detecting ecm aftermarket calibrations...
Old Feb 25, 2011 | 10:48 AM
scopedmp5's Avatar
this is what we look for. we arent given an actual procedure to identify tunes and what not. just basically if the calibration ID's arent correct enjoy! lol
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 VIN A Service Manual | Document ID: 1969610
Engine Control Module Scan Tool Information (LNF)
Table 1: Engine Control Module Scan Tool Data Parameters
Table 2: Engine Control Module Scan Tool Output Controls
The Engine Control Module Scan Tool Data List contains all engine-related parameters that are available on the scan tool. The list is arranged in alphabetical order. A given parameter may appear in any one of the data lists, and in some cases may appear more than once, or in more than one data list in order to group certain related parameters together.
Use the Engine Scan Tool Data List only after the following is determined:
• The Diagnostic System Check - Vehicle is completed.
• No diagnostic trouble codes (DTCs)
• On-board diagnostics are functioning properly.
The scan tool values from a properly running engine may be used for comparison with the engine you are diagnosing. The Engine Scan Tool Data List represents values that would be seen on a normally running engine.
Important: A scan tool that displays faulty data should not be used. The scan tool concern should be reported to the manufacturer. Use of a faulty scan tool can result in misdiagnosis and unnecessary parts replacement.
Only the parameters listed below are referenced in this service manual for use in diagnosis. If all values are within the typical range described below, refer to Symptoms - Engine Controls for the 2.0L engine for diagnosis.
Engine Control Module Scan Tool Data Parameters Parameter
System State
Expected Value
Description
Base Operating Conditions: Engine Idling/Radiator Hose Hot/Closed Throttle/Park or Neutral/Closed Loop/Accessories Off/Brake Pedal Released
5-Volt Reference 1 Circuit Status
OK
This parameter will display OK if the circuit is good or Fault if a short to ground, short to B+ or open circuit is present.
5-Volt Reference 2 Circuit Status
OK
5-Volt Reference 3 Circuit Status
OK
This parameter will display OK if the circuit is good or Fault if a short to ground, short to B+, or open circuit is present.
A/C Disengage 1-8 History
Varies
This parameter indicates the reason the A/C compressor was disengaged. The reasons displayed are: None, A/C Pressure, Eng Spd, Batt Voltage, Stall Prevention, RPM Unstable, WOT, Launch Perf, Coolant Hot.
A/C High Side Pressure Sensor
1.43 Volts
The scan tool displays 0-5 volts. This is the A/C refrigerant pressure sensor voltage signal.
A/C On
2.39 Volts
868 kPa (125 psi)
The scan tool displays -103 to +3,119 kPa (-14 to +452 psi). This is the A/C refrigerant pressure sensor voltage signal converted to pressure.
A/C On
1568 kPa (227 psi)
A/C Off for WOT
No
This parameter indicates if the A/C system was commanded off for a wide open throttle event.
A/C Pressure Disable
No
The scan tool displays Yes or No. Yes is displayed when the system pressure exceeds 3,034 kPa (440 psi).
A/C Relay Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the A/C relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
A/C Relay Ckt Open Test Status
OK
This parameter displays the status of the output driver for the A/C relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
A/C Relay Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the A/C relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
A/C Relay Command
Off
The scan tool displays ON or OFF. ON is displayed when the ECM has energized the A/C compressor clutch relay.
With A/C Selected
On
A/C Request Signal
No
This parameter displays the state of the air conditioning (A/C) request input to the control module from the heating, ventilation, and air conditioning (HVAC) controls. The scan tool will display Yes or No. Yes indicates the control module is receiving a request from the HVAC system to ground the A/C clutch relay control circuit, engaging the A/C compressor clutch. No indicates the control module is not receiving a request from the HVAC system to ground the A/C clutch relay control circuit.
With A/C Selected
Yes
Air Flow Calculated
3-6 g/s
This parameter displays the air flow of the engine as calculated by the control module using information from the manifold absolute pressure (MAP) sensor. The scan tool will display a range of values indicating a high air flow when MAP pressure is high and a low air flow when MAP pressure is low. This value is listed in grams per second (g/s).
APP Indicated Angle
Accelerator pedal not actuated
0%
This parameter displays the angle, in percent, of the accelerator pedal as calculated by the control module using the signals from the accelerator pedal position sensors. The accelerator pedal position (APP) indicated angle is a range of values indicating a low percentage when the accelerator pedal is not depressed to a high percentage when the accelerator pedal is fully depressed.
Accelerator pedal fully actuated
100%
APP Sensors
0%
This parameter displays the average of the accelerator pedal position (APP) sensors as calculated by the throttle actuator control (TAC) module. The APP average is a range of values indicating a low number when the accelerator pedal is not depressed to a high number when the accelerator pedal is fully depressed. This value is listed in percent.
APP Sensor 1
0.94 Volts
This parameter displays the voltage signal sent to the control module from APP sensor 1 of the APP sensor assembly. APP sensor 1 is a range of values indicating a low voltage when the accelerator pedal is not depressed to a high voltage when the accelerator pedal is fully depressed.
4.27 Volts
APP Sensor 1 and 2
Agree
This parameter displays the results of a control module test that compares the signals from the APP sensors 1 and 2. The scan tool will display Agree or Disagree. Agree indicates that APP sensor 1 and APP sensor 2 voltages correspond to the same accelerator pedal position. Disagree indicates that APP sensor 1 and APP sensor 2 voltages correspond to different accelerator pedal positions.
APP Sensor 2
0.47 Volts
This parameter displays the voltage signal sent to the control module from APP sensor 2 of the APP sensor assembly. APP sensor 2 is a range of values indicating a low voltage when the accelerator pedal is not depressed to a high voltage when the accelerator pedal is fully depressed.
2.10 Volts
Average Injector PWM
1 ms
This parameter indicates the average base pulse width modulation (PWM) or average ON time of the fuel injectors in milliseconds. When the engine load is increased, the injector pulse width will increase.
BARO
60-104 kPa (varies with altitude)
This parameter displays the barometric pressure that is received from the BARO sensor that is integrated within the ECM in kPa.
BARO Sensor
3 Volts
This parameter shows the barometric pressure in volts.
Boost Pressure Sensor
98 kPa
This parameter shows the TC boost pressure in kPa.
1.78 Volts
This parameter shows the Turbo Charger Boost sensor voltage.
Brake Booster Pressure Sensor
26 kPa
This parameter shows the brake booster pressure in kPa.
Brake Pedal Signal Status
Released
The scan tool displays Applied, Valid, Released, or Invalid. This parameter shows the position of the brake pedal position sensor through the serial data bus.
Brake pedal depressed
Valid
Valid
This parameter displays the serial data message of the brake signal from the electronic brake and traction control module (EBTCM).
Calc. TWC Temp.
446°C (834°F)
Calculated catalytic converter temperature.
Calculated ECT - Closed Loop Fuel Control
Varies
This parameter shows the calculated temp used for closed loop control.
Calculated ECT - Thermostat Diagnosis
Varies
This parameter shows the calculated temp for thermostat diagnosis.
