Couple Questions To Owners
First...Do you know what the bolt pattern is on the rims, im sure ive read it somewhere before but i cant remember where
Second...Wheres the throttle body, is it at the back where the air box hose leads to or just behind the drivers headlight, or somewhere completely different?
Do either of you guys know if the Hahn exhaust from the SC will fit on the TC (just the cat-back), and also what about the spring are they the same because i have the H&R's on mine now and would like to swap them over. If u know either of them that would be great.
I thought i read somewhere that the downpipe on the TC has a three bolt flange on the end, so you could get the catbacks for the SC to work if you cut the 2 bolt flange off them and welded in a 3 bolt.
