CRACK pistons????
Old Nov 19, 2010 | 12:36 AM
slowgt's Avatar
CRACK pistons????
hey, i have a 09 cobalt ss with hahn ic and intake and custom straight pipe. i got a hp tuneput on my car from this guy named corry. he does alot of turbo balt tunes around where i live and he had my tune on a conservitive tune which was 20 psi and spiked at 22. idk if it was me racing from 2nd gear 40 roll and it spinnin tires hittin the rev limiter that made the pistons crack or if it was the tune? or was it a combination of my shitty drivin and the tune?
thanks
Old Nov 19, 2010 | 12:40 AM
blacklightmachine's Avatar
How
in plain english plz
do you know that your pistons are 'cracked'
Old Nov 19, 2010 | 12:42 AM
Nacademus's Avatar
You can heat your rocks and give everyone following you a free high all at the same time!
Old Nov 19, 2010 | 12:44 AM
Perfect.disguise's Avatar
Suuubaruuuuuuuuuu's sound good
Old Nov 19, 2010 | 12:45 AM
slowgt's Avatar
took it to the local dealer and they found out that they were
Old Nov 19, 2010 | 12:48 AM
Were you driving like a tard?
Old Nov 19, 2010 | 01:15 AM
slowgt's Avatar
na just wasnt use to the tune and dropped it in second and when i went to race this kid and i floored it, it hit the rev limiter quick and i let off and peddled and shifted it early and floored it again then hit the rev limter again and just let off... it was just like seconds if that on the rev limiter...
Old Nov 19, 2010 | 02:12 AM
ronn's Avatar
Your rev limiter is prolly already altered to 6700 or so with the tune? Not sure why piston would crack...usually ya see a bent valve. Maybe the valve hit it and caused the crack. Over reving will cause piston to come in contact with valve. If we have an *interference engine*, which I assume we do then:
Over-revving can cause the pistons to rise faster than the valve springs pull the valves up. In an interference engine valves and pistons crash together if that happens.
Old Nov 19, 2010 | 02:21 AM
You were driving like a tard.
Old Nov 19, 2010 | 08:47 AM
BartSS's Avatar
Where are you in IL and who is this Cory guy?
Old Nov 19, 2010 | 09:33 AM
Wangspeed's Avatar
Hitting your rev limiter won't cause your pistons to crack. I assume that your ringlands have cracked, if anything (or they mis-diagnosed). There's more to the tune than just keeping boost conservative. Timing makes a significant difference. No way to tell what's going on here without more information.
Old Nov 19, 2010 | 09:40 AM
importkiller's Avatar
Ummm Crack is good...
Old Nov 19, 2010 | 09:41 AM
Stamina's Avatar
As it is though, people just stick stronger valve springs in the head and rev much higher than 6700.
I wonder if it was something to do with the limiter itself and knock. A tuned friend of mine messed up an NLS, tapped the limiter, and ended up cracking a piston at some point during that event (had the Subaru sound start immediately after). Upon taking apart the engine, there was no evidence of any valve-piston contact, and the piston was broken on the side.
There's a pic^. He had luckily already bought forged pistons so we put those in over that weekend. Anyway, due to that, my guess would be something not valve related.
He was also using colder plugs.
Old Nov 19, 2010 | 10:06 AM
SSlobalt's Avatar
Cracked ring lands are caused by heat, right?
Old Nov 19, 2010 | 10:09 AM
Stamina's Avatar
I believe knock can cause it too.
Old Nov 19, 2010 | 10:20 AM
Iam Broke's Avatar
Overheating the rings cause them to expand more than the end gaps allow, forcing them to dig into the cyl walls and popping the ring lands off the piston. Anything that causes excessive piston/ring temps will pop a ring land.
SSlobalt's Avatar
Ah. Knock makes more sense because knock is a flame front collision that caused the piston to rattle in the bore. I can see that causing it.
Old Nov 19, 2010 | 12:41 PM
sebbie16's Avatar
What do you mean by subaru sound? The engine sounds more like a subaru?
Old Nov 19, 2010 | 12:51 PM
Stamina's Avatar
Typically when a compression issue pops up on our engines, such as when a piston/ring is damaged, the engine will then run uneven, sounding similar to a Subaru's boxer engine like the ones found in the Impreza WRX or STI. I hear the Subaru's signature sound comes from the unique uneven design of its exhaust, but that's another topic. The bottom line is when our engine sounds like that, then you've probably got a compression issue on one or more cylinders.
Old Nov 19, 2010 | 12:58 PM
sebbie16's Avatar
Well that sux... guess I need to do a compression test this weekend. After a NLS shattered my lifters (fixed under warranty) my car started to get the subaru sound.
Old Nov 19, 2010 | 01:04 PM
JacBlackSS/TC's Avatar
see i was wondering if from a 30 or 40 roll is 2nd gear or 3rd gear i always do 2nd but everyone has been telling me to do 3rd gear
Old Nov 19, 2010 | 01:05 PM
CudaJoe's Avatar
I NLS 1st to 2nd and my car immediately sounds like a subbie! then it corrected itself
Old Nov 19, 2010 | 01:11 PM
Rissa's Avatar
I do 40 rolls from 2nd.
Old Nov 19, 2010 | 01:30 PM
sebbie16's Avatar
BTW... how would one test the compression on these cars? The same way you would with a NA one. Never tested a turbo car before.
Old Nov 19, 2010 | 01:33 PM
PrincessTurbo's Avatar
1st to second nls is just torture...I granny that bitch all the time, nls is only worth it if the other car is 50K + lol