Catalyst Monitor Complete This Ignition
Varies
This parameter displays the completion status during the current driving/monitoring cycle of the non-continuous legislated emission related monitor. The states include Yes or No
Catalyst Monitor Enabled This Ignition
Varies
This parameter displays the enable status during the current driving/monitoring cycle of the non-continuous legislated emission related monitor. The states include Yes or No.
Catalytic Converter Protection Active
No
This parameter displays the state of the Catalytic Converter Protection mode.
CKP Active Counter
0-255 Counts incrementing
This parameter displays an incrementing counter when the control module receives a signal from the crankshaft position (CKP) sensor.
CKP Resync Counter
0 Counts
This parameter displays the number of times the control module has to resynchronize the CKP sensor.
Clutch Start Switch (if equipped)
Varies
This parameter displays the current state of the clutch pedal as determined by the control module. The scan tool will display Applied when the clutch pedal is depressed, and Released when the clutch pedal is not depressed.
Cmmd. A/F Equivalence Ratio
4.6:1
Equivalence numbers greater than one represent excess fuel in the fuel air mix. Equivalence numbers less than one represent a deficiency of fuel in the fuel air mix for complete combustion. The equivalence ratio will be reported as one when the vehicle is in Closed Loop.
CMP Sensor
RPM
This parameter will read zero unless there is a fault with the sensor. Then the value will increase to 255 and stop.
Cold Startup
Varies
This parameter displays whether the engine meets the conditions for a cold startup during the present ignition cycle. The scan tool displays Yes when the conditions for a cold startup are met during this ignition cycle. The scan tool displays No when the conditions for a cold startup are not met during the present ignition cycle. Conditions for a cold startup require the coolant temperature and the intake air temperature to be below a predetermined temperature and within a certain range of each other. These conditions must occur after the engine was warmed up to a specific temperature during the previous ignition cycle.
Control Module Voltage Signal
14.1 Volts
This parameter shows the control module voltage.
Cooling Fan Motor Command
30%
This parameter shows the percent of the pulse width modulated (PWM) duty cycle that the cooling fan motor is commanded.
CPP Learned Apply Position
Volts
This parameter contains the position learned for the clutch pedal position sensor when the clutch pedal is fully applied during the associated learn procedure.
CPP Learned Release Position
Volts
This parameter contains the position learned for the clutch pedal position sensor when the clutch pedal is released.
CPP Switch (If equipped)
Released
Crank Request Signal
No
This parameter shows the power mode status of the starter motor. When Yes is displayed, a request to engage the starter has been received by the ECM.
Ignition switch in the crank position
Yes
Cruise Disengage 1-8 History
Brake
These parameters indicate the last 8 reasons the ECM disengaged the cruise control. Reason 1 contains the most recent reason. The reasons include the following: Brake Pedal Initialize, Cancel, Clutch, Coast Disengage, Coast Speed Low, TAC Inhibit, Accel Rate, Decel Rate, High Speed, Illegal Mode, Low Speed, None, Cruise Sw OFF, Over Set Speed, S/C On Speed Hi, ECM Inhibit, Simul S/C-R/A, TCS, Under Set Speed, DLC Override, Memory DTC, Eng Run Time, Engine Speed, DTC Set, RPM Limit, First Gear, APP Override, Low Voltage, D Whl Spd Low, D Whl Spd Hi, Cruise S/S, Cruise Sw Data, ECT Overtemp, VSES, Trans. DTC, BPP Data, BPP DTC, Park Brake, ACC Inhibit, ACC Brake DTC, ACC Option, ACC Brake Inop, PTO Active.
Cruise Control Active
No
This parameter displays the status of the cruise control system as determined by the control module. The scan tool will display Yes when the cruise control system is in control of vehicle speed. The scan tool will display No when the cruise control system is not operating.
Cruise Inhibit Reason
OFF
This parameter contains one of the last eight reasons that powertrain has disengaged cruise control. A FIFO history buffer, which retains its contents over a battery disconnect, is used to store these reasons with reason 1 containing the most recent reason.
Cruise Inhibited
Yes
This parameter indicates the state of the cruise signal.
Cruise On/Off Switch
Off
The scan tool displays ON or OFF. This is the state of the switch as monitored by the body control module (BCM).
Switch pressed
On
Cruise Resume/Accel. Switch
OFF
Switch pressed
ON
Cruise Set/Coast Switch
OFF
The scan tool displays Active or Inactive. This is the state of the switch as monitored by the body control module (BCM).
Switch pressed
ON
Cycles of Misfire Data
0-2000 Counts incrementing
This parameter displays the number of cylinder firing events that were recorded as misfires as determined by the control module.
Cyl. 1-4 Inj. Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the fuel injector control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
Cyl. 1-4 Inj. Ckt Open Test Status
OK
This parameter displays the status of the output driver for the fuel injector control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
Cyl. 1-4 Inj. Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the fuel injector control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
Cyl. 1-4 IC Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the Ignition control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
Cyl. 1-4 IC Ckt Open Test Status
OK
This parameter displays the status of the output driver for the Ignition control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
Cyl. 1-4 IC Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the Ignition control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
Cyl. 1-4 Knock Retard
This parameter displays the knock retard as commanded by the control module for cylinders 1-4. Each cylinder is controlled individually based on both knock sensor signal inputs.
Decel. Fuel Cutoff
Inactive
This parameter displays the status of the operating mode used to turn off the fuel injectors during certain deceleration conditions. When the scan tool displays Active, the control module has turned off the fuel injectors. When the scan tool displays Inactive, the fuel system is operating normally.
Desired Exh. CMP
0 Degrees
This parameter displays the desired exhaust camshaft position, as determined by the control module. The scan tool will display a higher value for more advanced exhaust valve timing, such as at high load or speed conditions. The scan tool will display a lower value for a less advanced exhaust valve timing, such as at idle.
Desired Fuel Rail Pressure
3.8 MPa
This parameter displays the desired fuel rail pressure as calculated by the control module. This value is calculated based on engine speed, engine load, and sensor inputs. The scan tool will display a higher value at higher engine speeds and loads, and a lower value at idle.
Desired HO2S 1
OK
This parameter displays the desired heated oxygen sensor (HO2S) lambda value as commanded by the control module.
Desired Idle Speed
768 RPM
This parameter displays the engine idle speed in RPM commanded by the control module. The control module compensates for various engine loads in order to maintain the desired engine RPM at idle. This parameter is not valid unless the engine is running.
Desired Int. CMP
0 Degrees
This parameter displays the desired intake camshaft position, as determined by the control module. The scan tool will display a higher value for more advanced intake valve timing, such as at high load or speed conditions. The scan tool will display a lower value for a less advanced intake valve timing, such as at idle.
Desired TC Boost
48 kPa
This parameter displays the desired turbocharger boost pressure as determined by the control module.
Distance Since DTC Cleared
Varies
This parameter displays the distance accumulated since an emission diagnostic trouble code was cleared. The scan tool will display increasing distance as the vehicle is driven.
EC Ign. Relay Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the engine control ignition relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
EC Ign. Relay Ckt Open Test Status
OK
This parameter displays the status of the output driver for the Engine Control Ignition Relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
EC Ign. Relay Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the engine control ignition relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
EC Ignition Relay Feedback Signal
13.0-14.2 Volts
This parameter displays the voltage signal sent to the control module from the engine control ignition relay. The scan tool will display battery voltage when the engine is running. The scan tool will display no voltage when the relay is OFF.
