Clutchmasters stage 3 problem, help!
So I recently purchased a Clutchmasters Stage 3 clutch and alum. Flywheel and installed it all. I didn't beat on it at all for the first 100-200 miles and for the first time yesterday I went WOT in 1st and as I tried to shift to 2nd it was as if there was a wall blocking me from shifting into it, so I slowed down and calmly shifted into 2nd like normal and all was smooth. I did the same thing from 2nd to 3rd and it was still "blocking" me from shifting when driving aggressively, it shifts perfectly normal when driving normal. What could the reason for this be?
I Agree with Dart, You havent broken it in long enough, You shouldnt be driving Agressively for about another 200-300 miles or so, The engagment will prolly come off the floor a bit more as you break it in more as well.
Definitely not bled good enough. When you press the pedal in quickly, there isn't enough hydraulic pressure to push the pressure plate in all the way, so it's not completely disengaging form the flywheel. When you bleed it good, it will disengage.
