CAI Rubbin??
I went to go swap springs in my BPV today an saw that my injen CAI has been Rubbin the **** out of a bolt on top of somethin tO the point where half the bolt is almost gone.. Is there anyway I can stop the Rubbin? I don't want anything to end up bein jacked up down the line, maybe I'll jus tape that Lil line to somethin
Anybody else with this issue???
Pics belowwwwww
Pics belowwwwww
The charge pipe, I saw a HAHN pipe that rubbed on the underisde of the hood. All the red p/c was rubbed off down to the metal.
Yeah I know, just saying the charge piping is all I have heard about rubbing.
Cut up some radiator hose and either cover the bolt, or cover the intake. You can try adjusting the intake too. My Hahn has to get adjusted every few months, otherwise it will knock against the wheel well :-/
You need to fix that yesterday. That is an AC line, and when you wear through, it's going to depressurize the system, and you'll need a new line.
You should be able to move the intake or line gently away from each other. Will likely require a ziptie or something to keep it from moving.
Ya I was hopin it was nuthin like that
I can wiggle both of em around, but can't keep em away...
If I zip tie the aC line or Tape it to the side of one of my front struts or somethin, would that mess up anything when I turn my aC on???
You shouldn't unless you're a gorilla.
What about loosening the clamp and pulling the intake tube out of the rubber elbow some, just to make it sit a little bit higher? With my zzp intake (s/c) I had to mess with it so that it doesn't rub on the computer. Took a little while to get it all moved around but it's good now.
Good luck, hope it works. I hate how much crap chevy crammed under the hood and how everything "just fits". Make the car 3" wider and longer so we can have some room to do something!!