EC Ignition Relay Command
On
This parameter displays the commanded state of the EC ignition relay control circuit. The scan tool will display ON or OFF. ON indicates the EC ignition relay control circuit is being grounded by the control module, allowing voltage to other control module circuits and systems. OFF indicates the EC ignition relay is not being commanded on by the control module.
ECM in VTD Fail Enable
No
This parameter indicates whether or not the engine control module (ECM) is in failure enable mode for the vehicle theft deterrent (VTD) system.
ECT Sensor
72°C (161°F)
This parameter displays the temperature of the engine coolant based on the input from the engine coolant temperature sensor. When the coolant temperature is low, the scan tool will display a low temperature. When the coolant temperature is high, the scan tool will display a high temperature.
Engine Load
Varies
This parameter displays the engine load in percent based on inputs to the control module from various engine sensors. The scan tool will display a low percentage when the engine is at idle with little or no load. The scan tool will display a high percentage when the engine is running at a high RPM under a heavy load.
Engine OFF EVAP Test Conditions Met
This parameter displays Yes if the Conditions for Running the engine OFF EVAP diagnostics are met.
Engine Oil Pressure Switch
OK
This parameter displays the state of the engine oil pressure as determined by the control module. The control module monitors the engine oil pressure switch to determine if the engine oil pressure is sufficient. The scan tool will display low when the engine oil pressure is below a predetermined value.
Engine Oil Temperature Calculated
84°C (183°F)
This parameter displays the engine oil temperature.
Engine Off Time
Varies
This parameter displays the time elapsed since the engine was shut OFF.
Engine Run Time
Varies
This parameter displays the time elapsed since the engine was started. The scan tool will display the time in hours, minutes and seconds. The engine run time will reset to zero when the engine stops running.
Engine Speed
750-800 RPM
This parameter displays the speed of the crankshaft as determined by the control module using an input from the crankshaft position (CKP) sensor. The scan tool will display a high value at high engine speeds and a low value at low engine speeds.
EVAP Fault History
No Fault
This parameter displays the result of the evaporative emission (EVAP) system diagnostic.
Scan tool displays NO FAULT, EXCESS VACUUM, PURGE VALVE LEAK, SMALL LEAK, WEAK VACUUM, or NO TEST RESULT. The EVAP Fault History indicates the status of EVAP system diagnostics performed by the ECM.
EVAP Monitor Complete This Ignition
Varies
This parameter displays the completion status during the current driving/monitoring cycle of the non-continuous legislated emission related monitor. The states include Yes or No.
EVAP Monitor Enabled This Ignition
Varies
EVAP Purge Sol Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the EVAP purge solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
EVAP Purge Sol Ckt Open Test Status
OK
This parameter displays the status of the output driver for the EVAP purge solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
EVAP Purge Sol Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the EVAP purge solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
EVAP Purge Solenoid Command
10-15%
This parameter displays the on-time or duty cycle of the EVAP purge solenoid commanded by the control module expressed as a percent. The scan tool will display a high percentage when the control module is commanding the EVAP purge solenoid to be open a large amount. The scan tool will display a low percentage when the control module is commanding the EVAP purge solenoid to be open a small amount. The scan tool will display 0 when the control module is commanding the EVAP purge solenoid closed.
EVAP Vent Sol Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the EVAP vent solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
EVAP Vent Sol Ckt Open Test Status
OK
This parameter displays the status of the output driver for the EVAP vent solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
EVAP Vent Sol Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the EVAP vent solenoid control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
EVAP Vent Solenoid Command
Venting
This parameter displays the state of the EVAP vent solenoid commanded by the control module expressed as Venting or Not Venting. The scan tool will display Venting when the control module is commanding the EVAP vent solenoid to be open. The scan tool will display Not Venting when the control module is commanding the EVAP vent solenoid to be closed.
Exh. CMP Active Counter
1-255 Counts
This parameter displays an incrementing counter when the control module receives a signal from the camshaft position (CMP) sensor.
Exh. CMP Angle
0 Degrees
This parameter displays the degrees of advanced exhaust camshaft angle related to crankshaft position as determined by the control module based on input from the exhaust CMP sensor. The scan tool will display a higher value for a more advanced exhaust camshaft position. The scan tool will display a lower value when the exhaust camshaft is not being advanced, such as at idle.
Exh. CMP Command
6%
This parameter displays the exhaust camshaft position in percent of range as commanded by the control module.
Exh CMP Sol Bn 1 Ckt Open Test Status
Not Run
This parameter displays the state of the exhaust camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is open. The parameter displays Indeterminate until the circuit has been commanded ON.
Exh CMP Sol Bn 1 Ckt Short Gnd Test Status
Not Run
This parameter displays the state of the exhaust camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is shorted to ground. The parameter displays Indeterminate until the circuit has been commanded ON.
Exh CMP Sol Bn 1 Ckt Short Volts Test Status
Not Run
This parameter displays the state of the exhaust camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is shorted to voltage. The parameter displays Indeterminate until the circuit has been commanded ON.
Exh. CMP Variance
0 Degrees
This parameter displays in degrees, the difference between the desired exhaust camshaft position and the actual exhaust camshaft position.
Extended Travel Brake Pedal Switch
This parameter will display the state of the brake pedal, applied or released.
FC Relay 1 Ckt Open Test Status
Not Run
This parameter displays the state of the fan relay control circuit. The parameter displays Fault if the fan relay control circuit is open. The parameter displays Indeterminate until the circuit has been commanded ON.
FC Relay 1 Ckt Short Gnd Test Status
Not Run
This parameter displays the state of the fan relay control circuit. The parameter displays Fault if the fan relay control circuit is shorted to ground. The parameter displays Indeterminate until the circuit has been commanded ON.
FC Relay 1 Ckt Short Volts Test Status
Not Run
This parameter displays the state of the fan relay control circuit. The parameter displays Fault if the fan relay control circuit is shorted to voltage. The parameter displays Indeterminate until the circuit has been commanded ON.
FRP Regulator Command
125 Degrees
This parameter displays the portion of the high fuel pressure pump stroke that delivers fuel to the fuel rail. The scan tool will display a higher value for a higher commanded pressure, and a lower value for a lower commanded pressure.
Fuel Level Sensor
Varies
This parameter displays the approximate fuel level in the fuel tank as a voltage. The control module calculates this level using the signal from the sensor used to monitor the fuel level in the fuel tank. The scan tool will display a low reading when the fuel level in the tank is low or near empty. The scan tool will display a high reading when the fuel level in the tank is high or near full.
Fuel Pump Relay Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the fuel pump relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
Fuel Pump Relay Ckt Open Test Status
Not Run
This parameter displays the status of the output driver for the fuel pump relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
Fuel Pump Relay Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the fuel pump relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
Fuel Pump Relay Command
On
This parameter displays the commanded state of the fuel pump relay control circuit. The fuel pump relay should be ON when the scan tool indicates the Fuel Pump Relay Command is On. The fuel pump relay should be off when the scan tool indicates the Fuel Pump Relay Command is Off.
