change radiator hoses
Old Oct 30, 2014 | 07:02 PM
stevehendo34's Avatar
My 2009 TC now has 128,000 and hit 5 years.
Should I change the radiator hoses and thermostat.
I am going to change the coolant. is it hard to unhook the lower hose to drain.
I herd it is impossible to get to radiator drain.
Any explanation on changing bottom radiator hose or how to unhook it to drain system appreciated.
I know about the water pump drain and how to refill and burp the coolant system on a LNF from a video.
Old Oct 30, 2014 | 08:35 PM
kzak104's Avatar
the rad has a drain, loosen it, and under the lower rad hose,
no point in changing the hoses if theyre fine, same with the thermostat,
when i filled my coolant system i had the upper rad hose disconnected to help any air escape, whether or not it helped idk but i didnt get any air pockets after burping the system a few times
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
