Clutch Slip
Old Oct 11, 2011 | 11:27 AM
TheTruth7's Avatar
Clutch Slip
So I have read around before and saw similar stories. But Last night I went to get my car dynoed and at about 3k clutch would slip.. Now when i drive it and get on it on the highway i have noticed it before, but was never bad. So Trying to get opinions what clutch I should get in the future?
Old Oct 11, 2011 | 11:29 AM
nutty21's Avatar
Sub'd
Old Oct 11, 2011 | 11:36 AM
Chevycobaltss3's Avatar
Lol... Specs dont hold up, clutchmasters wont either, zzps have been used and.good results. The hypersingles suck all around. Ky clutch is proven and is a cheap route.. 300-400 shipped for a 650+ rated ft lbs clutch. 1 year warranty great customer service. Fast shpping, and ect.
Old Oct 11, 2011 | 11:39 AM
TheTruth7's Avatar
Damn, yeah im just still on the stock turbo with the tune. And right when my car wanted to hit that power it started slip But i'll look into that clutch.
Old Oct 11, 2011 | 11:56 AM
donkeyballs's Avatar
The hyper isn't too bad and the only problem I have is chatter when its cold. It has taken everything that I have thrown at it and its stiff but if your not a weak ***** you get used to it in a couple days. The zzp would be my other choice.
Old Oct 11, 2011 | 11:58 AM
Only reason i say not to do the hypersingle is ive seen three blow up on my tunes and like 4+ on other tuners tunes.
Old Oct 11, 2011 | 12:30 PM
Fastgti69's Avatar
KY seems to be the best bang for the buck. spoke to a guy last week he seemed pretty knowledgeable 400 shipped with everything needed. even throwout bearing or something
Old Oct 11, 2011 | 12:34 PM
Yep....
Old Oct 11, 2011 | 12:44 PM
BartSS's Avatar
Im on a hypersingle and the only thing that gave out was my trans. Im on a pretty agressive tune and it doesnt slip at all. Its been in like 2 years now
Old Oct 11, 2011 | 02:19 PM
slvrred-'s Avatar
sub'd as well. i think my clutch is starting to slip......seems to only do it in 4th and 5th gear.......1-3 still seem to hold ok.......I was thinking hypersingle just outta the fact that i don't have any shops around me that can resurface my flywheel and the stock one is almost 700 bucks.....
Old Oct 11, 2011 | 05:02 PM
nutty21's Avatar
So it's between Ky clutch & ZZP
so lets here it.
I want the good the bad and the ugly between these two.
What's your experience folks?
Which one will last the long run?
Old Oct 11, 2011 | 08:10 PM
FasterIsBetter's Avatar
Damn, lol. Wish I woulda bought a KY clutch. Where do you get em? Do I have to call up Kentucky Clutch or something? I looked all over the place for em.
Old Oct 11, 2011 | 08:16 PM
chris88z24's Avatar
Lol the Synapse Turbo SS made almost 400 ft lbs of torque on the stock clutch, was abused daily, and never once had an issue with the clutch slipping.
Old Oct 11, 2011 | 08:44 PM
If you want a ky clutch call em. Tell them about me and youll get the deal f you dont you wont get.the.clutch at the good price.
Old Oct 12, 2011 | 07:33 PM
slvrred-'s Avatar
I called them today and called them today and quoted me 390 shipped for there stage 3 clutch. Apparently they only offer the stage 3 and a stock replacement......insight?
Old Oct 12, 2011 | 08:15 PM
Depends on what u want the only make the 8 puck for people who need them since theyre.so harsh on engagement. .... All u will ever need is the stage 3-4 lol. We tested the setup again to see what the system would hold. Pressure plate held to 2000 ft lbs friction disc. 650-700 ftbls without slippage.
Old Oct 13, 2011 | 10:44 AM
RYRO14's Avatar
You can buy stock flywheels from ZZP for $120
Old Oct 13, 2011 | 08:42 PM
Knightwolf's Avatar
Double Holy **** on that KY clutch! Cheap and holds a **** ton.. very impressive. Sub'd for future when I do buy a clutch(next year) :P Mine still holds if I keep the revs above 3500 rpm
Old Oct 13, 2011 | 08:45 PM
TurboTechRacing's Avatar
Stock Flywheel with a SPEC STAGE 3+ Clutch kit! One of the BEST setups around.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