Fuel Rail Pressure Sensor
1.2-1.5 Volts
This parameter displays the voltage signal sent to the control module from the sensor used to monitor the pressure inside the fuel rail. The scan tool will display a low voltage when the pressure in the fuel rail is low. The scan tool will display a high voltage when the pressure in the fuel rail is high.
Fuel Tank Level Remaining
Varies
0-100%
This parameter displays the amount of fuel remaining in the fuel tank as a percentage. The control module calculates this level using the signal from the sensor used to monitor the fuel level in the fuel tank. The scan tool will display a low reading when the fuel level in the tank is low or near empty. The scan tool will display a high reading when the fuel level in the tank is high or near full.
0-61 Liters (0-16.2 gallons)
Fuel Tank Pressure Sensor
-19.8 to +12.52 mm Hg/-10.5 to +6.17 in H2O
This parameter displays the fuel tank pressure as calculated based on a signal sent to the control module from the fuel tank pressure (FTP) sensor. The scan tool will display a low value when the pressure in the fuel tank is low or a vacuum. The scan tool will display a high value when the pressure in the fuel tank is high.
0.2-4.0 V
This parameter displays the fuel tank pressure as calculated based on a signal sent to the control module from the fuel tank pressure (FTP) sensor. The scan tool will display a low voltage when the pressure in the fuel tank is high. The scan tool will display a high voltage when the pressure in the fuel tank is low.
Fuel Tank Rated Capacity
61.2 Liters (16.2 Gallons)
This parameter displays the rated maximum quantity of fuel the fuel tank will hold. This is calibrated in the control module to match the vehicle.
Fuel Trim Learn
Enabled
This parameter indicates if the control module is adjusting long term fuel trim in response to the short term fuel trim. The scan tool displays Enabled or Disabled. When conditions are appropriate for enabling long term fuel trim corrections, the scan tool displays Enabled.
Fuel Volatility
Varies
This parameter indicates the rate the fuel can be vaporized in the cylinder as calculated by the control module. The scan tool displays Low, Moderate, or High. The scan tool will display HIGH when the fuel volatility is high. The scan tool will display LOW when the fuel volatility is low.
GEN F-Terminal Signal
45% Varies with electrical load
This parameter is an ECM input of the generator field duty cycle. This is an indication of generator load on the engine.
GEN L-Terminal Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the generator L-terminal control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
GEN L-Terminal Ckt Open Test Status
OK
This parameter displays the status of the output driver for the generator L-terminal control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
GEN L-Terminal Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the generator L-terminal control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
GEN L-Terminal Signal Command
On
This parameter indicates the generator commanded state by the ECM.
HO2S Heater Monitor Complete This Ignition
Varies
HO2S Heater Monitor Enabled This Ignition
Varies
HO2S / O2S Monitor Complete This Ignition
Varies
HO2S / O2S Monitor Enabled This Ignition
Varies
HO2S 1 Heater Command
Varies
This parameter displays the commanded state of the HO2S heater by the control module. The scan tool will display a higher percentage as the heater command is increased, and a lower percentage if the heater is not commanded ON.
On
This parameter displays the commanded state of the HO2S heater by the control module. The scan tool will display On as the heater is commanded ON, and OFF if the heater is not commanded ON.
HO2S 1 Htr Ckt Short Gnd Test Status
Not Run
This parameter displays the status of the output driver for the HO2S heater control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
HO2S 1 Htr Ckt Open Test Status
Not Run
This parameter displays the status of the output driver for the HO2S heater control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
HO2S 1 Htr Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the HO2S heater control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
HO2S 1 Sensing Element
300 Ohms
This parameter displays the resistance of the sensing element within the control module. The front sensors are normally regulated to 80 ohms. The rear sensors are normally regulated between 20-300 ohms which depends on temperature.
HO2S 2
50-850 mV and Varying
The scan tool displays a range of 0-1,106 mV. The HO2S bank 2 parameter represents the exhaust oxygen sensor output voltage. The voltage fluctuates constantly within a range between 10 mV , and 1,000 mV, while operating in Closed Loop.
HO2S 2 Heater Command
Varies
On
HO2S 2 Htr Ckt Short Gnd Test Status
OK
HO2S 2 Htr Ckt Open Test Status
OK
HO2S 2 Htr Ckt Short Volts Test Status
OK
HO2S 2 Sensing Element
0 Ohms
HO2S Sensor 1 Module Signal
Varies
This parameter displays the voltage of the HO2S control transistor, which is internal to the control module.
IAT Sensor
Varies
The scan tool displays °C/F.
The ECM converts the resistance of the intake air temperature (IAT) sensor to degrees in the same manner as the engine coolant temperature (ECT) sensor.
The scan tool displays a range of -40 to +132°C (-40 to +270°F).
IAT Sensor 2
15-60 °C (59-140°F)
This parameter displays the temperature of the air after the turbocharger and the charge air cooler, before it enters the intake manifold. Intake air temp is used by the ECM to adjust fuel delivery and spark timing according to incoming air density.
Ignition 1 Signal
ON
This parameter displays the voltage measured at the ignition 1 circuit of the control module. Voltage is applied to the control module when the ignition switch is in the ignition 1 position.
Ignition Off Time
Varies
This parameter displays the time elapsed since the ignition was last turned off. The scan tool will display the time in hours, minutes, and seconds.
Initial Brake Apply Signal
Released / Applied
This parameter displays the state of the brake pedal that is transmitted over the serial data circuit from the electronic brake control module (EBCM).
Inj. 1-4 Disabled Due to Misfire
No
This parameter displays the status of the fuel injector driver by the control module. The scan tool will display YES if the fuel injector is being disabled due to a misfire detection. The scan tool will display NO if the fuel injector is not being disabled by the control module due to a misfire.
Injector 1 Command
Varies
This parameter displays the amount of fuel injector ON time or pulse width as commanded by the control module.
Injector 2 Command
Varies
Injector 3 Command
Varies
Injector 4 Command
Varies
Int CMP Sol Bn 1 Ckt Open Test Status
Not Run
This parameter displays the state of the intake camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is open. The parameter displays Indeterminate until the circuit has been commanded ON.
Int CMP Sol Bn 1 Ckt Short Gnd Test Status
Not Run
This parameter displays the state of the intake camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is shorted to ground. The parameter displays Indeterminate until the circuit has been commanded ON.
Int CMP Sol Bn 1 Ckt Short volts Test Status
Not Run
This parameter displays the state of the intake camshaft actuator solenoid control circuit. The parameter displays Fault if the camshaft actuator solenoid control circuit is shorted to voltage. The parameter displays Indeterminate until the circuit has been commanded ON.
Int. CMP Active Counter
0-255 Counts
Int. CMP Angle
0 Degrees
This parameter displays the actual intake camshaft position in degrees.
Int. CMP Command
6%
This parameter displays the intake camshaft position in percent of range as commanded by the control module.
Int. CMP Variance
0 Degrees
This parameter displays in degrees, the difference between the desired intake camshaft position and the actual intake camshaft position.
Knock Detected Cyl. 1-4
No
This parameter displays the status of each cylinder for knock detection by the control module. The scan tool will display YES if a knock condition has been detected related to that cylinder combustion event. The scan tool will display NO if there is no knock condition detected related to that cylinder combustion event.
Knock Retard
0 Degrees
The scan tool displays Degrees.
