Cold start issues
Old May 12, 2013 | 08:39 AM
TurbaltSS_09's Avatar
Cold start issues
Hey guys, I'm having some issues with my car, When it sits for several hours or over night and I start it it will misfire and sputter on cold starts only. After it warms up it runs fine and will only throw a CEL when first started. The dealer put new plugs in and the gap was.048 on #4 and.033 on 1,2,3. I'm thinking the coil pack got stressed too much and is now shot. Just wanted to see what you guys thought... Dealer isn't being much help with this issue. it is an 09 ss t/c.. thanks
Old May 12, 2013 | 09:12 AM
umrdyldo's Avatar
As always...
What CEL are you getting?
Old May 12, 2013 | 09:24 AM
random misfire and misfire on all 4, but the code is different every time. One day it will be a random misfire i'll clear it and next day it will be misifre on a specific cylinder.
Old May 12, 2013 | 10:02 AM
Sox-Fan's Avatar
Got Brakes?
Swap 2 and 4 coil pack. If the misfire code moves to 2 its coil. If it doesn't move check the plug.
That gap is too small.
Old May 12, 2013 | 07:59 PM
SSlobalt's Avatar
Another member on here, YelloEye, had the same issue and found out it was coked-up valves. He had his entire head replaced by GM. PM him and see if he can help you out.
Old May 12, 2013 | 10:53 PM
Top end was just done by the dealer! 4 new pistons too.
Old May 13, 2013 | 08:41 AM
umrdyldo's Avatar
Alright well if the dealer just did that then you need to be taking back to them for a fix.
Old May 13, 2013 | 09:46 AM
QuickSilver_SS's Avatar
X2 , if I just had all that replaced and still had misfires and or soem sort of issues I would be right back in there.
Old May 13, 2013 | 11:07 AM
I have and they keep telling me nothings wrong so I called GM today an bitched
Old May 13, 2013 | 11:11 AM
I just replaced the MAP sensor ( one on top of manifold ) because it just went.... I have a feeling its the other map or one of the coil packs... Plugs look fine aswell.. Im not a mechanic by anymeans would be nice if the dealership would stop fukin around an get it fixeed
Old May 13, 2013 | 11:17 AM
umrdyldo's Avatar
So what exactly did they do? Is a whole new head or did they just replace valves or what?
Does the car run fine when warm?
Have you ever replaced the Evap purge sensor?
Old May 13, 2013 | 11:34 AM
They said two valves were stuck from carbon build up an the lifters were broken. so they fixed that and ported the top end said it was good to go. got it back threw another cel they replaced the fule pump cam shaft sensor pcm said it was done.. Again threw another code they started looking at bottom end replaced pistions and rings. And now they say theres nothing they can do...yes it runs fine when warm except for minor misfires which wont throw a cel. only time I can feel it struggleing is during cold start.. no have not looked at Evap
Old May 13, 2013 | 11:37 AM
umrdyldo's Avatar
Well that still sounds like something is screwed up in the head.
and when the dealer says "there's nothing else they can do".
You escalate it like you have done. Where is the GM service chick Sarah or whatever her name is?
Old May 13, 2013 | 12:06 PM
Lol my buddy said same thing awhile back..
Old May 13, 2013 | 12:32 PM
umrdyldo's Avatar
It scares me a bit when you say ported. Doesn't the LNF hate to be ported on the intake side?
Old May 13, 2013 | 01:47 PM
Chevrolet Cust Svc's Avatar
Hi TurbaltSS,
I can certainly understand your frustration with the issues you have described. I would like to research this for you. Can you private message me your full name, address, phone number, Vehicle Identification number, and approximate mileage on your vehicle please?
Kindest Regards,
Crystal L-Chevrolet Customer Care
Old May 13, 2013 | 01:58 PM
Sir_Hiro's Avatar
Crystal?! What happened to Sarah??
Old May 13, 2013 | 02:51 PM
damastah's Avatar
Sarah got fired for uploading pics of herself nude on CSS
Crystal is the new replacement
and what is this number to GM? i would like to call and bitch to someone as well haha
Old May 13, 2013 | 04:09 PM
Originally Posted by Chevrolet Cust Svc
Hi TurbaltSS,
Kindest Regards,
Crystal will pm you after work.
Old May 13, 2013 | 08:51 PM
gotboost?17's Avatar
Nothin Stock
I wanna c pics of Crystal, yum yum
Old May 13, 2013 | 08:53 PM
Nothin Stock
an op just stage kit it and everything should fall into place
Old May 13, 2013 | 08:55 PM
nobody2u's Avatar
Sub'd
Old May 14, 2013 | 08:04 PM
SSlobalt's Avatar
Originally Posted by nobody2u
Sub'd
For solution, or pics of Crystal?
Sean Cummings
Jan 8, 2020 10:17 AM
ricklovin93
Aug 27, 2016 06:35 PM
vjoel2011
Oct 2, 2015 12:11 PM
Sabon_SS
Sep 7, 2015 12:39 PM
