Charge pipe Q's
Charge pipe Q's
im thinking of upgradeing the pipes since there stock. but do i need to be tuned for these? also what brands are out there and whats the best bang for the buck? i was thinking zzp but im not shure how i should order them
no tuning needed. If you don't want a MAF reloceate (which you DO need to tune for) just get the hot side piping (or upper piping). ZZP makes a great set of pipes, but you have to cut your stock elbow if you don't order their silicone couplers.
ah thanks tommy. i was thinking just the hot side for show purposes. might get the K@N intake. but ive had issuse with intakes.
I would have bought ZZP pipes if they were out at the time I bought CIA dress-up hot sides. I do like the way the CIA's follow the stock route and not straight across the motor .... but i guess the shorter one's are good for a couple hp more from what ive read.
Can you explain a bit more on this? Which elbow do you have to cut: The one from the turbo or the one going to the IC? And are you sure you have to cut it? This is the first I've heard about this.
You don't have to cut anything if you buy ZZP's coupler kit . If you want to save some cash you can cut the couplers off your stock charge piping and reuse them.
My Injen has given me no problems and it looks sexy! Make sure you get the upgrade on the couplers and T-bolts. Im tuned and the is no need for m.a.p. relocate. My buddy has the same set up and he did the m.a.p. relocate but there is no real preformance gain