Indicates the amount of spark the PCM is removing from ignition control (IC) spark advance in response to the signal from the knock sensors. The traction control system desired torque signal from the electronic brake and traction control module (EBTCM) may cause knock retard to display a value more than 0.0 degrees if traction control is active.
KS 1 Signal
Varies
This parameter displays the voltage input to the control module from the knock sensor (KS).
KS 2 Signal
Varies
Long Term FT
-10 to +10%
The scan tool range is -99 to +99 percent. This parameter indicates the Long Term fuel trim (FT) correction for bank 1 as commanded by the ECM.
A change made to the fuel delivery will be indicated by the Long and Short Term FT values. The Short Term FT values change rapidly in response to the HO2S signal voltages. These changes fine tune the engine fueling. The Long Term FT values change in response to the trends in the Short Term FT. The Long Term FT makes coarse adjustments to the fueling in order to re-center and restore control to the Short Term FT. The Short Term FT and the Long Term FT can be monitored with a scan tool. A positive fuel trim value indicates that the ECM is adding fuel in order to compensate for a lean condition. A negative fuel trim value indicates that the ECM is reducing the amount of fuel in order to compensate for a rich condition.
Loop Status Sensor 1
Varies
Closed loop indicates that the ECM is controlling fuel delivery according to oxygen sensor voltage. In open loop, the ECM ignores the oxygen sensor voltage and bases the amount of fuel to be delivered on throttle position (TP) sensor, ECT, and mass air flow (MAF) sensor inputs only.
Loop Status Sensor 2
Varies
LT FT Idle/Decel.
0%
This parameter displays the commanded Long Term Fuel Trim correction by the control module for idle and deceleration conditions.
MAF Sensor
3-6 g/s (varies with altitude)
The scan tool displays g/s.
The scan tool displays a range of 0.0-655 g/s. The mass air flow (MAF) is the MAF input frequency converted to grams of air per second. This indicates the amount of air entering the engine.
MAF Sensor
2100 Hz (varies with altitude)
The scan tool displays a range of 0-65,555 Hz. The MAF sensor is a hot wire type air flow sensor. The ECM converts current draw needed by the MAF to keep the hot wires at a constant temperature into a frequency signal. The scan tool displays this frequency in a hertz signal.
MAP Sensor
20-42 kPa (varies with altitude)
The scan tool displays kPa.
The MAP sensor measures the change in the intake manifold pressure which results from engine load and speed changes. As the intake manifold pressure increases, the air density in the intake also increases and additional fuel is required.
The scan tool displays a range of 10-240 kPa.
MAP Sensor
0.80-1.30 Volts (varies with altitude)
The scan tool displays Volts.
The scan tool displays a range of 0-5 volts.
MIL Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the malfunction indicator lamp control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
MIL Ckt Open Test Status
OK
This parameter displays the status of the output driver for the malfunction indicator lamp control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
MIL Ckt Short Volts Test Status
Not Run
This parameter displays the status of the output driver for the malfunction indicator lamp control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
MIL Command
Off
This parameter displays the commanded state of the MIL control circuit. The malfunction indicator lamp should be on when the scan tool indicates the MIL Command is On. The malfunction indicator lamp should be off when the scan tool indicates the MIL Command is Off. The control module will command the MIL On when the ignition is ON with the engine OFF in order to perform a bulb check.
MIL Requested by DTC
No
This parameter shows if the illumination of the MIL has been requested by a failed diagnostic trouble code (DTC).
Misfire Current Cyl. 1-4
0 Counts
The scan tool displays 0-255 counts. The display shows the number of misfires that have been detected during the last 200 cylinder firing events. The counters may normally display some activity, but the activity should be nearly equal for all of the cylinders, and in low numbers.
Misfire History Cyl. 1-4
0 Counts
The scan tool range is 0-255 counts. This parameter indicates the total level of misfire that has been detected on each cylinder. The misfire history counters will not update or show any activity until a misfire or DTC P0300 has become active. The misfire history counter will update every 200 cylinder firing events.
PNP Switch
Park / Neutral
The scan tool displays the position of the transmission selection as Park/Neutral or In Gear.
Post Inj. Cyl. 1 Command
0 ms
This parameter displays the amount of fuel injector ON time or pulse width as commanded by the control module for catalyst heating.
Post Inj. Cyl. 2 Command
0 ms
Post Inj. Cyl. 3 Command
0 ms
Post Inj. Cyl. 4 Command
0 ms
Power Enrichment
Inactive
The scan tool displays ACTIVE or INACTIVE. ACTIVE displayed indicates that the ECM has detected conditions appropriate to operate in Power Enrichment mode. The ECM will command Power Enrichment mode when a large increase in throttle position and load is detected. While in Power Enrichment, the ECM will increase the amount of fuel delivered by entering Open Loop and increasing the injector pulse width. This is done to prevent a possible sag or hesitation from occurring during acceleration.
Reduced Engine Power
Inactive
The scan tool displays Active or Inactive. The scan tool displays Active when the ECM receives a signal from the TAC module that a throttle actuator control system fault is occurring. The ECM limits the engine power.
Reverse Switch
OFF
Manual Transmission Reverse Switch On indicates that the reverse switch hardwire input to the ECM is active.
Short Term FT
-10 to +10%
Spark
18-24 Degrees
The scan tool displays a range of -64 to +64°. The scan tool displays the amount of degrees the ECM commands. The ECM computes the desired spark advance using the following: (1) ECT, (2) engine speed (RPM), (3) load, (4) vehicle speed. The ECM adjusts the timing.
A negative (-) value indicates degrees before top dead center (BTDC) or spark advance; a positive value indicates degrees after top dead center (ATDC) or spark retard.
Starter Relay Ckt Short Gnd Test Status
OK
This parameter displays the status of the output driver for the starter relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to ground on the circuit.
Starter Relay Ckt Open Test Status
OK
This parameter displays the status of the output driver for the starter relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is an open in the circuit.
Starter Relay Ckt Short Volts Test Status
OK
This parameter displays the status of the output driver for the starter relay control circuit. The scan tool will display OK if the circuit is operating correctly or Not Run if a diagnosis has not been made. The scan tool will display Fault if there is a short to voltage on the circuit.
Starter Relay Command
Off
The scan tool displays ON or OFF. This displays the commanded state of the starter relay by the ECM.
On
Start-up ECT
Varies
Indicates the engine coolant temperature at engine start up.
The scan tool displays a range of -40 to +150°C (-40 to +302°F). The scan tool displays the engine ECT at the time the engine was started. The ECM uses start-up ECT for certain DTCs.
Used to determine if the last startup was a cold start.
Start-up IAT
Varies
Indicates the IAT at the time that the vehicle was started. Used to determine if the last startup was a cold start.
The scan tool range is -40 to +132°C (-40 to +270°F).
System Power Mode
Run
This parameter displays the position of the ignition switch.
TAC Forced Engine Shutdown
No
This parameter indicates the status of TAC control by the control module. The scan tool will display YES if the engine has been shut down due to a throttle control fault. The scan tool will display NO if the engine has not been shut down by a throttle control fault.
TAC Motor
Enabled
This parameter indicates the status of the TAC motor driver by the ECM. The scan tool will display Enabled if TAC motor operation is allowed. The scan tool will display disabled if the TAC motor is disabled.
