diagnosis help PLEASE
I have a ss turbo with a trifecta tune and 3"downpipe. It just started making a a vibrating fart sound(only under boost and when warmed up). Sounds like it is coming from turbo/downpipe. It runs flawlessly when it is cold but starts after about 5-10 minutes of driving. Again, only happens under boost and boost pressure does not seem to be affected much if at all?? I had my local mechanic check for exhaust/downpipe leak and he said it is fine. Is it the turbo? Blow off valve? Anything else?? Thanks in advance.
please read and help
OK, I took the car into the garage. They felt the catless down pipe blew out the muffler insulation or something. I checked around and other agreed it was a possibility so I bought a 3 inch stinless cat back system :-) However, the car is still making a groaning muffled sound coming from near the downpipe and maybe turbo area? Any suggestions? Is my turbo going? There is no smoke or oil and it is still boosting--what could it be?? Thanks
its not your turbo because mine makes the same noise and i'm n/a. i have midlength header, high flow cat and gmpp performance catback. if that helps narrow things down for ya
scopedmp5
02-25-2011 02:19 PM
Coblasts
08-27-2008 10:34 PM
