maybe releasing the clutch to slow, just dropping the clutch from high rpm just doesn't seem like a good idea though. Not my first 5 speed but my last car was a focus with half the power so I probably need to relearn how to drive this car.
Old Jun 1, 2010 | 09:30 AM
myrt's Avatar
mine works alright i meen i do spin like crzy but the car dose take off good. n i nvr smell burning clutch. might just need a new clutch man. or like thay said up top ur just letting it out a bit to slow.
Old Jun 1, 2010 | 09:39 AM
SSlobalt's Avatar
Old Jun 1, 2010 | 09:40 AM
buellfooll's Avatar
You sure it's the clutch you're smelling and not the tires? To the truly uninitiated they might smell the same. Try this. Spin the tires unmercifully by any means available, jump out of the car quickly and smell the tires. You'll never mistake the smell of burning rubber again. Seriously!!
Old Jun 1, 2010 | 09:42 AM
JPizzle's Avatar
Yea. I think that this guy is just slipping the clutch (not letting it out fast enough) and that's why he smells clutch.....
Old Jun 1, 2010 | 10:25 AM
Permafried-'s Avatar
If you use LC properly you shouldn't smell burning clutch. If you are, you're slipping it too much; it's a controlled release, not a dump, not a slip. If you dump it, you might want to prepare for new axles depending on track prep. If you're smelling burning clutch repeatedly you might want to set aside $1500+ for a clutch job, or quit using it or you'll burn your clutch out in absolutely no time.
The feature isn't useless it works well now that I got rid of the **** stock tires, these ones actually want to grab, the stockers want to just smoke away all day long and then randomly decide they should function as a tire and not a smoke show. Those saying it's useless do realise what that mode causes the ECM to do....right???
Old Jun 1, 2010 | 10:33 AM
Godly's Avatar
Simple solution=don't use the LC.
The limit is set to high and ive made worse times with it then I have by just launching at 2-3 k
Old Jun 1, 2010 | 10:57 AM
jpower102's Avatar
Would a tuner be able to adjust the rev limiter in LC mode?
Old Jun 1, 2010 | 11:00 AM
stanced_balt's Avatar
cool tow hook too bad your stance is still half assed. if m borroughs caught you rockin' the sig on sw forums he'd give you a perma ban for poseurism.
Old Jun 1, 2010 | 11:05 AM
BLAZIN07SS's Avatar
I'm too JDM for you
waiting on tires. ruining my rear quarter panels every time i hit a bump. and i just use the sigs cause they are funny as ****. lol
Old Jun 1, 2010 | 11:11 AM
cc08 status
Old Jun 1, 2010 | 11:16 AM
I don't see why not; Term/BYT should be able to answer that though if they happen to see this thread.
Old Jun 1, 2010 | 11:24 AM
Shez's Avatar
I don't know if you could edit the stock launch control rpm limit. You would need a WOT box, no?
Old Jun 1, 2010 | 11:30 AM
If they've unlocked the ECM/PCM it should simply be an entry in a table I would think? I could definitely be wrong but I thought all rev limits were controlled by the ECM based on the mode the car is in?
Old Jun 1, 2010 | 11:36 AM
Iam Broke's Avatar
Launch control RPM's aren't in a given table HP Tuners has opened up, but you can limit your RPM's any time in neutral or the clutch is depressed afaik, though I never tried it.
Since tuned I don't use it or the NLS feature. No need to grenade the trans here.