TC Bypass Sol Ckt Open Test Status
Not Run
This parameter displays the diagnostic state of the output driver for the turbocharger bypass solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is an open on the circuit.
TC Bypass Sol Ckt Short Gnd Test Status
Not Run
This parameter displays the diagnostic state of the output driver for the turbocharger bypass solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is a short to ground on the circuit.
TC Bypass Sol Ckt Short Volts Test Status
OK
This parameter displays the diagnostic state of the output driver for the turbocharger bypass solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is a short to voltage on the circuit.
TC Bypass Solenoid Command
On
This parameter shows the state of the turbocharger bypass solenoid. The scan tool shows either commanded on or off.
TC Wastegate Sol Ckt Open Test Status
OK
This parameter displays the diagnostic state of the output driver for the turbocharger wastegate solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is an open on the circuit.
TC Wastegate Sol Ckt Short Gnd Test Status
OK
This parameter displays the diagnostic state of the output driver for the turbocharger wastegate solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is a short to ground on the circuit.
TC Wastegate Sol Ckt Short Volts Test Status
Not Run
This parameter displays the diagnostic state of the output driver for the turbocharger wastegate solenoid. The scan tool will display OK if the circuit is operating correctly. The scan tool will display Fault if there is a short to voltage on the circuit.
TCM Requested Torque
3 N·m
Represents the PWM signal from the EBTCM. The EBTCM reduces the traction control desired torque signal pulse width when a drive wheel slippage situation is detected. The ECM monitors the traction control desired torque signal and reduces drive wheel slippage as necessary by retarding spark timing.
TCM Torque Reduction Active
No
This parameter displays whether EBTCM has determined a reduction in torque took place.
TCS Torque Delivered Signal
0%
Represents the PWM signal which indicates the available torque the engine is delivering to the drive wheels. The EBTCM monitors the Traction Control Torque signal to ensure that the ECM is responding properly to the Traction Control Desired Torque signal.
TCS Torque Request Signal
98%
Scan tool range 0-100 percent. Represents the PWM signal from the electronic brake and traction control module (EBTCM). The EBTCM reduces the Traction Control Desired Torque signal pulse width when a drive wheel slippage situation is detected. The ECM monitors the Traction Control Desired Torque signal and reduces drive wheel slippage as necessary by retarding spark timing, decreasing boost sol. PWM, or increasing air/fuel ratio. The ECM can also turn OFF up to three fuel injectors if the Traction Control Desired Torque signal indicates a large enough amount of drive wheel slippage.
TCS Torque Reduction Active
No
This parameter displays whether the transmission control module (TCM) is reducing torque.
Total Fuel Trim Average
Varies
This parameter displays the overall fuel trim from the idle/decel cell and the cruise/accel cell.
Total Knock Retard
0 Degrees
This parameter indicates how much ignition spark timing is being retarded due to all control systems monitored by the control module. The scan tool will display a high value during extreme conditions such as high temperatures and antilock braking. The scan tool will display a lower value during lighter driving conditions.
Total Misfire
TP Desired Angle
6%
The scan tool displays %. The scan tool displays 0-100 percent. The ECM indicates the desired throttle angle commanded by the vehicle operator. The scan tool indicates the desired throttle angle commanded by the vehicle operator.
With Ignition On, Engine Off, Accelerator pedal not actuated
11%
With Ignition On, Engine Off, Accelerator pedal fully actuated
100%
TP Indicated Angle
6%
This parameter displays the angle of the TP in percent. This information is calculated by the control module using the signals from the throttle position sensors. The scan tool will display a low percentage when the throttle plate is closed. The scan tool will display a high percentage when the throttle plate is fully open.
29%
100%
TP Sensor 1
4.06 Volts
This parameter displays the voltage signal sent to the control module from the sensor used to monitor the position of the throttle plate. This parameter is for sensor 1 of the TP sensor assembly. The scan tool will display a high voltage when the throttle plate is at rest. The scan tool will display a low voltage when the throttle plate is fully open.
3.27 Volts
0.80 Volts
TP Sensor 1 Learned Minimum
4.83 Volts
This parameter displays the learned minimum voltage for TP sensor 1 as determined by the control module this ignition cycle.
TP Sensors 1 and 2
Agree
This parameter displays the results of a control module test that compares the signals from the TP sensors 1 and 2. The scan tool will display Agree when the signal from TP sensor 1 corresponds with the signal from TP sensor 2. The scan tool will display Disagree when the signal from TP sensor 1 conflicts with the signal from TP sensor 2.
TP Sensor 2
0.90 Volts
This parameter displays the voltage signal sent to the control module from the sensor used to monitor the position of the throttle plate. This parameter is for sensor 2 of the TP sensor assembly. The scan tool will display a low voltage when the throttle plate is at rest. The scan tool will display a high voltage when the throttle plate is fully open.
1.71 Volts
4.16 Volts
TP Sensor 2 Learned Minimum
0.69 Volts
This parameter displays the learned minimum voltage for TP sensor 2 as determined by the control module this ignition cycle.
Traction Control Status
Inactive
This parameter displays Active if the electronic brake and traction control module (EBTCM) is commanding traction control.
Vehicle Speed Sensor
0 km/h/mph
The scan tool range is 0-200 km/h (0-125 mph). This parameter displays the vehicle speed. The ECM receives reference pulses from the vehicle speed sensor (VSS) and converts them into km/h and mph for display.
Volumetric Efficiency
15-22%
This parameter displays the calculated volumetric efficiency of the engine as calculated by the control module.
VTD Auto Learn Timer
Inactive
This parameter indicates the time elapsed within the current auto-learn cycle within the immobilizer system.
VTD Fuel Disable
Inactive
This parameter indicates the VTD system has disabled fuel.
VTD Fuel Disable Until Ign. Off
No
This parameter indicates the VTD system has disabled fuel for the remainder of the ignition cycle.
VTD Fuel Enabled
Yes
This parameter indicates that the VTD system has enabled the fuel system.
VTD Password Learned
No
This parameter indicates if learning of the immobilizer secret information is enabled.
Warm-ups Since DTC Cleared
Varies
The scan tool displays a range of 0-255. This parameter counts the number of warm up cycles since a DTC was cleared from memory. The scan tool displays counts.
Wastegate Solenoid Command
0%
This parameter shows the percent of the pulse width modulated (PWM) duty cycle that the wastegate solenoid is commanded.
Wide Open Throttle
No
This parameter indicates the throttle status commanded by the control module. The scan tool will display YES if the vehicle throttle is commanded to wide open. The scan tool will display NO if the vehicle throttle is commanded to an amount less than 100%.
Engine Control Module Scan Tool Output Controls Output Control
Description
A/C Relay
Air Conditioning Compressor Clutch Enable; Air Conditioning Compressor Clutch ON
CMP Actuator System
Exhaust Cam Phase Solenoid Bank 1 Enable; Exhaust Cam Phase Solenoid ON
CMP Actuator System
This function controls the exhaust camshaft position (CMP) actuator. The normal commanded state is 0 degrees. The system will INCREASE or DECREASE the exhaust camshaft timing by changing the duty cycle of the actuator in 5 degree increments up to 50 degrees. This also affects Desired Exh. CMP Angle.
