How to change serpentine belt.
Old Aug 27, 2014 | 08:55 PM
stevehendo34's Avatar
Jack up car mine is 2009 ss.
Remove passenger side wheel.
Remove black cover that's over the belt and on inner fender well.
Get tool serpentine belt tool from harbor freight like $11 or so.
Cut tool in half or it won't get in there, I moved red rubber piece to shortened tool.
If you cut it the exact correct length you can lock the tenssioner open resting it on the inside of the axcle
Use the tool from under the car-you do not have to bend it works great.
This took me 30 min total and was so easy. Stealership wanted $137.
Old Aug 27, 2014 | 09:03 PM
714ionredline's Avatar
Thanks
Old Aug 31, 2014 | 01:07 PM
cw383's Avatar
Awesome. I have a new belt, just need to get ambitious and put it on. I was just going to get the loaner tool for Autozone, but that's a good find at Harbor. How long did your tool end up being after your cut?
Old Oct 30, 2014 | 11:59 PM
13 inchs
Old Oct 31, 2014 | 06:28 AM
LNFTX's Avatar
A thin 3/8 ratchet or a ratchet attachment for a wrench will work also
Old Nov 2, 2014 | 08:28 PM
Solaris99's Avatar
I just changed mine today. I had rented a serpentine belt tool from Auto Zone and it was too long, so I ended up needing to remove the engine mount and take it on from the top. A thin ratchet probably would have been easier.
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