CMP Actuator System
Intake Cam Phase Solenoid Bank 1 Enable; Intake Cam Phase Solenoid Bank 1 ON
CMP Actuator System
This function controls the intake CMP actuator. The normal commanded state is 0 degrees. The system will INCREASE or DECREASE the intake camshaft timing by changing the duty cycle of the actuator in 5 degree increments up to 40 degrees. This also affects Desired Int. CMP Angle.
Cooling Fan
Cooling Fan Speed Enable; Cooling Fan Speed
Cylinder Power Balance
Fuel Injector Enable; Fuel Injector ON
Engine Speed Control
Activates the throttle activation control (TAC) system to change engine RPM. The normal commanded state is None. To enable the RPM control, all instruction on the scan tool must be completed. The system will increase or decrease the RPM within a range of 400-2,000 RPM. The set step value changes the RPM by increments of 25 RPM, 100 RPM, and 500 RPM. The system remains in the commanded state until cancelled by the scan tool.
EVAP Service Bay Test
EVAP Service Test Trigger
EVAP System
Activates the purge solenoid in 10 percent increments from 0 to 100 percent. The device control will be aborted and inhibited if the fuel tank pressure (FTP) sensor exceeds -27 mm Hg (-14 in H2O).
EVAP System
Activates the vent solenoid. The device control will be aborted and inhibited if the FTP sensor exceeds -27 mm Hg (-14 in H2O).
EVAP System
Simultaneously activates the purge solenoid in 10 percent increments from 0 to 100 percent and the vent solenoid. The device control will be aborted and inhibited if the FTP sensor exceeds -27 mm Hg (-14 in H2O).
Fuel Pump
Activates the fuel pump relay for 2 seconds. Also turns fuel pump ON and OFF while engine is running.
Fuel System
High Pressure Fuel Supply System Control - Demanded High Pressure
Fuel System
High Pressure Fuel Supply System Control - MSV Control At Engine Running "High Pressure Test"
Fuel Trim Enable
Disables the ECMs ability to learn new fuel trim parameters. The commanded states are NONE, ENABLED, DISABLED. The normal commanded state is NONE. The system remains in the commanded state until cancelled by the scan tool.
Fuel Trim Reset
Activates the reset of fuel trim data in all fuel trim cells.
GEN L-Terminal
Generator L-Terminal Enable; Generator L-Terminal ON
Loop Status
Controls the system loop status. The commanded states include NONE, OPEN, or CLOSED. The normal commanded state is NONE. When commanded OPEN or CLOSED, the system remains in the commanded state until cancelled by the scan tool.
Malfunction Indicator Lamp
Malfunction Indicator Lamp Enable; Malfunction Indicator Lamp ON
Spark Control
Enables or disables idle spark command. When commanded ON, the idle spark will be controlled to 13 degrees before top dead center. The normal commanded state is OFF.
Special Durations
Graphs the accumulated misfires occurring in each cylinder. The scan tool allows for a reset of the misfire graph.
Starter Relay Control
Starter Relay Enable Starter Relay ON
TC Bypass Solenoid
TC Bypass Solenoid Command ON/OFF
TC Wastegate Solenoid
Wastegate Solenoid Command 0-100%
Throttle Position
Operates TAC motor in 10 percent increments to open or close the throttle blade. The test operates during key ON, engine OFF.
xTooltipElement
Service Information 2009 Chevrolet Cobalt | Cobalt, G5 VIN A Service Manual | Document ID: 2474187
#09-00-89-016A: Warranty Administration - Labor Operation Z1111 - Suspected Tampering or Vehicle Modifications - (May 19, 2010)
Subject: Warranty Admin - Labor Operation Z1111 - Suspected Tampering or Vehicle Modifications
Models: 2011 and Prior Passenger Cars and Trucks
2010 and Prior HUMMER H2, H3
This bulletin is being revised to add model years and update the information. Please discard Corporate Bulletin Number 09-00-89-016 (Section 00 - General Information).
The purpose of this warranty administration bulletin is to provide retail and wholesale service personnel with the policies/procedures and the warranty claims submission procedures that support the suspicion of tampering to a vehicle's electrical, chassis/body or propulsion system.
Labor operation Z1111, Documentation of Vehicle Tampering or Non-GM Vehicle Modifications can be used to reimburse the dealership for the time used to identify and document customer concerns that the dealership has determined are the result of tampering or non-GM vehicle modifications to a vehicle.
Tampering is defined as causing intentional damage to a vehicle and is not covered under the terms of the GM New Vehicle Limited Warranty.
Tampering can include, but is not limited to:
• inducing an electrical components and/or system failures
• disconnecting wires or connectors
• intentional contamination of fluids
Non-GM vehicle modifications include, but are not limited to:
• installation of non-GM accessories
• installation of suspension lowering or lift kits
• installation of aftermarket tires and/or wheels
• installation of "power-up chip" and/or non-GM control module calibrations.
The new Z1111 labor operation is to be used to reimburse the dealership for identifying and documenting tampering or non-GM vehicle modifications. If tampering and/or non-GM vehicle modifications are suspected as the root cause for a customer's concerns, please follow the guidelines below:
• When the Z1111 labor operation is used, thoroughly document the repair order to support the use of the Z1111 labor operation. All straight time must be documented and verified.
• The Z1111 labor operation can be used independently.
• The repair order must be accurately documented with the facts supporting the condition, including photographs or other documentation as appropriate.
• U.S. Dealers: Notify the Fixed Operations Manager (FOM) of the situation.
• Canadian Dealers: Notify the Warranty Manager (WM) of the situation.
If the dealership management in concert with the FOM/WM decides, in the interest of customer satisfaction, to perform repairs related to tampering or non-GM vehicle modifications, the repair order must clearly document that the work performed is not being done to correct a warrantable defect in material or workmanship.
Claims should be submitted using the appropriate labor operation and the dealer must use the Customer Satisfaction box in Global Warranty Management.
If additional time and/or parts are to be charged to GM, use the appropriate labor operation as if it were a defect in material or workmanship. All documentation must clearly indicate that these are not repairs performed under the terms of the New Vehicle Warranty.
Dealer Service Management must be involved in any situation that would justify the use of labor operation Z1111 and all claims will have to be submitted with "Request for GM Authorization" routed to the Warranty Support Center (WSC) or Warranty Manager (Canada).
With the proper documentation, and with the assistance of your Zone Team members, it may be appropriate to initiate the Warranty Block procedures outlined in the GM Service Policy & Procedures Manual, section 1.4.14 (Voided Warranties and Branded Titles).
Global Warranty Management (GWM) Example Repair Performed
Part Count
Part No.
CC
Net Item Type
Labor Op
Labor Hours
Net Item
Suspected Tampering
R
Z1111
0.2
0.0
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
Old Feb 25, 2011 | 10:49 AM
scopedmp5's Avatar
xTooltipElement
Service Information 2009 Chevrolet Cobalt | Cobalt, G5 VIN A Service Manual | Document ID: 2467338
#08-06-04-033D: Identifying Aftermarket Engine and Transmission Calibrations-GasPowered Engines Only and Automatic Transmission - (May 7, 2010)
Subject: Identifying Aftermarket Engine and Transmission Calibrations 2.0L, 2.2L, 2.4L, 2.8L, 2.9L, 3.0L, 3.1L, 3.2L, 3.4L, 3.5L, 3.6L, 3.8L, 3.9L, 4.2L, 4.3L, 4.4L, 4.6L, 4.8L, 5.0L, 5.3L, 5.7L, 6.0L, 6.2L, 7.0L, 7.4L, 8.1L Gas Powered Engines Only and 6T40/45 (MH8), 6T70/75 (MH2, MH4, MH6, MY9), 6L50 (MYB) 6L80 (MYC) or 6L90 (MYD) Automatic Transmission
Models: 2006-2009 GM Passenger Cars and Light Duty Trucks
2006-2009 HUMMER H2, H3
2006-2009 Saturn Models
2006-2009 Opel GT
2007-2008 Daewoo G2X
EXCLUDING Chevrolet Aveo, Pontiac Vibe, Wave, G3, Saab Models, Saturn ASTRA
This bulletin is being canceled because the information no longer applies. Please discard Corporate Bulletin Number 08-06-04-033C (Section 06 - Engine/Propulsion System).
Old Feb 25, 2011 | 10:51 AM
scopedmp5's Avatar
xTooltipElement
Service Information 2009 Chevrolet Cobalt | Cobalt, G5 VIN A Service Manual | Document ID: 2482806
#PI0128A: Engine Misfire/Low Compression - (Jun 1, 2010)
Subject: Engine Misfire/Low Compression
Models: 2008-2010 Chevrolet Cobalt, HHR
2008-2010 Pontiac Solstice
2008-2010 Saturn SKY
2008-2009 Daewoo G2X
2008-2010 Opel GT
Equipped with 2.0L Engine (VIN X - RPO LNF)
This PI is being revised to remove a bulletin reference. Please discard PI0128.
Condition/Concern:
Some 2.0L Turbo engines may come in with a misfire on one cylinder.
For further misfire diagnosis, a technician should perform a compression test. The results may lead to a cylinder with low compression (85-90 psi). This may be the cause the misfire. The cylinder with the low compression may have a burned/ damaged piston from detonation. The damage to the piston is usually above and below the first compression ring in an area about 25.4 mm (1 in) in length.
Recommendation/Instructions:
Damage of this type to the piston is usually caused by aftermarket equipment (examples are: air induction systems, intercooler cooling devices, NOS systems, ECM calibrations), all designed to boost the output of the engine. This increased output of the engine can lead to severe detonation in certain conditions. If diagnosed with this condition, the vehicle should be inspected for aftermarket performance equipment and/or calibrations, and it should be noted on the repair order.
The GM Accessories power upgrade kit by itself is designed for this engine and should be the recommended performance enhancing equipment. Using the GM accessory kit with other aftermarket components could damage the engine as well.
If repairs to the engine are the result of the installation or use of a non-GM approved part, the warranty will not be honored.
Old Feb 25, 2011 | 10:57 AM
northvibe's Avatar
Good information. In the MS3/MS6 Mazda would look to see how many read/writes were on the ECM as well. If it was high they knew you maybe were tuning, cant prove it but you know...
Old Feb 25, 2011 | 11:34 AM
CudaJoe's Avatar
That part right there is complete bullshit.
I can see NOS and ECM calibration changes but a filter? a new intercooler?, charge piping? rofl!
If these morons understood that their design tells the car to lower boost when it sees increases in airload than they would know that an intake, exhaust, intercooler, CPing would NEVER increase engine load and performance... without a ECM parameter change that is.
Old Feb 25, 2011 | 12:08 PM
Grishbok's Avatar
They have every right to, you are asking GM to warranty conditions caused by other manufacturers parts? If you put in an aftermarket air filter, and it shreds and falls apart and gets sucked into the motor creating havoc, is that GM's fault? No, its the aftermarket air filter companies, so why would GM have to pay for your ******* mistake?
Old Feb 25, 2011 | 12:13 PM
northvibe's Avatar
No one ever said they didnt have the right to! There is a reason I go back to stock when I bring my cars in for warranty. If I was GM I'd do the same thing.
Old Feb 25, 2011 | 12:49 PM
CudaJoe's Avatar
well I understand that aspect but the other thing that lies in this is if the engine has issues and their is the aftermarket intake filter on the car and its perfectly fine does this mean its at fault? no. but now they have the means to say it is.
It doesnt say there, If there is an aftermarket IC, intake system that is obviously the cause of the failure... void the warranty.
what it says as I read it, if you see any of this aftermarket **** on the car, you do not need any sort of evidence to say thats what cause the issue and go ahead and void the warranty. an intercooler does NOT increase performance, an intake tube and filter DOES NOT increase performance by itself on our cars. A Charge pipe is a fuggin metal tube.
Old Feb 25, 2011 | 12:54 PM
Witt's Avatar
Air induction system can include the MAF housing which can definitely hose a powertrain over time if not installed and tuned correctly.
Old Feb 25, 2011 | 01:03 PM
tom.g's Avatar
Thank you very much for posting this article, two questions:
1. Does the AC Compressor really disengage when you go WOT?
2. In the Boost Pressure Section it lists pressure at 98 kPa = 14.2PSi, is this service bulleting telling techs to be weary if they see a higher boost pressure?
Luckily as far as I know they can't tell on our cars how many times the ECU has been flashed, either via HP Tuners Write Entire or by Flashing Back to Stock with the Trifecta Dealer Kit. Someone correct me if I'm wrong.
Old Feb 25, 2011 | 01:06 PM
Witt's Avatar
1. Yes, the threshold can be changed via HPT.
2. Kind of. When a CEL/SES light sets it takes a snapshot of all engine parameters at the time. If they see higher than normal MAP pressure when the light set, it can indicate manipulation of the ECU but it can also mean the car is overboosting for a warranty related reason.
Old Feb 25, 2011 | 01:18 PM
ROB517's Avatar
I'm 100% stock and I've seen 16psi???
Old Feb 25, 2011 | 01:23 PM
Witt's Avatar
I didn't read the entire thing but it probably lists parameters with key on engine off which would be atmospheric or 14ish psi above vacuum (0psi above ambient).
Old Feb 25, 2011 | 01:43 PM
tom.g's Avatar
Thanks.
1. SO it's not a factory setting? From what I read it sounds like it is Factory.
2. Lol I should of figured that 14.2PSi is absolute pressure and not guage
Old Feb 25, 2011 | 02:14 PM
scopedmp5's Avatar
ah i love being a tech at the dealer. dont need to worry about this garbage. to sum everything up it all depends where you take your vehicle. some service writers can be complete ***** about voiding **** and there are some that will basically bend over and grab their ankles just to keep you as a customer. very shaddy buisness.......lmao and no they cant really tell if the software has been messed with.
Old Feb 25, 2011 | 02:19 PM
Witt's Avatar
Thanks.
Its factory, some people adjust it though.
GaryGibblez
Jan 14, 2020 10:35 AM
QuickSilver_SS
Jan 21, 2019 06:27 AM
chefhhr
Oct 26, 2015 10:36 PM
metroplex
Sep 27, 2015 07:48 AM
budah93
Sep 15, 2015 07:23 AM
